Nutz About Bolts Prius Maintenance Videos
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Tideland Prius, Feb 17, 2016.
  1. jerrymildred
    jerrymildred Senior Member
    11,517
    14,148
    Tampa, FL
    I had one of those many years ago. My wife hated it. :LOL:
  2. George W
    George W Senior Member
    911
    514
    San Antonio
    I thought the video number 19 was entertaining.
    1. Says all you need is a 14 mm socket(but later says you need a 17 mm open end)
    2. Oops! (Drops)
    3. Oops! (Drops)
    4. Oops(Wrong lubricant)
    5. Goes on to explain the pitfalls of the procedure AFTER the work is done instead of before.
    I don't think I'll be referring to this video when I change my front pads.
  3. 2012 Prius v wagon 3
    2012 Prius v wagon 3 Active Member
    281
    278
    Redwood City, California
    I think it's a great video. Similar to most brakes, you need the 14 mm socket to undo the bolt, and often also need a thin open end wrench (17mm in this case) to hold the pin from just turning, since the bolt screws into the head of the pin. Thin because sometimes there is not much room. Sometimes sufficient impact will knock the bolt loose without needing the wrench, as happened in the video. Usually need to hold with a wrench to torque accurately when reassembling.
  4. Rebound
    Rebound Senior Member
    3,996
    2,644
    Portland, OR
    NutzAboutBolts is infallible!
    But maybe you shouldn’t use a sliding pin lubrication video in place of a brake pad replacement video.
    Raytheeagle likes this.
  5. ASRDogman
    ASRDogman Senior Member
    7,541
    3,893
    The videos are for reference. And they are not "Professionally" done. EVERYONE makes mistakes!
    It doesn't take away from what the video was made to do, to show you his way of doing a certain repair.
    You are more than welcome to make your own videos and post them.
    I always watch several videos of any repair I want to do that I've not done before.
  6. Ed Beaty
    Ed Beaty Active Member
    334
    311
    Salt Lake City
    @George W
    "I don't think I'll be referring to this video when I change my front pads."
    I don't think I'll be referring to any of your comments when I login to PriusChat.
    Ramirezja and RMB like this.
  7. George W
    911
    514
    San Antonio
    You're welcome to do so. If you're going to put a video out there giving advice, cautionary information should be presented first, not last. What if I had decided to use this as my how to guide? I might have ended up like this guy.
  8. Ed Beaty
    334
    311
    Salt Lake City
    Only if you're so stupid you didn't watch the entire video first (advisedly TWICE). Apparently you are that stupid? Like that guy?
    Sad!
  9. Rebound
    3,996
    2,644
    Portland, OR
    George, NutzAboutBolts is an AWESOME resource to our community. They’ve made videos about everything Prius, and they’re really, really good. They’re our heroes. They saved me a fortune. (Or they lead me to buy more tools than an Indy pit crew, one or the other...)
    They made a video about brake pad replacement, but you were looking at a video about lubricating the sliding pins. Please, view the correct video before working on your Prius.
  10. George W
    911
    514
    San Antonio
    In the video the back plate of the brake pad came off and fell to the ground (another Oops) AND he removed the brake pad to reinstall it , so technically you could also say it was also video about brakes.
  11. ASRDogman
    7,541
    3,893
    Person "A" cannot blame Person "B" because Person "A" don't not use common sense.
    As I stated before, watch more than ONE video! And you will learn from others mistakes!
    And also learn some of their tricks and shortcuts. Or, maybe not.
    No one is required to put up any videos. They do it to try to help other people.
    I'm thankful for NutsAboutBolts' videos. I would have figured out how to clean the EGR system, and
    intake manifold on my own. But his videos saved me a LOT of time! And grief! :)
    With any type of repair video, they are not responsible for your actions!
    Do your own research! Watch several videos and you will learn the good, the bad, and the ugly!
  12. jerrymildred
    11,517
    14,148
    Tampa, FL
    Not these days. Everything is always someone else's fault. :(
    Edit to add:
    Blindly following a instruction before you know where they lead isn't terribly bright. I've had teachers give tests that demonstrated that. It's embarrassing. :LOL:
    Ed Beaty and ASRDogman like this.
  13. ASRDogman
    7,541
    3,893
    HEY! That's not MY fault! :eek::rolleyes::LOL:
    jerrymildred likes this.
  14. Grit
    Grit Senior Member
    6,573
    4,226
    Wilkes Land
    It was already like that when I got there.
  15. jerrymildred
    11,517
    14,148
    Tampa, FL
    I didn't do it and I promise I'll never do it again. :rolleyes:
    ASRDogman likes this.
  16. Mendel Leisk
    41,315
    Another positive vote for @NutzAboutBolts . The guy's soft spoken delivery, humour, thoroughness, attention to detail, and you-can-do-it attitude, he's the Bob Fosse Ross of mechanics. Nobody bats 100, but he's up there. (y)
    #316 Mendel Leisk, Mar 26, 2020
  17. Rebound
    3,996
    2,644
    Portland, OR
    Batting 100 is pretty easy, but we get the point.
    jerrymildred and Mendel Leisk like this.
  18. Ed Beaty
    334
    311
    Salt Lake City
    Hey! He's Canadian, and lives in BC, give 'm a break! ;)
    Rebound and Mendel Leisk like this.
  19. Mendel Leisk
    41,315
    Yeah, that's not cricket... :whistle:
  20. NutzAboutBolts
    NutzAboutBolts Senior Member
    1,693
    1,737
    Bay Area
    Hey, at least you learned something from my video, and it is to not watch my videos :ROFLMAO::ROFLMAO::ROFLMAO:
    Bay Stater, RMB, Raytheeagle and 2 others like this.
