Number crunching
Discussion in 'Fred's House of Pancakes' started by Leadfoot J. McCoalroller, Apr 22, 2022.
  1. fuzzy1
    10,705
    As mentioned in some other threads, I slashed my home's total energy consumption to about half what it burned in our first fifteen years here, before completing the final solar system expansion to produce the remaining half and reach net-zero. That was done by a mixture of appliance upgrades (especially heating), building envelope improvements, improved winter solar heat gain, and reduced summer heat gain.
    This is a late-1980s house, built to an outdated energy code (still 4" walls) that all nearby then-incorporated areas had already moved beyond (e.g. requiring 6" walls). My work applied to newer minimum-energy-code construction should produce significantly lower consumption than I reached (especially the walls and most windows, which haven't been improved), for less labor. Good passive house design should do much better still -- lower energy use, using smaller heat pumps, and providing better indoor air quality.
    I also try to keep aware of the new concepts and designs and construction practices, but like you, am unlikely to have one built for our later years.
    John321 likes this.
  2. John321
    John321 Senior Member
    1,524
    1,442
    Kentucky
    When we built our home almost 10 years ago we did as much design as possible at the time to make it energy efficient.
    One item I visited was using 2x6 in the framing walls to increase insulation - the builder was not receptive due to door joist, window openings, windows, doors and a few other concerns - not to mention additional cost.
    Looking at some advances made in metal joist and cost reductions, if building today with the escalating energy cost would be much more pro active in searching out a more energy literate and cooperative builder.
  3. Leadfoot J. McCoalroller
    8,284
    7,794
    Pennsylvania
    2018 Prius c
    One part of the house needs to be re-roofed soon. I'm looking at using white shingles to reduce summer heat.
    At least locally, I'm finding that it is quite hard to hire builders who know about this stuff. I talked to 4 or 5 HVAC contractors before finding one who knew what they were doing with modern high efficiency mini-splits.
    I've tried to hire an energy auditor to go through the house and spot whatever I missed, but only found one in the area and he wasn't taking new work for whatever reason.
    I burned through about 12 solar power outfits before I found the one that I hired to build the array, and he's from the next county over.
    I've only found one plumber who is willing to install a heat pump water heater. It's the biggest plumbing shop in the area, owned by private equity- they do their deal by charging roughly double what everyone else does with "easy financing." Their work is top notch, I've seen great results... but double? Hmm.
    The list goes on... point is there seems to be a major skills gap in the local trade force.
    It feels like a small-potatoes version of what I saw when I lived in NYC. Back then you just could not get good trade workers on your project unless your renovation budget was north of $500k.
    #263 Leadfoot J. McCoalroller, Dec 18, 2023
    fuzzy1 and John321 like this.
  4. Salamander_King
    Salamander_King Senior Member
    11,024
    8,978
    New England
    I agree with you 100% on this. The biggest problem is that most of passive energy concepts are very expensive or down right impossible to apply for existing conventional construction to retrofit.
    Living in a tech loaded large 4,000sf net-zero house is just not attainable goal for many. I am not totally anti-tech, but very simple passive solar heated tiny house preferably off-grid is something I would like to build for my self and spend my retirement years. The problem, my wife will not approve of such living conditions. She is very high maintenance. LOL
    John321 likes this.
  5. John321
    1,524
    1,442
    Kentucky
    Agree completely about how hard it is to find energy/certified reliable contractors.
    That would be a nice opportunity for a person who was looking to find a Carrer or Business to operate.
    One thing we did was to build as small a house as possible to live in - we thought this might be our last home. Ours is barely 1500 sq ft. The small space and one story on its own helps cut bills. But additional insulation in the side walls with 2x6 might have made a dramatic difference on heating and cooling loads.
    We did do things like air tight energy listed can lighting in the ceiling that is rated for direct contact with insulation in the attic to prevent air migration into the unheated attic along with as many other small things to cut energy use as we could find.
    Maybe our biggest nod to energy conservation was a Hybrid gas furnace/heat pump combo that was the highest rated at the time for SEER and COP.
    #265 John321, Dec 18, 2023
  6. Leadfoot J. McCoalroller
    8,284
    7,794
    Pennsylvania
    2018 Prius c
    When people can afford the upgrades, anyway.
    Most of the trade guys I've hired are overly cost-sensitive. More than once I've caught them recommending insufficient fixes to problems, and when I call them on it they say it's because they "got in trouble" for recommending something too expensive to the last guy. o_O
    So... I understand. Most of the customers are asking for the cheapest possible thing rather than something that can save energy (and thus money) going forward. Not much incentive for a given tradesman to invest in learning a new system or better method.
