Now it's foggy all the time
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Pinto Girl, Oct 9, 2006.
  1. Tom_06
    Tom_06 Active Member
    609
    142
    Newark, Delaware, USA
    <div class='quotetop'>QUOTE(Pinto Girl @ Oct 9 2006, 02:00 PM) [snapback]330109[/snapback]</div>
    This seems a bit high, even for a Dealer. The list price on Toyota glass is $560.82, discounted price is $448.66. See:
    http://www.trademotion.com/partlocator/ind...amp;catalogid=2
    I've had the misfortune to have 4 or 5 windshields replaced and the labor content just wasn't that high - 2 guys in less than a hour. They are talking about $550 in labor and materials (glue).
    If you do have to do this out-of-pocket, try talking them down - have them spell out the charges for labor and materials.
    - Tom
  2. Pinto Girl
    Pinto Girl New Member
    3,093
    350
    <div class='quotetop'>QUOTE(darelldd @ Oct 9 2006, 05:49 PM) [snapback]330279[/snapback]</div>
    Here's what I did:
    1. Using paper towel as an applicator and an old rag to buff, I rubbed (as hard as I could) Mothers carnuba wax+cleaning compound into the windshield (the can was about four-ish years old and seemed to have a little liquid and possibly some grit in the bottom). I didn't let it dry...buffed and buffed, then wiped off wet and repeated. Did this on and off for probably two hours (I'm not kidding; I'm really pathetic sometimes)
    2. Earlier in the week, I'd ordered the Zaino glass polish, which just happened to arrive while I was in the middle of causing all of this damage. So I switched over to the Zaino, and did the same thing for about another hour and a half.
    3. Next, I thought to myself, I've heard all about these claybars that seem to work so well on paint...so I went right down to the auto parts store and bought one, which I then used in combination with the Zaino product. On the windshield. Buffed hard for about another hour or so. I think it was this combination that caused the hazing.
    4. Then I thought, how about trying the liquid which came with the claybar (again, for paint) so I did that for about fifteen minutes with no effect (i.e., I didn't cause any more visible damage)
    5. Seeking yet another way to inflict harm on my darling Buzz, I tried the liquid 'cleaner-wax' (Meguiar's) that came with the claybar kit. Buffed for about fifteen minutes.
    6. It was at this point that I noticed the haze. I panicked (again) and buffed the h-e-double-toothpicks out of it with a foam wax applicator (moistened with tap water) and the Zaino. Did this for about two hours.
    ...and, boy, are my shoulders tired!
    At this point I called the glass guy. He used what looked like a power drill and some sort of clay compound(s) that he sprayed with a spritz bottle and worked into it for a while. I think it might look a bit better but it's SO difficult to tell; from most angles there's this vague haziness, but if the light hits it just right it goes almost totally opaque. The morning sun is awful; I almost rear-ended someone this morning 'cause it went opaque all of the sudden.
    Believe me, I'd love to not replace the windscreen, but it's difficult to even see the damage from most angles; that's what threw me off after doing all of what I did. I tried to be really, really observant for scratches, but what I wasn't seeing was the hazing. Without some sort of light angled so the glass repair person could see the haze, I don't know how they'd go about fixing it.
    But, clearly (no pun intended, believe me), my understanding of automotive glass is somewhat limited.
    [sigh]
    <div class='quotetop'>QUOTE(Tom_06 @ Oct 9 2006, 06:19 PM) [snapback]330298[/snapback]</div>
    Ahhhhh...thank you for that link! I had a feeling their price was a skosh high, based only on what I'd read here on PC, and this seems to confirm. I will, indeed, be paying out of pocket and shall call to my dealer's attention the difference between the cost of this part and what they're attempting to charge me.
    As I said, I've never had to replace a windshield before. I will *definitely* ask for a breakdown of the charges before going ahead with the job. The price above is ONLY for the part, installation is additional.
  3. jburns
    jburns Senior Senior Member
    829
    111
    Archdale, NC
    <div class='quotetop'>QUOTE(Pinto Girl @ Oct 9 2006, 07:40 PM) [snapback]330303[/snapback]</div>
    Call Guinness!!
  4. PA
    PA Member
    427
    27
    Raleigh, NC
    2019 Prius
    <div class='quotetop'>QUOTE(Beryl Octet @ Oct 9 2006, 06:27 PM) [snapback]330270[/snapback]</div>
    Yeah, I got 2 chips on the hood of my then-2-week-old Prius. Scared the hell out of me when they hit. It looked like the rocks shot straight up in the air after impact like bullets. At least a little dab of touch-up paint will take care of those. By the way, I believe the truck tags are on the front, so they won't get dirty, bent-up, etc. like they would on the back. And they also won't get written down by drivers who just got pelted with rocks.
