NTB put on wrong size tires... Need Advice!
Discussion in 'Gen 2 Prius Main Forum' started by newkbomb, Jan 23, 2007.
  1. Tideland Prius
    16,680
    <div class='quotetop'>QUOTE(JimboK @ Jan 24 2007, 07:07 AM) [snapback]380021[/snapback]</div>
    They're a pretty good set of tyres. We're on our second set in our 02 Camry (OEM tyres). They're quiet and comfortable and good in the dry. They're ok in the wet and snow. We replaced ours at 70ish thousand kilometres. It's a bit short but not too bad. Mileage is pretty good too.
    <div class='quotetop'>QUOTE(Beryl Octet @ Jan 24 2007, 09:08 AM) [snapback]380106[/snapback]</div>
    Yeah, I think anything is a step up from the Integrity.
  2. hyo silver
    hyo silver Awaaaaay
    15,272
    1,604
    off into the sunset
    2025 Prius Plug-in
    XSE Premium
    <div class='quotetop'>QUOTE(Allannde @ Jan 23 2007, 09:25 PM) [snapback]379797[/snapback]</div>
    This feature really shouldn't be all that difficult. It's been available on bicycle computers for many years.
  3. Beryl Octet
    Beryl Octet New Member
    1,293
    Abingdon VA
    <div class='quotetop'>QUOTE(hyo silver @ Jan 24 2007, 02:00 PM) [snapback]380183[/snapback]</div>
    Not difficult at all, probably. But if it were available on cars, don't you think folks who are paying for use of the car by the mile, for example, leasers, would adjust the "size of the tire" setting to minimize the miles driven?
  4. hyo silver
    hyo silver Awaaaaay
    15,272
    1,604
    off into the sunset
    2025 Prius Plug-in
    XSE Premium
    <div class='quotetop'>QUOTE(Beryl Octet @ Jan 24 2007, 03:18 PM) [snapback]380194[/snapback]</div>
    That could backfire by risking a few speeding tickets, though, because they'd have no idea of their true speed! Actually, I was thinking the rpm setting could be adjusted by a dealer or tire shop, not the driver. How does Toyota make allowances for different tire sizes in different markets? There must be an adjustment in there somewhere.
  5. Beryl Octet
    1,293
    Abingdon VA
    <div class='quotetop'>QUOTE(hyo silver @ Jan 24 2007, 02:31 PM) [snapback]380198[/snapback]</div>
    I've seen trucks and cars in the bad old days where a different gear in the transmission that drives the odometer can be installed to allow for different tire size/rear axle gear ratios. I imagine anything very modern probably does this through software, but probably not accessible to the owner, or even guys in a tire store for that matter..
  6. auricchio
    auricchio Member
    921
    Cambria, CA, USA
    <div class='quotetop'>QUOTE(hyo silver @ Jan 24 2007, 11:31 AM) [snapback]380198[/snapback]</div>
    Either the sizes (and therefore revs/mile) are close enough to not need adjustment, or the adjustment is made at the factory.
    The tires aren't that much different in different markets.
  7. dmckinstry
    dmckinstry New Member
    1,034
    Cheney, WA (Near Spokane)
    <div class='quotetop'>QUOTE(Allannde @ Jan 23 2007, 05:25 PM) [snapback]379797[/snapback]</div>
    Interesting. On my car, CAN-View reports about 1 mph less than the speedometer at speeds of 55-65 mph.
    I don't go fast enough to get a 2 mph difference, and haven't paid attention a lower speeds.
    Dave M.