  7. John321
    1,524
    1,442
    Kentucky
    You make some great points and the customer wanting the best cost work rather than the most energy efficient is certainly understandable.
  8. fuzzy1
    10,705
    ... and I though my 1980s house was among the very last 2x4 houses built around here. All the nearby new construction we've watched and walked through in the years since have been at least 2x6. I should have paid more attention to the nearby 'mansions' built early last year, to see if their walls were even deeper.
  9. mikefocke
    4,077
    1,861
    Sanford, NC
    I live in a climate that varies from 10 to 100F most years. As my house was being built, my builder calmly explained when I remarked about the amount of insulation he was installing in the attic and walls that "we don't do it like that around here". I offered to pay the extra cost.
  10. Salamander_King
    11,024
    8,978
    New England
    Not all highly insulated construction are more expensive than conventional houses. Two I am thinking are straw bale house and cord wood house. In our area both materials are cheap and DIYable. If I live in Southern arid area, adobe house would be preferable.
  11. Leadfoot J. McCoalroller
    8,284
    7,794
    Pennsylvania
    2018 Prius c
    I'm still trying to figure out my house in terms of construction. The big addition on the front seems like it was done with plans bought out of a magazine and timbers recycled from a church or a barn. The floor joists are these ridiculous 3x14 oak monsters. But they have leftover plaster stains on them, as though they'd been formerly used as studs for a wall and covered with lath and plaster.
    The walls on the first floor are super thick- concrete block with stucco outside, frame & plaster inside. Then it's just stickbuilt 2x4 frame with wood siding for the second floor over it. Very weird.
  12. John321
    1,524
    1,442
    Kentucky
    If you don't mind me asking - what was your motivation for your energy improvements and what has sparked your interest in energy?
    I will share what sparked my interest. At work I was assigned to cut energy consumption in an Automotive Paint Shop. Initially I had no training and went into the job assignment 'blind' but - training and experience was acquired and it has generated a lifelong interest in practical application of energy conservation principles and improvements.
    It is a fascinating topic and I appreciate this thread and its post - very interesting discussions.
    Also I think your efforts to understand your homes construction are an important step in your energy journey - one of the items we were taught is before you can make productive improvements you must properly- grasp the current situation- then once understood you can begin the journey of improving the situation to achieve your goals.
    #272 John321, Dec 19, 2023
    Louis19 likes this.
  13. Leadfoot J. McCoalroller
    8,284
    7,794
    Pennsylvania
    2018 Prius c
    It was a confluence of a few things.
    I learned a lot of the basics of PV power maintaining the family beach cottage which has no grid available- it's that remote. Learning to live on a very tiny electrical budget taught me a lot. So that covered a lot of the education.
    I also had an investment that had matured with little potential for further appreciation, and I wanted to re-invest it in something else. But I'm really fed up with wealth management in general. Too often I feel like I'm making more money for finance weenies than I'm making for me.
    We know we aren't going to relocate for a while, so it made sense to invest in the home. Could have done a new kitchen, new patio & hot tub, or a variety of other nice things.
    Those things would make the home more enjoyable, and there would likely be a positive impact on the valuation at eventual sale. But a PV system like this can add similar value and eliminate a constant and growing expense... which I can use later to fund a fancy kitchen etc.
    I figure the worst that could happen is that somebody invents a cheaper and cleaner method to produce electricity, and my system won't be able to pay for itself. But what's that? Cheaper and cleaner electricity? Well, that's the kind of problem I want to have. But even before that, I think we are safe. With the added tax rebates, the payoff period is now short enough that I really doubt anybody would be able to scale up any new power system before we are recouped.
    John321 likes this.
  14. Salamander_King
    11,024
    8,978
    New England
    We are currently experiencing power outage from a deadly storm yesterday. So far we used 15 gal of gasoline for our generator. That is roughly 20kWh of electricity generated and used. At $4/gal ethanol free gas cost, the cost of electricity for the last 24 hour is $3.00/kWh which is 10 times more expensive than already expensive grid power.
    Even if I had a off grid solar, it would not have helped in this weather. And grid-tied solar would have been just as useless. I have a feeling this outage is going to be a long haul.
  15. Louis19
    Louis19 Active Member
    395
    370
    Laval Québec Canada
    2022 Prius Prime
    Upgrade
    @Salamander_King , hope the outage does not last long . In my region we had a lot of rain but no wind ....so no power outage.
