Not sure if I need to replace 02 sensors
Discussion in 'Prius v Technical Discussion' started by Blurredforlife, Jun 4, 2023.
  1. Blurredforlife
    Blurredforlife Junior Member
    75
    Chicago
    I've been getting 38.5 mpg lately. I did a Dr prius check..battery has 64 percent life. Got a catalyst bank 1 when running a smog check. Could it also need replacing catalytic converter? Screenshot_20230604_143041_BlueDriver.jpg Screenshot_20230604_143041_BlueDriver.jpg Screenshot_20230604_140539_BlueDriver.jpg Screenshot_20230604_143041_BlueDriver.jpg Screenshot_20230604_140539_BlueDriver.jpg
  2. BiomedO1
    BiomedO1 Senior Member
    4,635
    2,433
    Left Coast
    Also check your ECT- (engine coolant temperature), MAF- sensor, air filter; that'll also cause you to run rich.
    How many miles on her and what maintenance has been done to her?
  3. Blurredforlife
    75
    Chicago
    I've got around 186k on it.
  4. Tim Jones
    Tim Jones Senior Member
    1,762
    569
    SE Texas
    2011 Nissan LEAF
    Just the rite miles for all of the bad stuff to start happening............... : (
  5. SSAutomotive
    SSAutomotive Junior Member
    Stewartstown, PA
    Voltage readings like that is 99% of the time a failing cat. When O2 sensors fail, they'll often lag or just have weird out of range readouts on the ECU. I'd start saving for a new cat or look into cleaning. If you do buy a cat, do not buy cheap; get OEM or equivalent. If you want to clean, I'd replicate the formula best as possible for CATACLEAN using the MSDS, but up the dosage (don't get too crazy). Other folks also use acetone and other solvents, but that's your call.
