Nutz About Bolts Prius Maintenance Videos
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Tideland Prius, Feb 17, 2016.
  1. cnc97
    cnc97 Senior Member
    1,422
    1,535
    38
    Evansville, IN
    To do a compression test, pull the top apart, remove the coils and plugs. Unplug the injectors. Screw the tester into the first cylinder. Hit the power button, and push down the accelerator pedal. The engine will be commanded on. The spinup will do the job for you. Repeat for other cylinders as required.
    Rebound and Mendel Leisk like this.
  2. mohsin
    mohsin Member
    91
    61
    Dubai, UAE.
    2014 Aqua
    Re; Nutz About Bolts.
    I forgot to mention that I sent these guys an email on Christmas eve as my 3rd Gen started missing.
    Hats off to them that I got prompt response to my numerous emails all during the Christmas festivities.
  3. Rebound
    Rebound Senior Member
    3,996
    2,644
    Portland, OR
    You can also turn on the heater. On a cold vehicle, turning on the heater requires hot water circulation and so the engine must start up.
  4. prius_abbey
    prius_abbey New Member
    Los Angeles
    Hi NutzAboutBolts,
    Do you have a video on GEN 3 AC Fan Replacement of Condenser Fan Replacement (right side)? It makes a disturbing noise when AC is on.
    Thanks
  5. Raytheeagle
    Raytheeagle Senior Member
    11,265
    15,520
    Bay Area, California
    2019 Prius Prime
    Welcome to Prius Chat (y).
    Have you opened the glove box and taken out the filter to see if something is in the squirrel cage fan?
    That might explain the noise;).
    I’d look at that before replacing anything:).
    Good luck and keep us posted (y).
    Rebound likes this.
  6. Mendel Leisk
    41,471
    Is the "condenser" the AC radiator , in the front of the engine bay?
  7. ASRDogman
    ASRDogman Senior Member
    7,599
    3,916
    The condensor is in front of the radiator and cools the hot(ter) freon. The evaporator is behind the glove box,
    and provides the cold air to the cabin.
  8. Mendel Leisk
    41,471
    I always trip over the terms, keep it straight by thinking: if you are condensing it, it's going to get hotter, so that's the one at the front of the car. Somewhat akin to wringing a wet cloth to get water out of it: similarly you compress the AC gas to squeeze the heat out of it.
  9. ASRDogman
    7,599
    3,916
    The expansion valve, or orifice tube, takes the high pressure and opens a small hole to the evaporator.
    The speed of the freon escaping and expanding causes it to get extremely cold in the evaporator.
    The fan blows over it cooling the hotter air. And it also take moisture out. There's all kinds of science behind it.
    Too complicated for me, basically that what it does.
    I'm certain "someone" will give a long, huge, detailed explanation of how it work to show how stupid mine is......
  10. Mendel Leisk
    41,471
    Mostly I was trying to steer the focus away from the dash, back to the front. :)
  11. NutzAboutBolts
    NutzAboutBolts Senior Member
    1,698
    1,745
    Bay Area
    No sorry, I don't. Do you have a video of the noise issue?
    Fostel likes this.
  12. bostonbruins8703
    bostonbruins8703 Active Member
    178
    101
    Brewster, Ma
    2024 Prius Prime
    XSE
    So the EGR cleaning and blown head gaskets seem to be an issue with the early 3rd gens. From your knowledge, what year of the 3rd gen/Prius V (wagon) did this issue become resolved?
  13. Mendel Leisk
    41,471
    The EGR system on 3rd gen Prius and the Prius v hasn't changed to speak of, for the various years. Fourth gen Prius has done a major mod to the EGR: much greater cross-sectional area through the passageways (looks to be roughly double 3rd gen and v), inlet downstream of the Catalytic Converter (vs at the intake manifold on 3rd gen). Toyota even notes the 4th gen EGR revision, in some press releases.
  14. bostonbruins8703
    178
    101
    Brewster, Ma
    2024 Prius Prime
    XSE
    Thank you for answering my question. It is possible to take out the 3rd gen/V EGR and put in one from the 4th gen? forgive me, I'm not mechanically inclined. And did any of the Prius C's have an EGR issue?
    #274 bostonbruins8703, Oct 24, 2019
  15. Mendel Leisk
    41,471
    I'm not sure if the c has EGR, or if it does, it's very rudimentary, and not problematic??
    Someone here has transplanted 4th Gen EGR to 3rd, ultimately successfully IIRC, but it's not a trivial undertaking. He might have needed 4th Gen intake manifold as well. AND, it requires significant mod of 3rd gen exhaust manifold, heating and bending the EGR feeder pipe to match up with 4th Gen EGR cooler inlet.
    My 2 cents: I would just clean the 3rd gen EGR.
  16. Rebound
    3,996
    2,644
    Portland, OR
    It’s an issue with a lot of engines. That, and the PCV blowing oil into the intake. I think the regular maintenance is the best route, and it’s maybe... every 50K miles or more that you’d do this.
    #276 Rebound, Oct 26, 2019
    bostonbruins8703 and Raytheeagle like this.
  17. bostonbruins8703
    178
    101
    Brewster, Ma
    2024 Prius Prime
    XSE
    For those who are not mechanically inclined. How much does a shop charge to do something like this?
  18. Bay Stater
    Bay Stater Senior Member
    534
    771
    Central Mass
    Generally auto repair shops won't clean the EGR System. It takes too long to do. Your best bet is to buy a used one off of EBAY, clean it your self (several threads provide various cleaning methods) and have your mechanic swap it in. ;)
    Raytheeagle and bostonbruins8703 like this.
  19. bostonbruins8703
    178
    101
    Brewster, Ma
    2024 Prius Prime
    XSE
    Problem is, I'm not mechanically inclined. Even with the videos and thread suggestions. =(
  20. Bay Stater
    534
    771
    Central Mass
    You could buy a new EGR valve and EGR Cooler assembly and have your mechanic install it.
    Raytheeagle likes this.
