Not happy with Toyota over seat belt chime
Discussion in 'Gen 3 Prius Main Forum' started by priuscritter, Feb 15, 2011.
  1. Tideland Prius
    16,540
    lol. I'll take the beeps =)
  2. priuscritter
    priuscritter I am the Stig.
    1,525
    199
    Indiana
    Well friends, I took the Prius to another dealer after work today and got the speed sensitive seat belt chime disabled. $28. It's been interesting to read the responses here. Kudos to Gates Toyota of South Bend for actually acting like a service department and not the seat belt police.
    Not happy with Kokomo Toyota for making me go through this. Ridiculous. And not happy with the Toyota Customer Service line for basically telling me that they wouldn't follow what the owner's manual says.
  3. kenmce
    kenmce High Voltage Member
    1,544
    515
    NY
    The problem is that they screwed up when they replaced the comfortable, friendly, well known and understood standard shift selector with that toy joystick thingee up on the dash. Roughly every adult on the continent knows the normal shift selector by heart. I can work it in the dark, or backwards, or on someone elses car without even thinking about it. The little joystick, not so much.
    A normal shifter stays where you put it, and pretty much can't shift by mistake. That d*%n little thing can be whacked by anything, and you might not know you were in reverse, or you might try to shift it by touch and have it wind up going backwards without knowing it.
    The correct solution would be to eliminate that doofy little toy and put back a normal shifter. For whatever reason Toyota decided to keep it and add that &^!! little bell to "fix" the problem instead.
  4. priuscritter
    1,525
    199
    Indiana
    update:
    my dealer (Kokomo) called me today to say they think they have a procedure for me to be able to disable the seat belt chime myself. I decided not to tell him that i already had it done at another dealer. He is faxing me the procedure. I will post it here. I am betting that it is for the gen 2 prius, but if it is for the gen 3 and just not in the manual, then we might have a way to do it without the dealer. it also involves the reverse beep-to-one fix, according to him. I should get the fax tomorrow when i get to work.
  5. docsnavely
    docsnavely Insert Custom Title Here
    66
    Ocoee, FL
    I read this and cringe. As a paramedic and witness to many a horrific death, I can tell you that pulling out of your driveway is a prudent time to be wearing your seatbelt. Statistics don't lie when they say that the majority of auto incidents happen closest to people's homes.
    With that being said, I feel your frustration and as it is your multi-thousand dollar purchase, you are entitled to change whatever the hell you want to change.
    My only advice would be to find another dealer like everyone told me to do when mine was being adamant about not being able to change the reverse beep.
  6. DumbMike
    DumbMike Active Member
    560
    119
    Los Angeles
    I will say that my reading of the Owner's Manual is that the seat belt beep "can" be customized, not that Toyota will do it for you. Pages 587 and 592. If I didn't read some other section of the Owner's Manual that applies, I'd appreciate a page number so that I can read it.
    That being said, I think they could have handled your issue a bit better.
    I will be interested in whatever information you get from the dealer on how to change the beeps, hopefully without having to buy a ScanGuage. Thanks for the work on this.
    Mike
  7. GreenJuice
    GreenJuice Active Member
    195
    127
    London, UK
    I've also used the Scangauge method to disable the seat belt chime.
    Has anyone else noticed that this is only disabled for low speeds up to about 15 mph?
  8. Justin Bird
    Justin Bird Junior Member
    Auckland, New Zealand
    I managed to turn off the seat belt beep in my 2012 Prius by disconnecting the seatbelt sensor connector under the seat. It's the little white one to the side of the big green one underneath the seat. IMG_20200308_152939.jpg
  9. AzusaPrius
    AzusaPrius Senior Member
    2,170
    915
    I can not believe no one mentioned Carista. The price you paid to do that, you could have been able to do so much more with this obd2 reader. Also I think Dr. Prius app app does it too.
  10. Johnny Cakes
    Johnny Cakes Senior Member
    1,045
    780
    Virginia, USA
    You can't fault the people who paid the dealer in this thread. Carista wasn't founded until February 2013. I guess if they were clairvoyant, they could have just waited a couple of years and saved some cash.
  11. Grit
    Grit Senior Member
    6,573
    4,226
    Wilkes Land
    And then came prius tweak app, which is free. Not sure why people still buy the larista app dong, over priced and other apps are just as capable.
    AzusaPrius likes this.
