Nutz About Bolts Prius Maintenance Videos
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Tideland Prius, Feb 17, 2016.
  1. shmAmmz
    shmAmmz New Member
    Saudi Arabia
    Hello.
    Is there a Gen 2 video playlist like this?
    Thanks.
  2. Mendel Leisk
    41,442
    Not here. IIRC, @nutzaboubolts 2 guys, though one is on camera in the majority of the videos, were Toyota dealership mechanics. The videos were of cars they had, namely 3rd Gen Prius. If you check out their channel they’ve done videos on quite a variety. Currently mostly about Toyota Sienna.
  3. NutzAboutBolts
    NutzAboutBolts Senior Member
    1,698
    1,743
    Bay Area
    Thanks, just edited it.
    johnHRP and Kromis like this.
  4. Purrius
    Purrius Member
    155
    43
    Northeastern US
    @NutzAboutBolts
    Summoned from the wilds, has our boy returned?! (• ˕ •マ.ᐟ
  5. NutzAboutBolts
    1,698
    1,743
    Bay Area
    lol in and out, busy with other stuff going on in life
    Kromis likes this.
  6. NutzAboutBolts
    1,698
    1,743
    Bay Area
    Be on the look out for the inverter water pump video. Just got done filming, just need to edit now.
  7. Danny3xd ()
    Danny3xd () Member
    85
    38
    Connecticut
    Thank Good you use your powers for good, NaBs!
    NutzAboutBolts likes this.
  8. NutzAboutBolts
    1,698
    1,743
    Bay Area
    :ROFLMAO:
  9. NutzAboutBolts
    1,698
    1,743
    Bay Area
    Here’s the video! Broke a few plastic pieces but learned a lot :ROFLMAO::ROFLMAO:
    johnHRP, Fostel, Kromis and 5 others like this.
  10. ASRDogman
    ASRDogman Senior Member
    7,587
    3,913
    Thanks for the video! Very good job!
    And thanks for NOT having and background music playing! (y)
    Is the clip on the inner side by the ac connector a push type, or do you have to rotate it
    with your scribe?
    And the green ones for the coolant hoses, they just slide to the side?
  11. Mendel Leisk
    41,442
    Is there a hope-in-hell you could pull that pump out from below? I'm guessing not. :(
    Repair Manual says no.
  12. NutzAboutBolts
    1,698
    1,743
    Bay Area
    There’s 2 plastic clip on that side, one is the white clip, which you use a needle nose plier to pinch the inside to release it from the plastic bracket. The other one down by the hose that is black is the same as the wire harness clip from the top of the plastic bracket, you pull the clip up and pull the plastic clip out from the clip. Hopefully that’s what you’re talking about, if not, screen shot the image for me and I can answer it correctly.
    The green clip that holds the coolant hose in is a U shape type clip, where you use the pick to pull it out of the hose and then pull the hose out. Make sure to pull it straight out, it’ll lock in place so it won’t fall off, it’ll only go in and out one way. Sometimes you’ll have to use your middle finger to pry the ends of the U out to unclip it.
    Hope that helps.
    ASRDogman likes this.
  13. NutzAboutBolts
    1,698
    1,743
    Bay Area
    I don't think you can, the hoses and one bolt is in the way. Wish it was that easy lol
    Danny3xd () and Mendel Leisk like this.
  14. NutzAboutBolts
    1,698
    1,743
    Bay Area
    Just finished replacing engine wp and thermostat. Will be editing it and posting it in a few days.
  15. NutzAboutBolts
    1,698
    1,743
    Bay Area
    Here you go, hope its helpful. Its been long over due lol.
    johnHRP, adrtho4, Fostel and 5 others like this.
  16. Mendel Leisk
    41,442
    I changed the oil on our ‘10 yesterday, didn’t have time nor inclination to start a trial removal, but that inverter water pump looked very accessible from below. There’s a support bracket, perhaps with that unbolted first.
    I’m kicking myself now, should have given it a try, not disconnecting any coolant lines, just unbolting.
    next year. :)
    Raytheeagle and Fostel like this.
  17. Mendel Leisk
    41,442
    I did ask @NutzAboutBolts about this, and he said there was something impossible to remove from below.
    but hope springs eternal, next time I’m under there I’ll give it a try.
    how to deal with the two bolts coming through the weld-nuts, for starters:
    #457 Mendel Leisk, Apr 6, 2025
  18. ErikSC
    ErikSC New Member
    United States
    2023 Prius
    These videos are very helpful.
  19. Mendel Leisk
    41,442
    Couldn’t stand the suspense: it’s right there, but not possible as far as I can see. Had the three inverter pump bolts out, but it can’t get by the black painted bracket, and the hoses are out of reach. A fiddly little bracket captured by the bolts is hard to align. For the bolt that threads in from above, I hacksawed a slot in the tip, to help spin it down. Not that I’ll need that again lol.
    Purrius and Fostel like this.
  20. rjparker
    rjparker Tu Humilde Sirviente
    10,143
    6,304
    Texas Hill Country
    Accepting lessons from others saves massive time and effort while broadening our knowledge without resorting to the school of hard knocks over and over again.
    Purrius, Mendel Leisk and ASRDogman like this.
