Number of inverter pumps?
Discussion in 'Gen 2 Prius Technical Discussion' started by Prius Fleet Owner, Aug 14, 2018.
  1. ChapmanF
    18,215
    Ok, I take your point, in case the OP personally had no idea that the reason for an inverter pump is to pump coolant to cool the inverter.
    But the first post also mentions what was said by a mechanic at a local garage about the number of pumps appearing to be there. And it seems like the mechanic had enough of an inkling to have counted all the things that look like pumps connected to coolant hoses, and not the other thing that looks like a pump connected to steel brake lines.
    So it still seems like the space for possible legitimate confusion, which I took the post to be about, is still really because of the number of similar-looking pumps that are attached to the same sort of hose and look to be for pumping the same kind of stuff.
    -Chap
    m.wynn and Mendel Leisk like this.
  2. Prius Fleet Owner
    Prius Fleet Owner Junior Member
    22
    Plymouth
    Active
    I did actually know about the inverter having a pump specifically for the coolant unique to the inverter only.
    However, the mechanic did throw some doubt into my mind about it having more than one pump which is why I came here as I was only aware of one which turns out to be the case.
  3. Mendel Leisk
    41,463
    Yeah: two coolant circuits, one for the engine, one for the inverter, and one coolant pump for each.
    The term used for describing both in the Repair Manual is "water pump". Attached are Repair Manual excerpts for replacement of both.
    #23 Mendel Leisk, Aug 16, 2018
  4. ChapmanF
    18,215
    But, but, but, noooooo, haven't we been here before?
    Two coolant circuits, one for the engine, one for the inverter.
    One coolant pump for the inverter circuit.
    two coolant pumps (Gen 1), three pumps (Gen 2), one pump (Gen 3 onward). Gen 4 I can't speak to for sure, but I'd guess it's two, like Gen 1 and Gen 3. The thermos bottle with its dedicated pump was just a Gen 2 thing.
    Refer to post 37 of this thread.
    -Chap
  5. Mendel Leisk
    41,463
    Oh eff, thought this was third gen. @ChapmanF , I'm keeping you as busy a cat in a room full of rocking chairs.
    m.wynn, Raytheeagle and bisco like this.
  6. bisco
    51,949
    it has been one of the more confusing threads.:p
    m.wynn, Raytheeagle and Mendel Leisk like this.
  7. Mendel Leisk
    41,463
    See if I can redeem myself: attached are four second gen repair manual excerpts, for coolant pump removal/install: engine, inverter, heater and the heat storage bottle.
    Raytheeagle likes this.
  8. Elektroingenieur
    2,515
    3,284
    Three Touring
    The fourth-generation Prius has just one inverter water pump and one engine water pump, and replacing the latter requires removing the engine assembly with transaxle. I hope it lasts.
  9. Prius Fleet Owner
    22
    Plymouth
    Active
    That is very unusual for Toyota to place the water pump in a position that requires removal of the transaxle and engine assembly.
    We will have to wait and see on the longevity of the water pump.
  10. ChapmanF
    18,215
    Does the fourth gen not heat the cabin with coolant when the engine is stopped? Or does it just use the engine water pump for that purpose?
    -Chap
  11. Mendel Leisk
    41,463
    Hopefully this is an instance of the absurd over-removal recommended in the Repair Manual.
    But yeah, sometimes they're not kidding, 3rd gen spark plug removal and the need to remove wipers and cowl, for example.
  12. bisco
    51,949
    ouch, another strike against gen 4. poor pump reliability after warranty could be a nightmare for folks.
  13. Elektroingenieur
    2,515
    3,284
    Three Touring
    I believe it’s the latter. The Engine Water Pump Assembly is shown in the diagrams for the air conditioning system. Toyota writes in Course 752: Air Conditioning and Climate Control, “Some hybrids replace the conventional engine water pump with an electric engine water pump controlled by the ECU. In this case a separate electric heater water pump is not required.”
  14. ChapmanF
    18,215
    Huh. Maybe I'm mistaken about Gen 3 then. It certainly has the electric pump on the engine, but I thought it still also had the separate heater one. I'm not signed in to techinfo right now to make sure....
    -Chap
  15. Elektroingenieur
    2,515
    3,284
    Three Touring
    For 2010 and 2015, New Car Features says, “The air conditioning amplifier assembly calculates the flow rate value required for the electric water pump in accordance with the engine coolant temperature and air mix damper opening degree and sends it to the ECM.”
    I didn’t see any mention of a separate water pump for air conditioning there or in the Repair Manual, and the ECM is controlling it, so I assume “electric water pump” means the one attached to the engine.
  16. Mendel Leisk
    41,463
    Just for clarity: "air conditioning" in Toyota texts means any and all cabin ventilation, not just mechanical cooling, with the compressor and condenser.
  17. ChapmanF
    18,215
    Thanks, so I stand corrected:
    Inverter circuit: one pump (all generations)
    Engine circuit: two pumps (Gen 1), three pumps (Gen 2), one pump (Gen 3 onward).
    -Chap
    I've reported my posts 17 and 24 asking the mods to correct them.
    #37 ChapmanF, Aug 19, 2018
  18. Coolride17
    Coolride17 Junior Member
    55
    Just one for invertor. Just got done changi g my bad abs acumulator/pump, so had all those coolant lines disconnected, and fluid wouldnt stop coming out even after draing the hot water heater.lol
