Now this is weird - car started with nobody in it
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by mikenancy1, May 22, 2016.
  1. mikenancy1
    mikenancy1 2012 PiP (Base), '10 Highlander Hybrid, '05 Prius
    105
    Geneva, IL
    I was standing next to my car in the garage, when suddenly it started up. I got in and turned it off, and it hasn't happened again, but how in the heck...?
    52,891
    left it on by mistake?
  3. mikenancy1
    105
    Geneva, IL
    Nope. I'm sure of that. Logical guess though.
    52,891
    bad 12 volt battery?
  5. fotomoto
    fotomoto Senior Member
    5,639
    3,815
    So. Texas
    How?
    priuskitty likes this.
  6. bisco
    52,891
    when the sun spots are right, sometimes, when my neighbor closes his garage door, my car starts.
    Data Daedalus, mrlebop and N.J.PRIUS like this.
  7. mikenancy1
    105
    Geneva, IL
    I'd been parked in the garage for several hours with the car plugged in. I went out there to take the garbage out, and while I was in he garage, it started. Had I left it on, it would have started up much sooner, I suspect.
  8. Starship_Enterprius
    Starship_Enterprius Active Member
    334
    163
    Ottawa, Ontario
    2018 Prius Prime
    was it locked when it started?
  9. Mendel Leisk
    42,373
    Maybe it had started up sooner. Then it shuts down. And so on.
    The "smoking gun" is that you left it on; think bisco nailed it in first response.
    #9 Mendel Leisk, May 27, 2016
    Data Daedalus and Okinawa like this.
  10. Zythryn
    Zythryn Senior Member
    6,412
    4,415
    How did you know it was on?
    If it was because you heard the engine, it is likely you left the car on.
    If you leave the car on, it will sit there quietly until the traction battery runs down to a certain level.
    At some point, the engine will turn on to recharge the traction battery. After it charges up some, the engine will turn off again and the cycle will continue.
  11. Okinawa
    Okinawa Senior Member
    1,333
    320
    When I first got my Prius I got out of the car and left it on a couple of times. What I started doing to prevent that is to lock the door every time I get out of the car and if it is left on the door will not lock and you will hear a loud audible sound that will get your attention that you left it on. It works for me.
    Pluggo likes this.
  12. WilDavis
    WilDavis Senior Member
    2,493
    2,155
    49
    I've done the same thing more than once!
    mrlebop and bisco like this.
  13. bisco
    52,891
    i've left it on until i close the door and hear the beeps. i'm deaf, but i'm not that deaf.
  14. WilDavis
    2,493
    2,155
    49
    ...yet another reason to NOT disable all the warning/idiot lights!
  15. bisco
    52,891
    if you look up idiot lights in the dictionary, you'll see my picture.;)
    Potorap and WilDavis like this.
  16. mrlebop
    mrlebop Member
    136
    68
    which would be a total bummer if your garage door was closed and carbon monoxide builds up.
  17. Zythryn
    6,412
    4,415
    Which is one of the reasons I like BEVs :eek:
  18. CharlesH
    2,798
    1,166
    Roseville, CA
    It would be very difficult to build up a dangerous level of carbon monoxide with any modern car, let alone a Prius. Emissions systems reduce the CO output to essentially zero, even for conventional ICE cars. Now, I wouldn't bet my life on it, but that is what they say.
  19. Zythryn
    6,412
    4,415
    While this isn't common, it definitely does happen.
    Poisoning death of Highland Park couple points to alarming trend - Lake County News-Sun
    I would agree the amount of CO the Prius emits is much lower than that of a typical ICE car. But as you said, it isn't something you want to bet your life on.
    More common would be blocked tailpipes. Such as from snow. Both are a small percentage of all CO poisonings, however some fear the numbers will grow as more and more cars move to key fobs.
  20. Data Daedalus
    Data Daedalus Senior Member
    1,025
    1,185
    Wembley, London
    On a side note, I always confound not only my wife, but the odd passenger riding shotgun, when, upon reaching my destination, I proceed to run a verbally animated "Vehicle Shut Down Check List" for my Gen II Prius :rolleyes:. No, seriously. This is done virtually "Big Bang Theory" Nerd style o_O. It's probably an OCD thing really, but it ensures that I don't walk away from "The Spaceship" with my propulsion system left online and operational. I've mentally programmed myself to accept that my Prius is a lot more than an ordinary car, so I tend to treat it the same way your average aviation pilot might treat his aircraft :cool:. Believe it or not, my Prius actually gets a 'preflight' walk around before I lift off, every morning! :ROFLMAO:
