OBD Reader
Discussion in 'Gen 2 Prius Main Forum' started by orlandocfa, Jul 12, 2017.
  1. orlandocfa
    orlandocfa Junior Member
    San Tan Valley, Az
    It was recommended that I take a look at the OBDLink LX but they are only compatable with Android and I have an Iphone. The MX Wifi Model is a bit out of budget. Does anyone have any other OBD2 readers they would recommend that would work with an Iphone?
  2. dolj
    dolj Senior Member
    8,553
    4,344
    Wellington, New Zealand
    In order to use a smartphone, you first need to get a reliable (and fast) OBDII dongle. To get a good one, you have to spend the money.
    Have a look on the EngineLink app (it's an iOS app) website, I believe they recommend dongles that work well with their app.
    Good luck in your quest.
    #2 dolj, Jul 12, 2017
  3. marlinsmobile
    marlinsmobile Active Member
    106
    131
    Sandy Springs (Atlanta), GA
    I have this one, which is a cheap ELM327 knock-off. It was affordable and has worked well for me, but YMMV!
    I've used it to log about 95% of my trips in my gen 3 using the EngineLink app on iOS.
    Here are some additional threads on OBDII apps for iOS: OBDII iPhone App | PriusChat
  4. 05PreeUs
    05PreeUs Senior Member
    1,097
    565
    MSP
    I too have an ELM327 Wi-Fi and have two apps for iOS: "FourStroke" and "FORSCAN". Forscan is specifically for Ford products, while FourStroke is all makes. Neither will do jack with codes for a Toyota HSD system :(
