Nutz About Bolts Prius Maintenance Videos
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Tideland Prius, Feb 17, 2016.
  1. Mendel Leisk
    41,463
    I did valve clearance checks on Hondas for decades. The first to last was our 91 accord. Always, step one was: remove the valve cover.
    Then came our 06 civic hybrid. Now there's steeply canted windshield and cowl hanging over the engine. Ok, I found a pdf on Block Heater installed that explained the cowl removal, not quite as involved as the Prius, but getting there. Still thwarted: there's a great wiring harness running over the top of the valve cover, and it's not budging. Removed it's fasteners, at the cover and about a foot further in either direction, and the dipstick guide tube.
    All of this was a solid hour and a lot of head scratching. The valve cover came off in about 2 minutes after that.
    Raytheeagle likes this.
  2. Raytheeagle
    Raytheeagle Senior Member
    11,265
    15,520
    Bay Area, California
    2019 Prius Prime
    Patience is a virtue (y).
  3. NutzAboutBolts
    NutzAboutBolts Senior Member
    1,698
    1,745
    Bay Area
    Here's another video.
    RMB, Mendel Leisk, fopoku2k2 and 2 others like this.
  4. Mendel Leisk
    41,463
    ^ Early on, when I was looking into grill blocking, someone mentioned pushing bits of pipe insulation tubing onto the seams along the engine bay sides. That's one area that doesn't have gaskets, allows a lot of air in and out. It might swirl up through the wheel wells and out through those gaps? Not sure.
    Anyway, maybe due in part to leaving those zones with the pipe insulation year 'round, the engine bay on mine has stayed quite clean. I brush dust it once in a while, and then an air blast (leaf blower mostly, or a wet-dry vac, all I've got).
    RMB and NutzAboutBolts like this.
  5. eliteconcept
    eliteconcept 700 mile club, top tank mpg 69.5
    449
    186
    Indiana
    2022 Prius Prime
    sorry for the brake fluid question again. i found these steps https://attachments.priuschat.com/attachment-files/2015/04/74070_Prius_Brake_Bleed_1.pdf
    i have techstream and i feel pretty confident about doing this myself with techstream with the help of my dad who is a bit of a gear head. anyways, my only question remains about this bleeder screw. Is there a part I need to buy to hook up to drain the fluid out, or do i just need appropriately sized vinyl tubing to connect to the part that is already on the car to direct the fluid to a container?
  6. NutzAboutBolts
    1,698
    1,745
    Bay Area
    You can hook up a tube to the bleeder screw to route it to a container. If you don't have one, you can use an open container and open the bleeder screw and let it drip into it. Then just brake clean the fluids from the bleeder screw. Either or is fine, I've done both before :)
  7. eliteconcept
    449
    186
    Indiana
    2022 Prius Prime
    cool so no special tool or adapter needed, just some tubing, necessary wrenches, and an empty container
  8. NutzAboutBolts
    1,698
    1,745
    Bay Area
  9. Mendel Leisk
    41,463
    Techstream is not really needed either, if you follow the instruction to put it in "invalid" mode.
    While a bleed screw adapter is not strictly necessary, it's readily available and makes the connection more secure. I happened to have some with a MightyVac.
    OTOH, I've seen videos where they use a small zip tie, cinched just back of tube end, just tight enough that it stays on when you push it on.
  10. Abu Rais
    Abu Rais Member
    58
    42
    Houston, Texas
    One question regarding radiator coolant refill. On the video you didn't show how to put the car back from Maintenance mode to regular mode?
    Please let me know.
    Thanks
  11. Mendel Leisk
    41,463
    Just turn it off.
    This might be a moot point, if you're considering coolant change just due to EGR cleaning, as I mentioned in the other thread. It's overkill, a liter or two drain of engine coolant is sufficient for that purpose, and pouring it back into the reservoir without any maintenance mode worked for me.
    Having a 2010, I would suggest you open the coolant bleed bolt (white plastic cap, right above EGR), to let air escape when refilling. I have no idea why Toyota would opt to remove the bleed bolt, commencing in 2012, btw. With 2012 model year onward I suppose you could accomplish the same thing by just disconnecting the topmost hose, till coolant starts coming out as you fill.
  12. Abu Rais
    Abu Rais Member
    58
    42
    Houston, Texas
    Coolant bleeding bolt?
    Is it something on the video?
    Sorry for dumb questions but where is the EGR located?(right above EGR)
  13. Raytheeagle
    11,265
    15,520
    2019 Prius Prime
    Because it is not needed;).
    I have bled our 2010 as well as several other Gen3 Prii coolant systems and even though that is the high point in the system, the flow through the system is great enough to overcome a potential air pocket from forming:).
    That’s one valve this glorified plumber won’t need to turn(y).
  14. Mendel Leisk
    41,463
    @NutzAboutBolts has a 2012, which nixes the coolant air bleed bolt, and according to @Raytheeagle it's maybe not strictly necessary. Still, I get a kick out adding coolant and feeling the air rush out of there at the same time, it certainly can't hurt, hastens getting the bubbles out. Again, when refilling, just disconnecting the topmost hose (it feeds into the top of the EGR cooler IIRC) till coolant starts coming out, would do the same thing, if you're 2012 or newer.
    #174 Mendel Leisk, Oct 31, 2017
  15. eunique
    eunique Member
    66
    89
    US
    This is a very informatibe thread. Thanks for all the input
    SM-N935S ?
    NutzAboutBolts and Raytheeagle like this.
  16. NutzAboutBolts
    1,698
    1,745
    Bay Area
    I’m currently in limbo because I’m in the moving process, so I can’t film any Prius video until I get settled in. :(
  17. Raytheeagle
    11,265
    15,520
    2019 Prius Prime
    Staying in the Bay Area at least:whistle:?
  18. NutzAboutBolts
    1,698
    1,745
    Bay Area
    Dublin considered Bay Area? Lol
  19. Raytheeagle
    11,265
    15,520
    2019 Prius Prime
    East Bay and closer to a lot of us on here:)!
    Maybe you’ll make one of our meet ups:whistle:....
  20. NutzAboutBolts
    1,698
    1,745
    Bay Area
    Lol wife said strictly online only :(
