OBDII Scanner that can read sub-codes
Discussion in 'Gen 2 Prius Main Forum' started by qmanqman, Aug 16, 2025.
  1. qmanqman
    qmanqman Active Member
    444
    153
    CO
    Recently got the P0AA6 code. Watched a youtube video that says you need to get the sub codes.
    I have a cheapo OBDII scanner ($22) and the Veepeak bluetooth scanner ($32) for the Dr. Prius app and neither read subcodes. What do you guys use for subcodes that isn't $500?
    #1 qmanqman, Aug 16, 2025
  2. Brian1954
    Brian1954 Senior Member
    2,679
    1,071
    South Central PA, USA
    I use a hacked version of Techstream and also the Autel AP200. There are also many other scanners that will give you the sub-code of a trouble code.
  3. Tombukt2
    Tombukt2 Senior Member
    13,860
    2,519
    Durham NC
    Oh the hybrid isolation code first thing use cheapo scanner and clear codes twice back to back . Will the car ready now? Drive it stay close if you're driving okay and then codes . Get out unplug sc comPressor. You're driving in the code hasn't come back cool. Plug the air back up does the car code again if so you isolated to the AC that's one of the subs . The other main one is in HV case open up case look at inside bottom tray see the discoloration? That's battery acid leaking out of modules putting voltage to the battery tray which is secured to your chassis ground which is your 12-volt ground point so you're sending 75 DC volts to your 12 DC volt ground point not cool car doesn't like it that's why everything red won't start the last sub deals with orange wiring between HV batt and back of inverter rare..
  4. Tombukt2
    13,860
    2,519
    Durham NC
    There's a guy named Scott floating around here who has the whole manual available online I suggest look into it you have the big bucks for the 5 manual set at 300 plus dollars .
  5. qmanqman
    444
    153
    CO
    So get this. I cleared the code maybe 5-10 times. I'd clear it to start it, it would run for a few minutes and the code would come back. Couldn't figure out what scanner could to buy that would read sub codes (even contacted some manufacturers and they couldn't tell me). Set up an appt with my trusted mechanic and now the code won't come back. It gets driven 10 miles each way to work every day and is driving like it always has. Can a Prius cure itself of a P0AA6?
    FYI the other code that I had to fix when the red triangle reared its ugly head had to do with the inverter pump. I did replace the inverter pump. Is it possible the bad pump caused the problem? The P0420 is constantly on so we're not sure how long the inverter pump code had been on.
    #5 qmanqman, Aug 28, 2025
  6. Tombukt2
    13,860
    2,519
    Durham NC
    No it cannot it can be under threshold I guess . But a meter tells ya pretty quick . Google down and dirty test battery isolation fault Prius watch what he does with meter . You will do same . And probably find fault . Then you won't have to really worry about codes you need fix that first.
  7. qmanqman
    444
    153
    CO
    Well I don't have a scanner that reads the INF codes which is why I started this thread in the first place. If the inverter pump had stopped working could the inverter have over heated and kicked out the P0AA6?
    #7 qmanqman, Aug 28, 2025
  8. Brian1954
    2,679
    1,071
    It is very unlikely for an inverter cooling pump failure to cause the P0AA6 code.
    I recommend the Autel AP200 to read the trouble codes and INF codes. The scanner costs about $60 on Amazon. Read post #37 in this thread for more information about some scanners that were evaluated for functionally with a Gen 2 Prius. https://priuschat.com/index.php?posts/3290690
  9. qmanqman
    444
    153
    CO
    Thanks pal
  10. Tombukt2
    13,860
    2,519
    Durham NC
    Just try what I said . Test for leakage. W Dvom just takes a second.
  11. qmanqman
    444
    153
    CO
    Well, the code seems to have gone away. I've been driving it for the last two weeks with no issues. Only thing we did was replace that coolant flow control valve.
  12. Brian1954
    2,679
    1,071
    The code will eventually return. Just keep driving the car.
  13. qmanqman
    444
    153
    CO
    I hear ya. I've been saying that the last two weeks. I'm starting to say it with less and less volume as time goes on.
  14. qmanqman
    444
    153
    CO
    Thanks pal. I googled "down and dirty test battery isolation fault Prius". Didn't find anything with that title but came up with a bunch of videos about taking out the large battery and looking for leaking cels. Since I'm no longer getting the code I'm gonna not do that one just yet.
  15. Tombukt2
    13,860
    2,519
    Durham NC
    You just take the orange plug out pull the cover that exposes the fuse in the orange plug put the orange plug back in but don't slam it all the way down home . No test between a screw holding fuse in plug and ground see the voltage on meter it ain't dposed to be they're at all. So the HV is not isolated bad
