Obd location RHD
Discussion in 'Generation 1 Prius Discussion' started by Ant2, Oct 12, 2020.
  1. Ant2
    Ant2 New Member
    Nz
    2002 Prius
    Hi anyone can help on the location ? Do you need to remove panels
  2. Josey
    Josey Active Member
    305
    117
    Virginia
    2003 Prius
    No need to remove anything. It's to the right of the hood release lever. You can't see it unless you stick your head down under the dash. tho. Have to feel for it.
  3. dolj
    dolj Senior Member
    8,603
    4,365
    Wellington, New Zealand
    Correct, relative to the steering column, it is in the same place regardless of whether it is a RHD or a LHD. However, on a RHD, the hood release lever is right over on the RHS near the door, so the OBDII port is quite a way left of the hood release.
    As Josey said, 'You can't see it unless you stick your head down under the dash. tho. Have to feel for it.', but if you do stick your head down under the dash you will see it easy enough.
  4. Josey
    Josey Active Member
    305
    117
    Virginia
    2003 Prius
    Oh, shoot. I missed the RHD reference. So, yeah. In this case the the left of the hood release. (Who ever decided to put the steering wheel on the wrong side of the car, anyway?
