OBIHL4 Homelink Dimming Mirror for 2017 Prius 2
Discussion in 'Gen 4 Prius Main Forum' started by LamPrius, Aug 18, 2021.
  1. LamPrius
    LamPrius Junior Member
    Just got a used OBIHL4 Homelink Mirror for 2017 Prius 2.
    It have 10 pins in a dual row of 5
    The wire pin out as follow:
    1 Switch12+ for Diming function
    2 GND for Pin 1
    3 Not used
    4 Not used
    5 GND for Homelink function
    6 12+ ON for Homelink function.
    Dim function consump approximately 250mA max and steady at 140mA
    Homelink consump a pulse of 50mA
    Next step determine power from overhead console of the Prius.
    if any need to know how to remove the overhead console, let me know.
    Storming777 likes this.
  2. hill
    8,158
    By power, do you mean voltage?
  3. Colorado Boo
    Colorado Boo Active Member
    307
    202
    Monument, Colorado USA
    2021 Prius
    LE AWD-e
    The plastic box attached to the windshield that also has the mirror just snaps off...you gently squeeze and pull down on the bottom piece and you may have to also pull up a little on the top piece...it's a little unnerving how easy it comes apart! I saw good access to wires in there so splicing in for power and ground shouldn't be hard.
    I've been looking at replacing the rearview mirrors on both our Prius' with the Gentex Auto Dimming which is only $67 on Amazon.
