Observation while passing
Discussion in 'Prius v Technical Discussion' started by Aaron Vitolins, Sep 30, 2016.
  1. Aaron Vitolins
    Aaron Vitolins Senior Member
    1,612
    1,144
    Franklin TN
    First of all, yes I have the v wagon and not the liftback.. I know! Same powertrain, this is the more popping section of the forum though!
    So today I passed a car on a country road, wide open throttle from 42 MPH to about 65 MPH (in PWR mode of couse!) the thing I noticed was after I was passed the other car and I started letting up on the accelerator, I felt an even stronger surge of power. Like it was actually faster for a little bit as i let off the accelerator! I believe my 2012 liftback did something similar.
    Why is this? Is this because the engine makes peak tourqe around 4200 rpm? (That's what I think i heard once) forgive if I'm wrong!
    I would think with HSD you wouldn't necessarily feel the affects of the torque curve. I know for a fact gen 2 never did anything like this.
    Educate me! Thanks, you Guys and Gals on PC are the best!
    -Aaron
    Whiteyprius likes this.
  2. AzWxGuy
    AzWxGuy Weather Guy
    1,076
    553
    Tucson, AZ
    2021 Prius
    I'll take a guess. That's all it is though. If this were a carbureted engine I would suspect a vacuum leak or a loose or worn spindle on the carburetor throttle plate(s). I guess the real question is, was there actual acceleration or was this just perception. Flat terrain on your country road? Grabbing at straws here.
  3. Aaron Vitolins
    1,612
    1,144
    Franklin TN
    It was flat, maybe a little uphill actually. But yeah it honestly feel ever so slightly like a carbureted engine
  4. WolfpackBill
    WolfpackBill Senior Member
    349
    500
    Lexington, NC
    I think that's the CVT talking. It s a characteristic of a CVT where there's a second delay in response when you push the gas pedal and there's also a second delay when you let off the gas pedal. I've noticed that when I test drove a Subaru Outback with a CVT a while back.
  5. Aaron Vitolins
    1,612
    1,144
    Franklin TN
    No because I was holding it down for a good 7 seconds while passing. And the Prius doesn't have a CVT like other cars. No belts, cones or pulleys. It's A Ecvt
    Redpoint5 likes this.
  6. glutaman
    glutaman Member
    73
    26
    Dublin, Ireland
    The eCVT works by combining ICE, MG1, and MG2 spins - awesome representation here: http://eahart.com/prius/psd
    Off the top of my head now - if you lifted your foot enough to turn the ICE off, the MGs would have to change their spin speeds to regulate the change and that could have caused the power surge.
    In another situation that I've noticed in my car, there's a small loss of power when the ICE is kicking-in but it's power is only marginally needed. I guess the MGs are playing around a bit to find the sweet spot :)
    #6 glutaman, Oct 11, 2016
    Emad likes this.
  7. Redpoint5
    Redpoint5 Senior Member
    1,026
    509
    Portland, OR
    I'll take this opportunity to remind everyone that power mode doesn't affect wide open power. You can pass just as quickly in eco mode as power when mashing the throttle.
    Power mode simply makes throttle response more aggressive at partial throttle positions.
    broncobilly_69 and Mendel Leisk like this.
  8. bat4255
    bat4255 2017 Prius v #2 and 2008 Gen II #2
    670
    269
    Dodge Co. Wisconsin
    2017 Prius v wagon
    I have a Burgman 650 motorcycle/scooter, it to has a CVT and yes, it does the same thing. After a while you anticipate for it, and I look forward to it.
  9. Tiffany Melendez
    Tiffany Melendez New Member
    US
    2012 Prius+ MPV
    Good observation.
