Nutz About Bolts Prius Maintenance Videos
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Tideland Prius, Feb 17, 2016.
  1. Jimi1976
    Jimi1976 Active Member
    242
    124
    Denver, CO
    If you are unfamiliar with this kind of repair, I highly recommend you get a second opinion, from at least one other shop in your area.
  2. sfv41901
    sfv41901 Masta S
    4,591
    5,293
    Palmdale, Ca
    Should take about 2 -3 hrs......4hrs max if ur working slow.
    Just requires the removal of the axle to replace the seal & refill the CVT.
    iPhone ?
  3. PaulD
    PaulD Member
    53
    45
    Hillsboro, OR
    I've now done the engine oil and filter, engine & inverter coolant and HV battery fan cleaning with the videos. Top notch guys!
    Next is the spark plugs, but I'm going to wait a little longer since I've only got 92k miles on the car.
  4. Mendel Leisk
    42,119
    The only thing with the spark plugs is you will really start to hate the Toyota engineers. :)
    Robert Holt likes this.
  5. NutzAboutBolts
    NutzAboutBolts Senior Member
    1,753
    1,781
    Bay Area
    its not bad... took me 1 hr to finish from start to end with electric tools.
  6. Spindifferent
    Spindifferent Member
    155
    79
    Central Texas
    Wanted to add my thanks to the NAB folks and to ask if there are any plans for a wheel bearing replacement video. I think my 2010 needs a rear wheel bearing replacement.
    Thanks again for the great work!
  7. Mendel Leisk
    42,119
    Just curious: how many miles, are you running higher tire pressures?
    Another thing, do you encounter a lot of speed bumps? I hate those things, take them at dead slow.
    @Danny posting taking multiple tries with 20~30 second delays for each.
  8. Spindifferent
    155
    79
    Central Texas
    Hi Mendel,
    Not sure if you are asking me about the wheel bearing, but I'll respond in case you are: Approx. 79k miles. Yep, run tires in the 40-42 psi range. No encounters with lots of speed bumps, but have encountered some speed bumps for sure over those 79k miles. Oddly, the wheel sound changed after I rotated the tires. I re-rotated the tires and the sound still persists; a sound that graduates in loudness as the speed increases.
  9. Suprius
    Suprius Junior Member
    23
    29
    L.A, C.A
    I noticed I have about the same amount of miles as you and was wondering if you have replaced anything in your suspension yet?
  10. NutzAboutBolts
    1,753
    1,781
    Bay Area
    nope, running clean and strong, haven't had any problems with the car.
  11. Rebound
    Rebound Senior Member
    3,996
    2,645
    Portland, OR
    Sounds like a three hour job for me.
  12. Mendel Leisk
    42,119
    Took me half an hour getting the little black plastic corner of windshield pieces out, or in..., I forget. :oops:
  13. NutzAboutBolts
    1,753
    1,781
    Bay Area
    took me 2 hrs to film, and recently at 114k miles, I just replaced the spark plugs and it took me 1 hr.
    that just means you're getting old :D lol
  14. Rebound
    3,996
    2,645
    Portland, OR
    Wow, this has been fun! Here's what I've done so far on my 95,000 Prius Plug-in:
    1. Oil Change (nine or ten of them)
    2. Transaxle Fluid Change (two)
    3. Inverter Coolant Change
    4. Engine Coolant Change
    5. Brake Pin lube
    6. HV Battery Clean
    7. Throttle Body Clean
    8. MAF Sensor Clean
    9. EGR Pipe Clean
    10. Spark Plug Replacement
    All that leaves me with is the PCV Valve replacement and the dreaded brake fluid flush. Today I did the spark plugs, which was a lot easier than it looked. It took me a long time because I was fastidious about cleaning everything. I have a spotless engine compartment, but in four years of driving, all that stuff beneath the windshield has never been opened up and cleaned. I especially wanted to clean all of the cabin air intake area because I breathe that air. I even reached inside the air intake with my good old Clorox cleaning wipes.
    If you do the spark plug replacement, don't forget to have some dielectric grease for the ignition coils.
    Bay Stater, mrbigh and bisco like this.
  15. NutzAboutBolts
    1,753
    1,781
    Bay Area
    nice, your stats are like mine. The only thing I need to do left are the front and rear brake pads and rotors... which won't be for a while lol. The brake flush is easy for the rear, but for the front, you will need another person to help. :)
    #55 NutzAboutBolts, Aug 29, 2016
  16. Mendel Leisk
    42,119
    A question regarding the brake bleed sequence. I appreciate the rears are much more efficient at pumping out fluid; the assistant can just keep pressing the brake pedal and fluid comes out. But is there then an advantage to doing them first, as opposed to later?.
    I've attached the Repair Manual Section "REPLACE BRAKE FLUID (for not Using the Techstream)" (love the titles...). They specifiy a certain order to bleed the brakes.
    And just to grumble, of course they don't supply a simple pictogram, with the corners of the car numbered one through four. No: they laboriously repeat the procedure, four times (hopefully without zingers...), with identifying terms like "front disc brake cylinder assembly RH". I gather that means "front right". Anyway, the sequence, when you sift through it, is:
    FRONT RIGHT
    FRONT LEFT
    REAR LEFT
    REAR RIGHT
    Torque values for bleed screws:
    Fronts: 6 foot/lbs. (8 mm socket size)
    Rears: 8 foot/lbs. (10 mm socket size)
    Further thought: in the past bleeding brakes, I've always found the manuals specifying a certain bleed sequence. Typically it starts with the corner furthest from the master cylinder. I'm not quite sure of the rational, neither do I understand how the lines branch: do they run back separately, or merge?
    #56 Mendel Leisk, Oct 19, 2016
  17. Raytheeagle
    Raytheeagle Senior Member
    11,267
    15,525
    Bay Area, California
    2019 Prius Prime
    Today was brake pin lubrication day:). Only took a couple of hours for all four sets, stoppping a couple of times in between:(.
    Well worth the time and effort. Below are the pads at 142 k miles (original pads):
    Front pads: IMG_0078.JPG
    Rear pads: IMG_0075.JPG
    I think I have awhile for replacement:).
    Excellent videos @NutzAboutBolts .
  18. Mendel Leisk
    42,119
    That's astounding.
    I know I'm a broken record on this, but did you check that the rears are turning fairly free afterwards?
    Raytheeagle likes this.
  19. Raytheeagle
    11,267
    15,525
    2019 Prius Prime
    Absolutely ;).
    Got good revolution with ease on both sides:).
    I love regen braking:D.
  20. NutzAboutBolts
    1,753
    1,781
    Bay Area
    yup... those pads will last for along time lol. I still haven't done the brake pads and rotors replacement video because I still have life on the pads and rotors... even though its at 130k miles already :( we'll have to wait for a while before we'll have that video up lol.
    Apl420 and Raytheeagle like this.
