Nw LRR tires but they set to 35 psi?
Discussion in 'Gen 3 Prius Main Forum' started by Jim Caldwell, Sep 14, 2019.
  1. William Redoubt
    William Redoubt Senior Member
    1,228
    1,172
    Coronado Island, California
    I run my tires at 40. Difference between 35 and 40 psi is 6 miles per gallon. I have tested it many times.
    Robert Holt and Grit like this.
  2. William Redoubt
    1,228
    1,172
    I have been shorting Tesla and Diminishing Returns for years and making a boat load.
    Grit likes this.
  3. William Redoubt
    1,228
    1,172
    I am so sick of this type of comment. Anecdotes are VERY MEANINGFUL. In fact, every court in the world recognizes them per the well-known attorney Lionel Hutz: "While anecdotes, hearsay and conjecture may not be the best evidence, they are kinds of evidence." Just take a minute and look up Mr. Hutz's credentials.
    No study proves anything 100 percent. But an anecdote? By itself, taken alone with out other testing or sampling, is 100 percent accurate. And, when enhanced by smoking LEGAL CANNABIS (in the west-coast sun), is over 100-percent accurate.
    Take that Boston-boy! :)
    Ed Beaty and bisco like this.
  4. lenjack
    lenjack Active Member
    804
    114
    Pennsylvania USA
    Carmakers recommendation is for softer, more comfy ride. Upping it 3 to 5 pounds will give you better mileage, AND better handling, while the hardening of the ride will be barely noticeable. I have not found this to cause added tire wear.
    Threej likes this.
  5. Mendel Leisk
    41,431
    Walk yurself down to Pep Boys or whoever, get a $5 tread depth gauge. (y)
  6. fuzzy1
    10,446
    Even once a month was too fast. That sounds more like a small bead or valve leak, than permeation through the rubber, so all-nitrogen won't help.
    Comfort is very clearly a factor, and is likely why numerous previous-century cars had too-low pressure recommendations. E.g. my household's Honda and Acura suffered premature edge wear and hydroplaning until I upped the pressures. And the infamous Ford Explorer / Firestone rollovers, which killed a lot of people, which caused in part (along with a half dozen other problems) by a too-low manufacturer pressure recommendation.
    But I'm betting that upping the pressure 3-5 pounds will be more that 'barely noticeable' by numerous drivers and riders. While fine for me, a fair number of others won't like it.
    #66 fuzzy1, Sep 29, 2019
  7. fuzzy1
    10,446
    Many have done so or similar. Search around, here are just a few examples.
    NHTSA:
    A university engineering department:
    An engineering calculator source:
    A bicycle-specific test:
    CR94 and Robert Holt like this.
  8. bisco
    51,906
    sorry, i meant prius specific with LRR tires
  9. NewHybridOwner
    NewHybridOwner Active Member
    607
    283
    W. Michigan
    If the factory-installed tires were LRR (were they on yours?), wouldn't the specified 35psi on the label be for LRR tires rather than for "regular" tires?
  10. CR94
    CR94 Senior Member
    2,692
    1,173
    Northwestern S.C.
    You can be certain Toyota (among others) tested that too.
  11. bisco
    51,906
    no doubt