    Pinto Girl, my condolences on your windshield incident. The good news is it's repairable, and it'll be just fine. It's just one of those lessons we all learn. I would definitely check around instead of just going through the dealer, though. Perhaps someone can give you a recommendation?
  5. cairo94507
    cairo94507 Active Member
    923
    36
    Auburn, CA, USA
    Pinto Girl-
    I am alittle shocked that you did that; you seem to be car savvy. Anyway, I would clal your insurance provider, tell them a rock flew up and struck the windshield right in your direct line of sight and chipped the windshield and you tired to remedy the matter as best you could but it did not work out. Then tell them you took it to a glass shop and they attempted to reapir it and were unable, telling you to replace the winsdshield. Ask what it will cost to have the windshield replaced. I know you just love your car, fret not, a new windshield installed by a professional will not leak. I average at least one a year on one of my cars. None have ever leaked. I would recommend you replace your windshield with a factory glass and not some aftermarket item. Good luck. OH- by the way, my prius only came down 1/2" with the Sportivo springs and struts. Been in the car two weeks and it has not settled any lower than that. I just love that improvement.
    Cairo94507
  6. hdrygas
    hdrygas New Member
    3,650
    Olympia Wa
    I would go with OEM as well. I have had a partner that had a in the parking lot person do his and had leak problems. Now remember we get a lot of rain here in the PNW. Milage will vary.
  7. LMA
    LMA New Member
    57
    Cloverly, MD
  8. richard schumacher
    7,664
    1,045
    United States
    Pinto Girl, I commend you for sharing your experience and giving others a chance to learn from it. This takes courage and selflessness.
    And fear not: many people have had windshields replaced with good results. Good luck to you!
  9. seeh2o
    seeh2o Prius OG
    447
    16
    City of Angels
    I would try using white vinegar on a soft towel or cotton ball, that should cut through the wax and hopefully remove the haze.
    With my last car, an Explorer Sport, I had a LOT of experience with new windshields - over the course of 8 years I had 4 new windshields:
    One was from a rock kicked up by another vehicle while on the freeway;
    One was from someone intentionally throwing a large rock from an overpass at cars on the 5 freeway (I was going 70mph, I was lucky it hit the corner of the roof rather than full on into the windshield - I would have been injured or killed);
    One when my dad accidentally letting go of the windshield wiper (while replacing the blade the car alarm went off and scared him half to death, he dropped the bare metal arm and the windshield cracked instantly. Once I realized he was ok we both laughed our heads off!);
    And finally, thanks to the dealership - they broke the windshield while the car was in for routine service They kept the car for a week without explaination while paying for a rental. They NEVER told me they broke and replaced the windshield, I only found out when I read the paperwork! That service manager was fired by the time I went back to the dealership, I wonder what else he didn't disclose to people???
    Anyway, I never had a problem with leaking from any of the replacement windshields. All were OEM, but only one was replaced by the dealership.
    Good luck...and don't panic next time. Walk away, take a deep breath and count to 100!
  10. Pinto Girl
    3,093
    350
    <div class='quotetop'>QUOTE(richard schumacher @ Oct 10 2006, 08:28 AM) [snapback]330539[/snapback]</div>
    Just wanted to take a moment to give a big THANK YOU! to everyone for all of the support and information. I used the link to pricing for a new windshield, combined with telling them that I'm paying out of my own pocket (I may have layed it on a little thick about how I didn't want to make the insurance company pay when really it's my fault, etc.) to get them to reduce the price of the repairs to $150/labor and $589/for the new Toyota windshield.
    I know that may not be the lowest price possible, but it's lots better! Also might help with my feeble attempt to patch together the shreds of my credibility.
    [laughing]
    --Natalie
  11. Jennjay
    Jennjay Member
    142
    Fort Myers, FL
    Hi there, Personally I think you are being much too nice to your insurance company. As you stated you have full glass coverage that you have never used and always pay for. If you are not going to make a claim when you need it, why carry the coverage?
    The rock is what caused the problem, this was the "accident", not your attempted remedy. I think you should reconsider and put the claim through.
  12. devprius
    devprius /dev/geek
    979
    291
    San Francisco Bay Area, CA
    When I got a crack in my windshield, I eventually ended up taking it to SafeLite for replacement. Total cost was around $300 to me. This was a *lot* cheaper than the nearly $1000 that the dealership wanted. I did nott go through my insurance company for the repair.
