OBD2 Splitter- Is It Safe? & Does It Work?
Discussion in 'Gen 3 Prius Accessories and Modifications' started by Xterra72, Sep 3, 2020.
  1. Xterra72
    Xterra72 Senior Member
    1,437
    1,684
    Have Scangauge installed now but the hardwire kit for a dashcam in my case also uses the obd2 .
    looked into the OBD2 Splitter and found a few.
    Trying this one out for now:
    https://www.amazon.com/dp/B071L8W7Q7/ref=cm_sw_r_sms_api_i_VYyuFbN0K04YD
    I was wondering if anyone has used one with any success.
    Any thoughts on reliability and how safe it is to use in your car.
    Any thoughts or experiences are greatly appreciated.
  2. apt5020
    apt5020 Senior Member
    881
    1,294
    Prius City, CA
    I have a splitter for my Scangauge. Only issue if you do connect Techstream it doesn't like it. So you would have to disconnect the splitter and direct connect to OBD2. Not a big deal. Hope that help
    Xterra72 likes this.
  3. Xterra72
    1,437
    1,684
    Which obd2 splitter do you have? Happen to have a link?
  4. apt5020
    881
    1,294
    Prius City, CA
  5. DimitrisTS
    DimitrisTS Member
    30
    49
    Thessaloniki
    I also have a splitter for a couple of years now. I have simultaneously connected an obdlink lx and also a window auto-close module.
    No problems.
  6. Xterra72
    1,437
    1,684
    Which one do you have? Link?
  7. hotelprisoner
    hotelprisoner Member
    104
    87
    Ontario, Canada
    Technology
    Anyone get a ScanGauge and Techstream to play nice together with one of these? My splitter would not do this and my research says they can’t but that was awhile back.
  8. PriusCamper
    PriusCamper Senior Member
    13,357
    5,398
    Pacific Northwest, USA
    In general always having something plugged into your OBD2 is problematic and having two things always plugged in will be doubly problematic. Most people who have their OBD2 port in use all the time do pretty well for a while and then as everything ages they start getting errors and warning lights.
    In other words, it's a diagnostic port, not an accessory port. It's to be used when you're doing diagnostics rather than for adding new features to the vehicle.
    I'd recommend getting a $5 OBD2 cord with a switch on it so you can turn it on when you want to look at available data.
