Noticed that the LEDs on Audis go off when Signalling
Discussion in 'Other Cars' started by TonyPSchaefer, May 11, 2011.
  1. TonyPSchaefer
    14,816
    2,499
    66
    Far-North Chicagoland
    I noticed this the other day and thought there was a problem with the dude's car. But then I noticed it in other similar cars. I'll try my best to describe it:
    Audis now have that "eyebrow" of LEDs that run along the top of the headlight assembly. When the car is signalling a turn, the LED eyebrow turns off as the signal blinks. Not as an alternating "LED . Signal . LED . Signal" but the LEDs turn off, the signal blinks and when the signal gets cancelled, the LED comes back on.
    I find this odd. Has anyone else noticed this and does anyone have a rational explanation as to why they would implement this?
    addendum: Here's a thread at AudiWorld acknowledging this: http://forums.audiworld.com/showthread.php?t=2801816
  2. GrumpyCabbie
    GrumpyCabbie Senior Member
    6,722
    2,121
    45
    North Yorkshire, UK
  3. stevemcelroy
    stevemcelroy Active Member
    873
    194
    Boulder, CO
    Yes - I have noticed it as well. In many of the models the LED strip also doubles as the turn signal so it is the strip that is actually blinking. It does look a bit strange, but it seems like it is needed as it would be tougher to notice the blinking if it stayed on - white and amber alternating would be tougher to notice than amber blinking alone. I do not know if this was mandated by the government or if Audi just decided to do it on its own, but I think it is a good decision.
  4. Politburo
    Politburo Active Member
    971
    208
    I believe it's to meet the requirements of the FMVSS. Specifically, Standard 108 (49 CFR 571.108), S5.5.11(a)(4)(iv) which requires deactivation of an adjacent DRL when the signal lamp is activated and certain other conditions are not met. Here is the text. I made minor changes in braces for readability.
  5. San_Carlos_Jeff
    San_Carlos_Jeff Active Member
    871
    160
    Northern California
    2012 Chevy Volt
    I noticed it for the first time yesterday while coming to work. Thought it looked pretty cool.
  6. Trollbait
    12,351
    Is Audi the one with the sad LED brows, or angry like BMW?
  7. V8Cobrakid
    V8Cobrakid Green Handyman
    3,790
    152
    i noticed this a couple months back...
    i was going to say i don't like it.. i think it looks odd.. and it's probably done that way so that people can see the turn signals better (as someone else already proved.. sorry.. not looking at names).
    I like the Mercedes turn signals on the higher end S sedans... an entire row of yellow LEDs under the entire lamp.. very clear to see..
  8. cwerdna
    cwerdna Senior Member
    12,544
    2,123
    SF Bay Area, CA
    Yes. Actually, I'd seen a bunch of Audis where it seemed like one LED strip was burned out. I mentioned this on an OT Audi thread at my350z.com and that's when someone pointed out to me the behavior Tony's pointing out.
    Maybe I wasn't paying that close attention before but now when I look, when I see a Audi w/a strip out, that side's turn signals are on. Now, I'm not so sure about what I saw before. Was I previously seeing a mix of Audis w/the by design behavior and another set really with one set burned out?
  9. Tideland Prius
    16,445
    A few Chrysler products do as it as well but their DRLs are still the high beams. I believe it's so that the indicators can be better seen. Those Audi DRLs are pretty bright (and so are some of the Chrysler products' halogen DRLs)
  10. cproaudio
    cproaudio Speedlock Overrider
    2,401
    760
    CA
    The Prius's turn signal mirrors does the same. I've seen some Cadillacs do the same too. KK6PD's switchback LED mod does the same except his alternates between white and amber. You can get bulbs that act the same as the Audi's.
    This is the Prius's signal mirror
  11. a_gray_prius
    2,927
    783
    IL
    I noticed it on a friend's new Audi. I beleive they do it to reduce any confusion between the turn signal and other accessory driving lights (e.g. the LEDs)