    Solar at my lattitude is not cost effective during winter , sun is really to low and hydropower prices are very low .
  16. fuzzy1
    10,705
    Me? I'm an engineer ...
    An electrical engineer, so I'd been dreaming of PV electricity for decades. Three decades ago, I put up a 50W panel to charge a large 12V battery for some power-outage basics, but solar was still much too expensive for whole-house use. But when re-roofing a decade ago, I reviewed the solar market, compared that to my advancing age and soon-to-be declining physical ability to install a system myself, and decided that it was time to implement that dream before it became too late for me. Over the intervening two decades, I'd also shifted from being mostly skeptical of climate change, to believing more than half of it.
    I also grew up in a pre-WWI house, whose only "insulation" was a layer of tar paper under the siding. It required a huge amount of heating energy, so cutting and splitting firewood for its 1950's era wood furnace (an improvement of the previous fireplace and a wood-fired kitchen stove) consumed a considerable portion of dad's Autumn season. At least the farm had a very large woodlot with an effectively infinite supply of "free" wood, not counting the labor and tractor and chainsaw operating and maintenance costs. "Modern" homes were vastly better, but during the 1970s Energy Crises, I learned there was vast room for improvement in them too.
  17. Salamander_King
    11,024
    8,978
    New England
    Thanks. Going into the second night without power. I went out to get gasoline this morning, most gas stations were closed due to power outage. The one open was on emergency generator, but a long line of cars were waiting in line. I decided to drive to a next town, and lucked out to find a gas station open. Got 20 gal of gas in 4 Jerry cans. Not ethanol free gas, but likely to use them quickly, so regular 10% ethanol gas was fine.
    Yeah, solar in our winter is not very efficient. We have less than 4 hours of full sun in winter days. I have a community solar contract which gives me solar credit at 15% discount, their production now has drops to 30% level from summer time. I was allocated 150% to 200% of credit of my actual usage during summer, now the allocation is only 50% of my actual usage, so I am using credits saved from summer time.
    Unfortunately, unlike in your area, our electric rates are very high. But still much cheaper than the gas generator. Multiple day power outage is not frequent, but with the climate change we are experiencing more severe weather like the storm yesterday. The highest gust recorded was 93mph with some area getting more than whole year worth of rain in 24 hour period.
    I am now thinking of getting a 350gal propane tank to be used for the generator. It will be expensive, but in case I can't get gas, propane storage would make sense.
  18. Leadfoot J. McCoalroller
    8,284
    7,794
    Pennsylvania
    2018 Prius c
    I went for the biggest portable bottles that would fit in our Prius. I think they are 30lb, but there are several sizes close to that so I'm not positive.
    It's a size that is useful in terms of run-time, manageable for refilling, keeps me compatible with "barbecue bottles," I can own it so I'm not paying rent on it forever (common with larger sizes) and if there's a leak it'll only affect one bottle.
    Good luck and hang in there!
  19. fuzzy1
    10,705
    I'm north of your indicated location, so the winter sun is even lower. Though the worst part here is not the low sun, but the typical heavy overcast. As a climate change response, this is addressed by putting up enough solar capacity to produce extra net-metering credits during summer.
    Though abundant cheap hydropower is very hard to beat, especially in zones with enough that they don't need much of any fossil backup. While my public utility is mostly hydro and almost carbon-free, there just isn't enough hydro for everyone in the region, so the private utilities still use a lot of carbon-fuel generation. (Public utilities here get first pick of the prime hydro resources, leaving private utilities just the leftovers and needing to build other capacity.) So even though my solar doesn't offset any carbon use by my particular utility, it does free up some regional hydro to shift to customers on nearby private utilities and reduce their carbon. A net benefit for the region.
    As a winter backup for outages, yes, solar is very inadequate most winter days here.
  20. Salamander_King
    11,024
    8,978
    New England
    I have a few regular 25 lb BBQ grill size tanks as backup. My generator is a dual fuel. I have not run it with propane, but idea of permanent propane tank (350gal) is so that it will last multiple days without needing to refill every 8 hrs. Besides, if roads are blocked, I can't get to the store to get the tank filled. There are far few places where I can refill propane than gas stations. I can't store 350 gal of gas, but propane is doable.
    The problem is that propane as a fuel, the engine will not run as high making it 1kw less than when run on gas. The generator is rated 7500W peak/6500W sustained with gas but only 6500/5500 with propane not large enough for whole house. So, I will likely have to upgrade the generator as well.
