Not sure what happened when I got home last night
Discussion in 'Gen 2 Prius Technical Discussion' started by SDB54, Sep 6, 2019.
  1. SDB54
    SDB54 Junior Member
    82
    32
    Northern CA
    How do you tell? Or does Pep Boys etc know if they e been changed?
  2. SDB54
    SDB54 Junior Member
    82
    32
    Northern CA
    I think the place I bought it from did buy a “new” battery, but they got hosed l, which in turn means I’m getting hosed.
    The car place is trying to get the receipt for the batter so they can exchange it/get their money back.
    Meanwhile I’m not comfortable driving this thing anywhere but home or somewhere to get the battery replaced.
    SFO likes this.
  3. SFO
    SFO Senior Member
    5,302
    4,247
    Northern California
    Just compare the new to the old.
    If they're doing the installation, they won't sell you a battery that doesn't fit.
    Skibob likes this.
  4. Skibob
    Skibob Senior Member
    2,912
    1,502
    Northern California
    If you have ever looked at battery terminals the original ones will be the smallest ones you have ever seen
    SDB54 likes this.
  5. Skibob
    2,912
    1,502
    Northern California
    A jump box connected to the front jump points will easily start the car. If jumping from a car it’s best the jumping car isn’t running, you need very little power to start a Prius. No need to worry.
  6. SDB54
    SDB54 Junior Member
    82
    32
    Northern CA
    True.
    The guy at Pep Boys is saying the Bosch battery terminals are too big for the Prius and I need the Optima which cost $253 after the discount.
    Bosch is about $160 installed with the discount
  7. Skibob
    2,912
    1,502
    Northern California
    They make a Bosch battery with the little terminals. Several people here have one. Try this website for a dealer internet discount on a battery. Just choose counter pickup and no shipping charges. You would have to install it yourself though.
    Toyota Parts Center Online | Genuine Toyota Parts & Accessories
    SDB54 likes this.
  8. Mendel Leisk
    41,202
    Owners manual says to run engine on donor car for 5 minutes, at slightly raised rpm, IIRC. Check the manual confirm, the hook up sequence too.
    There IS a compatible Bosch at pep boys, or there was.
  9. SDB54
    SDB54 Junior Member
    82
    32
    Northern CA
    I was able to find a Toyota shop close by in Oakland that has the Toyota batteries. Unfortunately, no Internet discount, so it’s $216 plus tax, but has a 7 year warranty.
    I’ll check the Pep Boys ones as well Thanks!
  10. bisco
    51,775
    someone just mentioned in another thread, pep boys prius battery for $125.
  11. SDB54
    SDB54 Junior Member
    82
    32
    Northern CA
    Link?
  12. bisco
    51,775
    i'll see if i can find it
  13. SDB54
    SDB54 Junior Member
    82
    32
    Northern CA
    Thank you, appreciate it
  14. SDB54
    SDB54 Junior Member
    82
    32
    Northern CA
    I've been home 3 hours now (after a 50 minute commute) just put a meter on the battery....11.00 v
  15. 2k1Toaster
    6,035
    3,855
    Rocky Mountains
    50 minutes of charging is useless. 11v is dead. But will usually turn over a Prius.
    edthefox5 and Skibob like this.
  16. SDB54
    SDB54 Junior Member
    82
    32
    Northern CA
    Of course. I knew it wouldn’t re-charge it but I had to get it home. Hopefully it starts in the morning so I can at least get it to Pep Boys etc.
    #36 SDB54, Sep 7, 2019
  17. dolj
    dolj Senior Member
    8,396
    4,278
    Wellington, New Zealand
    I think you recall incorrectly. There is no need to have the donor car running at all, let alone for 5 min at a raised RPM. That sounds like old procedure for regular cars.
  18. Mendel Leisk
    41,202
    Not sure how necessary it is, but this is the North American Owner's Manual text:
  19. richmke
    richmke Member
    73
    48
    Milwaukee, WI
    When my 12v battery needs replacing, I plan on using a Mobility Battery. They are designed for Deep Discharge, so leaving the Prius for a week or 2 without driving is not a problem. I think Battery Plus has one for around $100.
    Fitting mobility 12volt AGM battery. | PriusChat
    SDB54 and SFO like this.
  20. Skibob
    2,912
    1,502
    Northern California
    It might say that in the owners manual but we all know you don’t have to do that. Probably canned language for every Toyota model.
