Not-coded key suddenly works on the car
Discussion in 'Gen 4 Prius Technical Discussion' started by MagnusAG99, Oct 17, 2019.
  1. MagnusAG99
    MagnusAG99 Senior Member
    673
    521
    Norway
    Okay, so this is a little strange. We bought a 2016 prius 2 weeks ago, we only got one key with it that was coded because they somehow had lost the other... But yea, we got a brand new not coded one in the mail 2 days ago. It did of course not work on the car, at first... Now after my mom came home with the car and both keys (she was gonna take the car to a toyota dealership to get the key coded to the car). The not-coded key suddenly works on the car? How is that possible? Is it that easy to code keys? you just take a working key, and a non coded key to the car. Start it up, and boom the non coded key is coded? Cause that was literally what happened...
  2. Salamander_King
    Salamander_King Senior Member
    11,024
    8,980
    New England
    Hummm, this is very interesting. Where did you get the brand new not coded key from? Dealer, locksmith, or online seller? Was it really brand new, or refurbished "virginized" fob? I don't have an explanation for what happened to your key, but I have purchased a refurbished "virginized" fob online for my PRIME, but have not done anything with it. I may try taking it with my working key to see what happens.
    My understanding is that for the new fob to work, the key has to be programmed to ECU by using special TechStream program that is only available to authorized Toyota dealers or trusted registered locksmith.
  3. fuzzy1
    10,713
    (*) Is the original key far enough away from the car to be certain that the car isn't starting from it?
    (*) Is there any chance at all that the lost key is actually inside the car? In another recent thread, the car has responded part time, but not all the time, to the missing fob lost somewhere inside.
    I won't completely dismiss the possibility of the car self-registering a virgin fob while a known registered fob is present. While this seems quite unlikely, and not anything I've ever heard of on previous generations, I won't stick my neck out to declare that such a new feature for Gen4 is impossible.
    alanclarkeau likes this.
  4. MagnusAG99
    673
    521
    Norway
    It was a toyota dealer we bought the car from, and they were gonna send a brand new non coded key. And it didnt work the first day it came in the mail, which makes sense. But today after my mom came home from work, it worked even while the actual key we knew worked was in our key locker (that blocks all signals from all our key`s). So i have no clue why or how, but it works now...
    I thought the key had to be coded with one of those tools the Gen 3 uses aswell, but apparently not? lol... Im going down the toyota dealership here tomorrow and ask how this is possible...
  5. fuzzy1
    10,713
    Take the non-coded key out and away from the car, then try again, verifying that the car doesn't start.
    If it still starts, then my bet is that the 'lost' key is somewhere inside the car, and very recently shifted into a detectable location or condition.
    If it doesn't start, then keep pursuing the apparent self-registration of the virgin key.
    alanclarkeau and krmcg like this.
  6. CooCooCaChoo
    CooCooCaChoo Senior Member
    962
    544
    Cow-lee-fornia
    2023 Prius
    ^^^ This is where my money is at too. The lost fob probably slipped down and out of previous owner's pocket and is sliding around under the seat. It's battery maybe low to boot.
  7. fuzzy1
    10,713
    At least testing for this is quick and easy. Not a certainty that this is it, but the probability is high enough compared to the minuscule time and cost of the test, that it is very well worth testing for.
    A low battery should trigger an alert on the dash display. It is tested for and coded into the digital transmission by the fob itself, not judged by signal strength received by the car. My spouse's key has that issue right now.
  8. MagnusAG99
    673
    521
    Norway
    Just tried, it starts with the non-coded key, beeps at me when the car is on and the key is out of car and the car responds when I lock and unlock it.
    If the other key had been somewhere around inside the car, and that that was the key it started with it wouldn’t beep when the non-coded key gets taken out of the car when the car is on. Because the key that started the car would obviously still be inside the car and the car wouldn’t react that the key is gone.
    Also even if that was the case that it was a coded key somewhere in the car, why does the car unlock and lock via the key that has not been “officially coded” and is brand new?
  9. alanclarkeau
    alanclarkeau Senior Member
    7,045
    7,593
    near Brisbane, Australia
    Have you asked the dealer who sent you the key?
    Put it down to a 1 in a million fluke.
  10. MagnusAG99
    673
    521
    Norway
    We called the dealer today, they said they sent a brand new key for our local Toyota dealership to code.
  11. Salamander_King
    11,024
    8,980
    New England
    So, are you saying your local Toyota dealership coded the key before mailing it to you? Is the physical key cut?
    #11 Salamander_King, Oct 18, 2019
    kithmo likes this.
  12. fuzzy1
    10,713
    Though failed, I saw this as a necessary check before more costly paths were explored.
    Problem is, I don't believe that a fob can be fully coded remotely before mailing. The fob also must be registered by the car, which requires a data connection to the car.
    The only thought coming to mind is that possibly Toyota might have added a new software feature to this latest generation. That is, when the car detects a new virgin or pre-primed fob, in the presence of an existing properly paired fob, it is recognized as a new fob intended to be paired, and automatically completes the process. But I haven't seen any discussion of such a feature here, so this 'incident' is worth exploring.
    Done well, this sort of feature would avoid a good chunk of the hassle and expense of adding a new or replacement fob. Done poorly, it is another security hole.
    #12 fuzzy1, Oct 18, 2019
  13. CooCooCaChoo
    962
    544
    Cow-lee-fornia
    2023 Prius
    Yeah, but it could also mean that its easier to clone a key fob and steal the car now. Hopefully this isn't the case, and if it is, they've built in safety measures.
    scona and alanclarkeau like this.
  14. Salamander_King
    11,024
    8,980
    New England
    Agreed. It is indeed very strange that unregistered virgin fob is working without an effort. Is there anything different for Gen4 sold in EU?
    Yeah, if it's true that having a virgin fob with a registered working fob is all required to make it work on that car, it can be a huge security issue. I can see a scenario in which someone could have a virgin key fob and just ride along on any Gen4 to make it a working key for that vehicle. There has to be some other explanation for what is happening here.
  15. kithmo
    kithmo Couch Potato
    2,404
    2,776
    47
    South Yorkshire, UK
    Maybe the dealer just found the other missing key, which could have been in brand new condition if it wasn't used, and posted it to the OP ?
    The only mystery then, is why it didn't work the first time.
    #15 kithmo, Oct 20, 2019
    Salamander_King likes this.
  16. shadow4478
    shadow4478 Member
    84
    53
    Barrie
    There has to be an explanation
