Notes on changing the engine coolant on a gen 3
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Boffin, Sep 4, 2018.
  1. Boffin
    Boffin Member
    43
    66
    Maryland
    After putting it off for a while, I finally got around to changing my coolant. First, I watched NutzAboutBolt's excellent video about how to do it. Twice.
    Then I went about getting some new coolant. Zerex makes an "Asian" coolant which they assure me is just as good as the Toyota LLC coolant. Here's my query:
    Comments: I am about to change the engine coolant in my 2010 Toyota Prius, and just bought 2 gallons of Zerex Asian Vehicle formula (red label), part # 675130. I'd like to make sure that this coolant will be OK for this vehicle. Tom
    and their reply:
    Tom, thank you for contacting Valvoline Product Support. We do recommend Zerex Asian Vehicle Antifreeze/Coolant for the combustion engine cooling system on your 2010 Toyota Prius.
    If you have any further questions, please feel free to contact us via phone at 800 TEAM VAL or by email at [email protected] for assistance.
    Thank you and have a great day.
    Michael
    So. The Zerex was $17/gallon, the official Toyota coolant, $31. The owner's manual does not insist that you use their coolant:
    Use either of the following:
    • “Toyota Super Long Life Coolant”
    • Similar high-quality ethylene glycol-based non-
    silicate, non-amine, non-nitrite, and non-borate
    coolant with long-life hybrid organic acid technol-
    ogy
    Do not use plain water alone.
    I went with Zerex.
    Then, I jacked up the front end of the car, supported it on jack stands, and proceeded to remove the plastic under engine cover, grumbling that the Toyota engineers had not realized that this would be a hassle. But wait! What is this hole directly underneath the radiator drain spigot? I peer up the hole, and there's the spigot! Now, if only there was a bigger hole I could get my hand into and reach around for that spigot. There is! About 6" to the rear of the spigot hole. The engineers knew their stuff, the manual writers didn't.
    If you're stronger than I (a rather low bar, that) you can just twist the spigot open. I needed my small vice grips to get that first 1/8th of a turn, and then voila! the fluid started to drain. I gave it about 20 minutes and then hand tightened the spigot closed. It's sort of like an oil filter. After it's been closed (for 8.5 years, in my case) they get more than a little stuck. But re tightening is only to 9 ft-lbs, so that's easy, even for me.
    Then refill the coolant reservoir, as per NutzAboutBolt's video.
    If you've been putting it off because of the under engine cover removal, you're out of excuses. This is actually a pretty easy job.
    Montgomery, surfn, TeePeeB and 2 others like this.
  2. Mendel Leisk
    42,347
    The repair manual says to also remove the "cylinder block drain cock plug". It's around the exhaust side of the engine, about halfway up, on the passenger side. That said, I've heard precious little comes out. I'll give it a try, when I get there, see what happens. I know with Honda's there was always a deluge when the similar bolt was removed.
    Did you do the "inspection mode" thing, warm up the car and keep topping up? @NutzAboutBolts video shows that I think?
    Soh, TeePeeB and NutzAboutBolts like this.
  3. NutzAboutBolts
    NutzAboutBolts Senior Member
    1,756
    1,789
    Bay Area
    Easier than changing brake pads lol
  4. Boffin
    Boffin Member
    43
    66
    Maryland
    Mendel,
    I didn't open the "cylinder block drain cock plug". I suspected that this was yet another thing that the manual writers included to be totally sure that the job worked without a hitch. Note that they also recommend that you remove the under engine cover for an oil change. I've never done that either.
    Being lazy, after I had filled the coolant reservoir to well over the full mark, I just drove around the block a few times for about 10 minutes. It's hot (90 F, 32C) and the engine started nicely, without the kabuki dance of maintenance mode. When done, the coolant was down to the full mark. The remainder of the coolant was tightly capped and placed in the plastic bin just above the spare tire. Next time I buy gas, I'll check the fluid level, and it will be easy to top up, if necessary. (After the engine cools down!) The coolant reservoir gives me a few quarts (or liters, to the rest of the world!) of reserve should a yet unknown air pocket be hiding in the coolant system.
  5. Mendel Leisk
    42,347
    Yeah, I've yet to do a Prius coolant change. Over the year with honda it was basically:
    1. Pour in what it'll take (at the radiator cap, mia in the Prius), with the vent spigot open (there is one on the 2010~2011) untill coolant starts coming out of it.
    2. Shut the vent and keep pouring till it's up to the neck. Fill overflow about halfway.
    3. Start the car and let it run with radiator cap off (again, mia on the Prius), and stand at the ready with a baster and some sort of small container.
    4. As the car warms it starts burping at the radiator neck (did I mention the Prius doesn't have this, lol), and the level will tend to go up/down, mostly up, so stand at the ready with the baster, to avoid overflow.
    5. Carry on untill the cooling fan has come on twice, shut it down and ensure the overflow bottle's on the full mark, ditto for the coolant in the radiator neck (you know), cap the radiator.
    Oh I do that every oil change, 15~16 times by now, and maybe 4~5 other times, for various forays. Always carefully pry the plastic fasteners out, and wash them free of grit before reinstall. I think I might have broken one in all that time. I find that "flap" way to fragile/brittle, want to keep the whole thing intact.
  6. Boffin
    Boffin Member
    43
    66
    Maryland
    Mendel,
    My flap tore off years ago. I replaced it with a piece of plastic, held in place with one of the frame bolts and about 4 sheet metal screws. Ugly, but it works. Oil changes are a bit of a chore, having to deal with that kludged flap. My wife's Prius C has a regular spin on oil filter and openings in the under engine cover to access that and the drain plug. Pity the regular Prius doesn't have that...
