obd2 & Torque issues
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by Jumpjet, Jan 30, 2013.
  1. Jumpjet
    Jumpjet Member
    77
    25
    I have a dedicated android phone with Torque running automatically whenever I start the car. I leave my Bluetooth obd2 scanner always plugged in. I noticed by doing that, my clock runs 3min slow every morning so it looses 3min overnight, everynight. So I unplugged my obd2 scanner and so far the clock is back to normal. Has anyone else running that scanner or Scanguage noticed that? I wonder what other problems it causes by leaving it plugged in. Now I stopped using it in fear of causing other issues.
  2. PriusCamper
    PriusCamper Senior Member
    13,343
    5,395
    Pacific Northwest, USA
    I've read on here about it causing delays/confusion if OB2 is plugged in when the car boots up / goes into ready mode. Something about the OBD2 interfering with Prius system scan to make sure all the electronics are up and running. Perhaps you could figure out a way to put a switch in the system and set it up so it doesn't get turned on till after the vehicle is up and running?
  3. usbseawolf2000
    usbseawolf2000 HSD PhD
    14,487
    3,001
    Fort Lee, NJ
    The issue I have seen posted was due to the protocol auto detect.
    To resolve it, go to Vehicle Profile and set it to CAN 11 bit 500 baud. It will also speed up the process.
    F8L, mrbigh, lensovet and 2 others like this.
  4. mrbigh
    3,686
    699
    Long Island, NY
    nice to know, thanks
  5. Jumpjet
    Jumpjet Member
    77
    25
    [quotesbseawolf2000, post: 1731812, member: 2754"]The issue I have seen posted was due to the protocol auto detect.
    To resolve it, go to Vehicle Profile and set it to CAN 11 bit 500 baud. It will also speed up the process.[/quote]
    Okay i'll given it a try, thanks
    PriusCamper likes this.
  6. john1701a
    john1701a Prius Guru
    12,840
    5,312
    58
    So far, so good with me. Though, I did find it disturbing when I plugged in my BT adapter for the first time and connected to the Torque app, my reverse beep came back. How could that have happened without actually issuing the command? For that matter, I haven't even brought that display to the dashboard.
    Anywho, I've been toying with the app itself, the layout, and the downloaded data. It takes awhile to get a feel for it all... especially when comparing differences between Android versions and screen resolutions.
    I just got an ODB splitter yesterday. So, now I have both my ScanGauge and Torque available at the same time. That setup is working well too. I was a bit worried about having so much cabling to deal with. Turns out, all that can be secured tight and tucked in without getting in the way of anything. Phew!
    Thanks to all the advice those have shared so far. That's been really helpful.
  7. Electric Charge
    Electric Charge Active Member
    545
    133
    Syracuse, NY
    Where did you get the splitter?
    As for the beep, just previewing the settings used to trigger these settings, but this was recently addressed in the latest pid list.
  8. Jumpjet
    Jumpjet Member
    77
    25
    It appears that when you add a new display to torque, it refreshes all the values by sending the commands to get the results including the reverse beep and seat belt. What I did to solve that problem was to add the reverse beep off display and the seat belt off display to the main screen and put it in the background. So it always shuts off even when I go to add another display.
  9. Jumpjet
    Jumpjet Member
    77
    25
    When you say addressed, do you mean that it's known or that it's solved? Do you have the link to the latest PID list?
  10. usbseawolf2000
    14,487
    3,001
    Fort Lee, NJ
    Which OBDII dongle did you get?
    When you browse the list to pick, Torque actually sends the command to display the data as you scroll. A cool feature but the PIDs that changes the configuration got sent as well.
    For that reason, I have separated out those config PIDs into different csv file.
    lensovet likes this.
  11. john1701a
    12,840
    5,312
    58
    OBDII Splitter Y Cable, J1962M to 2-J1962F, 1ft (145802) : Amazon.com : Automotive
    Yup. And I wondered if that would do it, as I was scrolling to watch each of the values fill in.
  12. john1701a
    12,840
    5,312
    58
    I discovered a new issue tonight:
    DON'T LEAVE THE APP CONNECTED TO THE PRIUS WHEN YOU POWER OFF THEN POWER BACK ON!
    I was just going to run into the house for a few quick things. Why bother shutting off or disconnecting the phone? It became obviously about 100 feet from my house. Warning lights starting illuminating and the screen displayed a "CHECK PCS SYSTEM" message. Needless to say, I quickly figured out what had happening. And yes, I took the extra step to confirm my theory. Powering off then on again brought back the same condition.
    Powering off again, killing the phone, then powering on again, all returned to normal. Phew!
    Tracksyde likes this.
  13. Jumpjet
    Jumpjet Member
    77
    25
    Yep, I noticed the same thing. My problem is with the clock slowing way down and losing 3min per night. Selecting the 11 bit/500 baud didn't help. So I have to close torque when shutting down car or turning off the Bluetooth. I have it to automatically turn off Bluetooth when power is lost so I can get around that issue.
  14. Want A Hybrid
    Want A Hybrid New Member
    so you narrowed that down to Torque as opposed to the OBD2 scanner? I read on Amazon that the "cheap" scanner do sometimes weird things whereas the primo ones behave much better...?
    For those who have issues, what scanner are you using?
    I am using a Kiwi Bluetooth and never had any of these issues, but again I have a TCH 2012.
  15. Want A Hybrid
    Confirmed from my side as well on TCH 2012: When I leave Torque running and I power off and on again the engine, I have weird stuff happening, last time I had the airbag light and another one that were on.
    Switching off the car, the application then starting on the car then switching on the application fixed it all.
  16. usbseawolf2000
    14,487
    3,001
    Fort Lee, NJ
    Someone should report this "bug" to Torque app author on their forum. Ian is quick to fix things.
  17. Francos
    Francos Member
    118
    Can someone share some screenshots of the Torque app? Especially features related to PIP.
  18. usbseawolf2000
    14,487
    3,001
    Fort Lee, NJ
    This is my setup. For a full list of available PIDs, go here.
    Francos likes this.
  19. Mobalized
    Mobalized Member
    98
    27
    Anyone have any issues with the adapter draining battery?
  20. Lourun
    Lourun Member
    289
    35
    Glen Rock NJ
    2013 Prius Plug-in
    Not yet, have it in my pip for about 2 weeks running, all the time, no issue yet!
