o2 sensor for p0420 error code
Discussion in 'Gen 2 Prius Main Forum' started by Prius2006GuitarGuy, Apr 22, 2025.
  1. dolj
    dolj Senior Member
    8,655
    4,406
    Wellington, New Zealand
    The Autel AP200 you have should have the necessary capability.
    Here is the excerpt of the repair manual for the C2300 error that was not attached.
  2. MAX2
    MAX2 Senior Member
    1,436
    490
    101
    Third planet from the Sun
    I can't say about Autel whether it has the whole complex. The original Techstream program, which allows you to diagnose and check systems, write data to files. Try reading various ECU parameters and creating reports. If something doesn't work, ask for advice on the forum.
  3. Prius2006GuitarGuy
    Prius2006GuitarGuy Junior Member
    Sweden
    Thanks, will watch some tuts on youtube to see how to do it.
    Thanks, will check out "techstream" when I get some time off. Feel free to post any links or tuts if you feel it woudl help my journey.
