Nutz About Bolts Prius Maintenance Videos
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Tideland Prius, Feb 17, 2016.
  1. cnc97
    cnc97 Senior Member
    1,422
    1,535
    38
    Evansville, IN
    Just unplug the fuel injectors. Any code set will self clear after 5 startups.
  2. tony_2018
    tony_2018 Member
    227
    68
    Yeah I think thats what I'm going to do.
    These videos helped alot. Thanks to OP and creator.
    Raytheeagle likes this.
  3. ASRDogman
    ASRDogman Senior Member
    7,602
    3,915
    If you have the plugs out, unplugging the injectors will also work.
    Seems it would be a lot easier, and less risky, maybe damaging the wiring(?) to
    unplug the fuse/relay.
  4. Danny3xd ()
    Danny3xd () Member
    85
    38
    Connecticut
    Just wanted to Thank N&B for all his work and fine vids.
  5. Betty Craven
    Betty Craven Junior Member
    Washington
    Do these apply to a 2008?
  6. Tideland Prius
    16,559
    No. This applies to 2010-2015 models.
  7. batcat420
    batcat420 Junior Member
    Atlanta
    Big thanks to NaB! Recently did a round of 100k maintenance (spark plugs, coolant flush, trans fluid flush) and your videos made it easy.
    Rebound likes this.
  8. michael myers
    michael myers Junior Member
    Chattanooga, Tn
    2015 Prius v wagon
    Thank you for posting this. You're a super hero named Prius Man.
    Rebound likes this.
  9. Bbonez
    Bbonez Member
    40
    44
    @NutzAboutBolts can I a suggest a minor edit? Your video on front brakes in the description your tool list says M8.25 hex bolt to remove the rotors, I believe the correct bolt is an M8 x 1.25. That might help others find the part a little quicker. Thanks again for all the great videos.
    NutzAboutBolts and Mendel Leisk like this.
  10. Mendel Leisk
    41,489
    Good catch. Unfortunately I think he's moved on; last post was Feb 01, 2021. He's done a few product reviews on his Youtube lately, but not Prius or automotive specific.
    Bbonez likes this.
  11. Rebound
    Rebound Senior Member
    3,996
    2,644
    Portland, OR
    You don’t need to replace those bolts; they aren’t one time use bolts.
  12. Mendel Leisk
    41,489
    These are extra bolts, you need to purchase, screw into threaded holes on brake rotors/drums, to help break them loose.
    Bbonez likes this.
  13. ChapmanF
    18,245
    As an alternative, M8✕1.25 bolts are used in a bunch of places on the car, so if you need a couple to pop the rotors loose, you can usually find a couple nearby to borrow, then just put them back later.
  14. ASRDogman
    7,602
    3,915
    Take them off old worn out hubs...
  15. Mendel Leisk
    41,489
    A hybrid strategy: take one of those bolts from the car (typically 12 mm socket size?) verify it fits the threaded holes on rotor/drum, then take it down to hardware store, (one with bolts/nuts in bins), test thread the borrowed bolt on one of their M8 nuts, then use that nut to check-fit of their M8 bolts. 25mm fully threaded works good.
    I picked these up recently, having "misplaced" my earlier set. They're pretty ubiquitous these days.
    Reliable Fasteners Hex-Head Zinc-Plated Metric Bolt - M8 x 25mm - Blunt Point - Grade 8.8 - 3 Per Pack HBZM825MR | RONA
  16. kamrul
    kamrul Junior Member
    99
    17
    Bangladesh
    Though I have a subscription to the channel but this post is a Goldmine to have everything organized here. Thanks for the great work!
  17. Mendel Leisk
    41,489
    Yeah it’d be nice if their YouTube could have some sort of folder for Prius specific. Not sure if that’s even possible; YouTube is a bit of a pain.
  18. Rebound
    3,996
    2,644
    Portland, OR
    Is there anything left for them to do?
  19. rjparker
    rjparker Tu Humilde Sirviente
    10,163
    6,317
    Texas Hill Country
    Thats a playlist if configured by the content creator. A user can create folders under his own account for any combination of videos.
    This is my folder of 54 specific videos from different creators.
    EB40C5D3-67B6-4BBE-A3EC-AADAAD59115E.png DC2C4D3C-9050-48E6-BFB5-31D8F07C4E1C.png
    Plus you can have more specific folders that may duplicate videos in another folder
    #439 rjparker, Nov 21, 2022
  20. Mendel Leisk
    41,489
    Head gasket replacement? I think their videos are only about what befalls their Prius, so knock on wood he never needs to do that one. He did mention getting a Sienna I think, so maybe the Prius is gone.
