O2 sensor needs to be fixed
Discussion in 'Gen 2 Prius Main Forum' started by Dwight Schrute, Sep 28, 2015.
Tags:
  1. Dwight Schrute
    Dwight Schrute New Member
    27
    Scranton, Pennsylvania
    Title says it all. I bought a 2008 prius with 83k on it this weekend. I bought it knowing about the O2 sensor. Has anyone replaced this themselves? Because the guy who I bought it from, was very honest with me, and told me he was quoted at the dealer 300 or 500 to fix it ( I don't remember what he said! it was one of those numbers, either way, 300 is still a lot). I'd like to replace this myself, and from what I understand, my fuel economy is all thats being affected, right? I am still getting like 43 mpg.
  2. valde3
    valde3 Senior Member
    2,002
    745
    Finland
    What’s the fault code? Do you mean front or rear o2 sensor? Front sensor is actually air fuel ratio sensor and it’s in hard spot to remove. Rear sensor is easier.
  3. cyclopathic
    cyclopathic Senior Member
    3,292
    547
    2014 Prius c
    If it is rear it is a converter issue
  4. E Risch
    E Risch Junior Member
    49
    Nashville
    Downstream is like 10 minutes to R/R about $56 on my '04 (only buy Denso)
    Dwight Schrute likes this.
  5. Dwight Schrute
    27
    I think its the front. I will have to double check.. Im like 99% positive its the front
  6. Dwight Schrute
    27
    I am pretty sure its the front
  7. cyclopathic
    3,292
    547
    2014 Prius c
    If it is front clean connector. Does it burn oil? If it does this may be the root cause.
  8. Dwight Schrute
    27
    I am not aware that it burns oil if it does. Previous owner never mentioned it, but I will look out for that. thanks.