    I've had the replacement for over a year with no leaks or optical problems. There are SafeLites all over the Bay Area, or they will come out to your house/business to do the replacement (I had mine done at the shop itself).
  13. JimboK
    JimboK One owner, low mileage
    2,817
    188
    49
    Chesterfield, VA
    I agree with others that you should contact your insurance company. Yes, your well-meaning attempts to fix it are your "fault," as you say, but the rock was not. And that's what you have comprehensive coverage for. Even without your attempts, the insurance company would have (or should have) covered it anyway. Hopefully that will ease your commendable ethical concerns.
    I had a similar rock chip in my previous car, not a big deal normally, but like yours it was directly in my line of sight. As such, it was a distraction and, therefore, a potential (though admittedly small) safety hazard. My insurance company gave me the choice of having a glass shop replace it or try to repair it. The shop gave no guarantee that a repair would be invisible, so I opted for replacement.
    Good luck.
  14. dragonfly
    dragonfly New Member
    2,217
    <div class='quotetop'>QUOTE(Pinto Girl @ Oct 9 2006, 01:00 PM) [snapback]330109[/snapback]</div>
    I rented a car a couple of years ago, and when I turned it in it had a chunk missing from the windshield. I hadn't noticed it, so I paid for it. I think the charge was only $250 or so.
    I think you should let your insurance company take care of it. That's what you're paying them for!
  15. Pinto Girl
    3,093
    350
    Well...I did try the vinegar (also this stuff for hard water spots, being careful not to drip on the paint) but it reamained hazy, so I had it replaced.
    I think I still payed a little too much, but it all worked out okay...and, no, I didn't call the insurance company.
    I decided that, if I'd used a professional to repair it initally, none of this would have happened. Yes, the rock is what started it, but I think this is a bit of a lesson to me, too, about not obessing over material objects. Even ones that I'm deeply obsessed with, like my fair Buzz...
    I think this whole episode is actually a blessing in disguise.
    I could feel the onset of 'Porsche-itis' with my Prius (this is a well-known condition among Porsche owners, where at first you're paranoid about little things like parking lot dings. Then it continues to get worse and worse, to the point where it's almost impossible to even drive out of the garage without being overcome with fear).
    Now that Buzz is no longer "perfect" (not that she ever was, really, but new cars seem like that to me) I'm actually lots less uptight about attempting to keep her prisine.
    Also may have to do with the scarcity I experienced when I was young, but that's another story.
    One question, though:
    The car was returned to me with strips of tape at the top of the windshield, and they said that I have to leave them on for two days. Something about the sealer setting...? Sounded a little odd to me, but it was the end of the day and I just wanted to go home.
    Is this how the process usually works?
  16. mike_m
    mike_m New Member
    232
    Congrats on the new view!!!!!!!!!!!!!!!!!!
  17. naterprius
    naterprius Senior Member
    1,843
    Yes, leave the tape on a for a few days. It won't hurt the paint.
    Nate
  18. Pinto Girl
    3,093
    350
    I **LOVE** this Cult!!!!
    ooops!ummmmmm, make that, community...
    [smile]
    Y'all are the best.
    If this is wrong, I don't want to be right!!
  19. fshagan
    fshagan Senior Member
    1,766
    Noneofyourbusiness, CA
    <div class='quotetop'>QUOTE(Pinto Girl @ Oct 11 2006, 01:32 PM) [snapback]331348[/snapback]</div>
    My "Porsche-itis" was cured the first week I had my Prius; it was keyed in a parking lot the third day I had it.
    I get flipped off every week or so, and two weeks ago had people shooting spit wads at me. Really. Had one that stuck on the driver's side window all the way home. I can't figure out if its people upset about high gas prices, uber-conservatives that don't know I'm a fellow rightie, or what. I did put a NRA sticker on the back of the car, so we'll see if that helps.
    You display a great attitude about all of this. While we can't always control our situations, we do have control over our attitudes about it.
  20. darelldd
    6,059
    389
    Northern CA
    As was already answered, yes this is normal. The glass is sitting on a bed of adhesive, and wants to sag with gravity. The tape is there to hold the glass in position while the adhesive sets. If it is as warm where you are as it is here, you probably can take the tape off in a day. But leave it on for two just for grins. Take the tape off tomorrow, wash the car and the window, and you'll be good to go.
    Then, of course, stop driving it so you don't harm any more rocks on the freeway.
