Not ready
Discussion in 'Gen 3 Prius Main Forum' started by Vastolrd, Aug 30, 2024.
  1. Vastolrd
    Vastolrd New Member
    Poland
    The problem was solved by the mechanic. The wiring harness was damaged. After patching it, everything works as it should.
    Thanks for your help.
    ASRDogman and Tombukt2 like this.
  2. ASRDogman
    ASRDogman Senior Member
    8,058
    4,085
    WHAT wire harness? How was it damaged?
    Did you pinch it? Rodents?
    Brian1954 likes this.
  3. Vastolrd
    Vastolrd New Member
    Poland
    Immobilizer wiring harness.
    Symptoms:
    - the indicator light flashes all the time
    - inability to engage N gear
    - no READY mode
    I probably had to damaged it when I was pulling the wires from the steering column.