  7. yeldogt
    yeldogt Active Member
    810
    313
    NE
    You can get the coolant online w/ ship for bit over $20 bucks.
    I just do a simple refresh - inverter as well.
  8. Mendel Leisk
    42,347
    Checking my receipts: in April 2015 I purchased a 4 liter bottle of Toyota Super Long Life Coolant for $19.14 (CDN), at a dealership parts department. In Canada it's 55% concentration, comes in a 3.7 liter bottle, basically one US gallon.
  9. Michael Mathis
    38
    27
    Boca Raton FL
    "But wait! What is this hole directly underneath the radiator drain spigot? I peer up the hole, and there's the spigot! Now, if only there was a bigger hole I could get my hand into and reach around for that spigot. There is! ...The engineers knew their stuff, the manual writers didn't."
    This is true, and thank you to Boffin for sharing it. Made my work much easier this morning.
    I changed the coolant on my 2013 Prius and didn't need to remove the large plastic cover under the engine. I snaked a plastic tube up to the spigot, reached through the larger hole mentioned above and turned the yellow valve counter-clockwise to drain. Easy peasy. Photo with the yellow valve shown is what you see if you look up into the hole.
    For the oil change, I was very wary of working under the car. In this case, I built a ramp of 2x3 pieces of wood screwed together, drove the car up the ramp, jacked it up to place jack stands behind each tire, then used a third jack in the foreground under the main jack point of the car. Three levels of protection; each can hold the car up on its own. I felt quite secure.
    As it turns out, you can reach everything you need without really going under the car. The coolant spigot and valve are near the front of the car, in a straight line forward from the steering wheel. The oil change door swings open and if you bungee it flat against the bottom of the car (use the front grille), everything is reachable from the "northeast" corner (front corner on the passenger side).
    #9 Michael Mathis, Jun 25, 2020
  10. Mendel Leisk
    42,347
    i take the whole cover off pretty much any slow afternoon. Then just lie under there. Meditate. :whistle:
    Raytheeagle likes this.
  11. Michael Mathis
    38
    27
    Boca Raton FL
    "Then just lie under there. Meditate."
    Ha, as the coolant trickled down through my plastic tube, it crossed my mind, "It's kind of peaceful down here." Had to keep a little attention focused on holding my tube in place, though, or the garage floor might have turned a lovely shade of pink.
    Montgomery likes this.
  12. Mendel Leisk
    42,347
    I've scored a little over a yard of 1/4" ID surgical rubber tubing (it was the end of a spool, covid times at the hardware store, I got it for the cost of a foot. Not my foot...). I figure it'll push on securely to pretty much any spigot, and it's super flexy too, and no memory: goes where you want.
    Planning to do the deed this fall, going to see if anything comes outa the block drain too. At least the first time: I've heard nothing much does come out there. However, it's been reported close to a quart drains from the exhaust heat recovery. Hopefully not by you in another thread: my attention span isn't that hot. :oops:
  13. Raytheeagle
    Raytheeagle Senior Member
    11,269
    15,528
    Bay Area, California
    2019 Prius Prime
    You and your large piece of stump get quality bonding time :).
    Maybe Mrs. Leisk appreciates it too:love:.
    Whatever works in the end (y).
  14. Paladain55
    Paladain55 Active Member
    414
    172
    The South
    Did anybody ever find the engine drain cock? The procedures I've seen just drain the radiator and that is wrong. Thats not a coolant flush. On a 1uz,2uz,3uz if you don't hit the block drains you will only drain 1/4 of the coolant lol.
    The inverter flush looks straight forward though.
  15. Mendel Leisk
    42,347
    Yeah I found it. I drained the radiator first, then raised the car, took off the engine under-panel, and the aluminum metal shield just aft of that, reached waaay up, to right/back face of engine, pushed a tube onto the spigot, opened the valve, and got maybe 1/4 cup of coolant. If that. Don't waste the time and effort.
    What motivated me was previous Honda experience: removing the engine block drain bolt always resulted in a deluge.
    You might want to try pulling off one of the coolant hoses on the exhaust heat recovery system. That's NOT noted in the Repair Manual instruction, but seems like it would be fruitful. I looked at them, but chickened out: they looked formidable, and I figured let sleeping dogs lie.
    Paladain55 likes this.
  16. Paladain55
    414
    172
    The South
    I agree i was gonna say wow that engine drain is way too high! EHRS hose is just normal hose so I'll probably just use some hose pliers and twist it a bit to loosen it up and get it off. I bet if I do all of them I can get probably all of it out. I'll have to record how much comes out.
    I went on the good ole internet today and half of the videos said to use the old red coolant and just drain the rad so i bet a lot of people are doing this. yikes
  17. CR94
    CR94 Senior Member
    2,830
    1,243
    Northwestern S.C.
    i think the consensus of people who've tried is that the block drain isn't worth the hassle. You'll never get all the old coolant out, anyway. That's why Toyota suggests shorter change intervals after the first time, to compensate for the residual.
  18. ASRDogman
    ASRDogman Senior Member
    8,066
    4,086
    The block drain is more for after they machine the block and clean it.
    The only way to get all the used coolant, or oil for that matter, is to take the
    engine aparts and run it through a parts cleaner.
    It's not a Formula 1 car. It's a Prius. (y):whistle:
  19. Paladain55
    414
    172
    The South
    Yeah i don't think they thought it out on this car. But when done correctly the block drains do in fact get it all out. no offense to anyone in here though, it just bugs me lol
    i think the lower heat exchanger hose is just fine though for a good port to use.
  20. ASRDogman
    8,066
    4,086
    Radiator drain IS the lowest point in the coolant system, and the best place to drain it.
