Number 1 cylinder misfire
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by tgotr, May 17, 2020.
  1. tgotr
    tgotr Junior Member
    34
    Southern Michigan, below da bridge
    I changed out the Coil, now the number 3 cylinder is acting up and it's knocking. I am going to go with NGK plugs and all four coils, then clean the EGR shit again, despite not getting any engine codes but it's knocking like crazy at low RPMs but that could just be low quality plugs and coils. Since I'll have the wiper cowl off anyway. I inspected the injectors, checked out. No vacuum leaks either.
    Still no obvious signs of a head gasket leak.
  2. Mendel Leisk
    42,354
    Have you cleaned the intake manifold? Forget if it's been asked/answered. It has a small dia (1/4" EGR passage at each intake port.
  3. tgotr
    tgotr Junior Member
    34
    I cleaned the EGR stuff after I got the car and found out issues with the car resulting in the EGR stuff getting clogged would result in a blown head gasket.
  4. tgotr
    tgotr Junior Member
    34
    Does the same issue that impacts 2010-2014 Priuses (?) Impact other Toyotas? My friend has an '09 matrix and wonder if this stuff is something they should keep an eye on.
  5. tgotr
    tgotr Junior Member
    34
    No more prius. The motor blew apart. It's now a fully electric vehicle.
  6. Mendel Leisk
    42,354
    Help us out, where'd that come from? Actually don't: this'll be a challenge!
  7. tgotr
    tgotr Junior Member
    34
    My assumption is either the oil cooler or the block. I have it sitting at my trusted mechanic and he's going to tell me. I can't take it to a dealer since the nearest Toyota dealership is 1:30 away.
  8. The Critic
    The Critic Resident Critic
    3,193
    2,333
    CA
    Well that escalated quickly.
    Raytheeagle, Mendel Leisk and SFO like this.
  9. SFO
    SFO Senior Member
    5,302
    4,252
    Northern California
    Maybe going fully electric is in my future after all o_O
    Raytheeagle likes this.
  10. mjoo
    mjoo Senior Member
    1,163
    1,334
    Michigan
    I think the EGR cooler was a feature of the Prius only. It was for better fuel economy and for the higher compression ratio of the 2zr-fxe
    Did the engine break when you try to start the car?
    Pixel XL ?
    #30 mjoo, Jun 13, 2020
    SFO likes this.
  11. Mendel Leisk
    42,354
    Completely off-topic, but I remember that like it was yesterday. (y)
    Raytheeagle and mjoo like this.
  12. mjoo
    mjoo Senior Member
    1,163
    1,334
    Michigan
    Hehehe m2
    Those were simpler times. Pre-pandemic and pre-fatherhood.
    #32 mjoo, Jun 13, 2020
    Mendel Leisk and Raytheeagle like this.
  13. Raytheeagle
    Raytheeagle Senior Member
    11,269
    15,528
    Bay Area, California
    2019 Prius Prime
    Fatherhood can change things a bit:).
    The pandemic has changed things a bit:cool:.
    The advice hasn't changed one bit;).
    Stay safe in the land of Gerald Ford(y).
    mjoo and Mendel Leisk like this.
  14. tgotr
    tgotr Junior Member
    34
    Nope, started going up a hill, and there was a bang, low pressure light, and I was leaving a trail of oil in the road like spy hunter. That was the only part I found in the road, I have a feeling there is more and shrapnel.
    SFO, Raytheeagle and Mendel Leisk like this.
  15. mjoo
    mjoo Senior Member
    1,163
    1,334
    Michigan
    Glad you're ok.
  16. tgotr
    tgotr Junior Member
    34
    Yea, cars are replaceable. So I am car hunting. If anyone lives around me, the HV battery is good. $500 takes the battery.
    SFO likes this.
  17. ChapmanF
    19,032
    2ZR-FXE is an Atkinson-cycle engine.
    Low compression ratio. High expansion ratio.
