OBD Splitter
Discussion in 'Gen 3 Prius Accessories and Modifications' started by AzusaPrius, Apr 15, 2024.
  1. AzusaPrius
    AzusaPrius Senior Member
    2,254
    942
    Took some searching to find the right one.
    This will keep my UltraGauge constantly ready and the other side has a power switch to turn off my Carista when I am not monitoring other things. 20240415_181249.jpeg
  2. black_jmyntrn
    black_jmyntrn Senior Member
    1,729
    410
    2013 Prius Plug-in
    ohhhh link please!!! lmao.. I made my own lol I do like that switch feature. I went this route because I have a custom programmed pcb board so I can do things like the the a jumper between pin 4 (CG pin) and pin 13 ( TC pin) on the OBD2 connector trick from command line or web gui soo easily. soon techstream wirelessly! ABS and all!
    I was going to make a manual switch to do it but I thought it was cooler knowing I can do all that wirelessly. :)
    https://black.jmyntrn.com/2024/04/15/unlocking-advanced-vehicle-diagnostics-enhancing-your-prius-with-a-custom-obd2-setup/?utm_source=PriusChat&utm_medium=weblinkt&utm_campaign=commentlinkApril
    Blackhawk5 likes this.
