OBD-II Job Opportunity
Discussion in 'Prius OBDII Third-Party Apps' started by Hyeratic, Mar 14, 2014.
  1. Hyeratic
    Hyeratic New Member
    i'm Andrea Giuggioli and i'm technical manager of an Italy based software house. We develop mainly Retail software and Profiling software.
    We're now starting to develop a very interesting solution wich involves the OBD-II, so we need someone who is able to help us in the development and we would understand if there is one developer open to a job collaboration with us.
    I think that the collaboration could be very profitable for you, because the solution is very big and could be a long term parthership.
    Best Regards
    Andrea Giuggioli
  2. ccdisce
    ccdisce Active Member
    259
    187
    Stone Mtn GA USA
    Andrea,
    I am not sure what you need, If you need hardware help and can be of assistance there as I have been working and tinkering on the various versions of the Hardware to interface to the OBD2 Port that are in use.
    The latest design of the OBD2 interface that I am working on uses a Scantool STN1170 Chip which is capable of driving HS-CAN, MS-CAN, SW-CAN, KWP2000, and the legacy PWM/VPW .
    It will interface to a Laptop using virtual com port USB2 at 2Mb/sec which is necessary to run virtual Dashboards at a resonable refresh rate.
    Winston.
    Hyeratic likes this.
    49,519
    is this a work around from nigeria?:whistle:
    lensovet likes this.
