Now here a a Prius story for you! My 2006 Prius brakes failed!
Discussion in 'Gen 2 Prius Main Forum' started by Alphawolf, Mar 13, 2010.
  1. hobbit
    hobbit Senior Member
    4,089
    469
    Bahstahn
    Having never done a brake actuator but read the procedure pretty
    carefully and chatted with Toyota techs about it, I would agree
    that it's a pain in the tuchus. It's probably similarly gnarly
    on a third-gen, too, even though the plumbing is a little different.
    _H*
  2. 2009Prius
    2009Prius A Wimpy DIYer
    2,705
    511
    63
    I just did this accidentally yesterday. At a parking lot someone next to me suddenly moved his car after I had been slowly moving mine. I stomped on the brake and heard this loud noise as if someone had hit my car. Good to know this is normal. Thanks very much! :)
  3. 2009Prius
    2,705
    511
    63
    So even with Toyota's software tool the brake bleeding is still this time consuming?
  4. Bear68
    Bear68 Member
    373
    72
    West Palm Beach, FLA
    2nd Gen Prius are tough as all get out to bleed the brakes on, and the 3rd Gen can be just much a pain in the neck to bleed. Replacing the actuator on the Gen 3 is actually simple. It is located directly under the wiper pan. Remove the wipers and the pan under them and the actuator is staring you in the face, quick and simple.
