OBDII Scanner for Apple?
Discussion in 'Gen 3 Prius Main Forum' started by Borninblue, Feb 9, 2019.
  1. Borninblue
    Borninblue Active Member
    233
    158
    Cleveland, Ohio
    I would love to purchase a scanner that is compatible with my IPhone X, is there such a thing?
    I don’t have access to a laptop but do have a PC. If there is not one compatible with my IPhone is there anything out that will work with Wifi?
    I mainly want to check the health of the battery and if and when I throw a code, thanks!
  2. Borninblue
    233
    158
    Cleveland, Ohio
  3. JimboPalmer
    12,470
    6,879
    Greenwood MS USA
    My equipment is all Android, I use torque pro
    Bay Stater and Borninblue like this.
  4. Borninblue
    233
    158
    Cleveland, Ohio
    Thanks, does that give you traction battery diagnostics/health?
  5. RRxing
    RRxing Senior Member
    2,564
    1,842
    NEPA
    I use Carista. Changes settings (e.g. that awful reverse beep),can display tire pressures (although you'll have to figure out which TPMS sensor is for what tire), shows/clears codes, etc.
    Borninblue likes this.
  6. Borninblue
    233
    158
    Cleveland, Ohio
    Thank you! I want to get rid of that damn beeping. Does it display the traction and 12v battery health?
