Observed cold weather MPG difference
Discussion in 'Prius v Fuel Economy' started by Aran, Nov 7, 2013.
  1. LlF
    LlF Junior Member
    42
    Canada QC
    http://i.imgur.com/dHtTpJy.jpg
    This is highway driving with winter tires on bare road at 109km/h, at -26c, with octane free gas.
    I later speed to 125km/h but the consumption seems the same.
  2. Tony D
    Tony D Active Member
    468
    132
    Dublin, Ireland
    Where in hell is it -26oC?
  3. Stevevee
    Stevevee Active Member
    821
    224
    Vermont
    -26 C Not too bad. We're at -12 F now, and it's just starting to get cold ;)
  4. LlF
    LlF Junior Member
    42
    Canada QC
    Im in canada. in gaspe it is even lower, -44c.
    at -30c/-22f , the suspension is all stiff, the steering is heavier, even the gear shift won't spring back as easily...
    I read in the manual that when the temp is cold I should wait for the READY light to stay on before driving off, surprisingly that light only flashed like 2 seconds, but it was no way ready to drive at that moment...
  5. jdk2
    jdk2 Active Member
    751
    220
    Raleigh, NC
    2013 Prius Plug-in
    Better you than me :)
    Off topic, but years ago we went around the Gaspe Peninsula. What a beautiful place that was.
  6. Aran
    Aran New Member
    24
    2013 Prius v wagon
    And have you guys noticed any increase in the margin of disparity between computer and calculated MPG as temperatures dip? In my ignorant mind, the computer should understand the additional taxation of colder temps. With this polar vortex thingamabob, for my last tank the computer showed something like 42.5 while the calculated MPG was 38.4. This was the widest margin to date.
  7. Maine Pilot
    Maine Pilot Senior Member
    166
    504
    Saco, Maine
    I'm surprised no one has mentioned "winter" gasoline. Most, if not all, gasoline blends are reformulated for cold weather driving. As a result, gas-powered engines are easier to start in cold weather, but at the expense of MPG, due to the BTU's available in winter gasoline. Perhaps, one of the engineers on this thread could explain this in a more scientific way.
    Another factor is the Prius' engine has to run more often to deliver cabin heat.
    Still, another reason for lower MPG, is air density. The ideal fuel/air mixture on a "standard" day, (at sea level 59*F/15*C), is around 15 parts air to 1 part fuel. Air is much denser with cold temperatures; i.e., more air molecules. Therefore, to produce the most efficient air/fuel mixture, the amount of fuel has to be increased in order to maintain that 15/1 air-fuel ratio. This is accomplished by the fuel injection computer. Hence, lower MPG.
    john1701a and Aran like this.
  8. john1701a
    john1701a Prius Guru
    12,818
    5,303
    58
    That fact has been beaten to death over the past 13 years of Prius ownership... making it easy to not notice it missing in 1 of the 100's of threads all on the same topic.
