Obvious + Slowly discovered consequences of 12 V battery disconnect
Discussion in 'Gen 2 Prius Main Forum' started by NoMoShocks, Mar 11, 2008.
  1. NoMoShocks
    NoMoShocks Electrical Engineer
    1,292
    81
    Camas, WA
    When I did my Daylight Running Lights conversion for my Fog Lights to allow them to operate by themselves without the main headlights on, I avoided disconnecting the 12 V Aux Battery to avoid the obvious resets involved:
    1. Loss of Radio Presets
    2. Loss of clock setting
    Even though I know best practice is to always diconnect the battery whenever working on the electrical system, I am used to working circuits that are hot as an electrical engineer. But, I did seriously question the widom of my decision as I was pulling connectors from the steering column and suddently realized that the bright yellow connector I pulled without even thinking was probably part of the Airbag system. Un unexpected airbag deployment would have been dissapointing to say the least.
    In the end, my missguided attempts at avoiding having to reset the radio presets and clock was in vain since I had to pull most of the connectors out of the main computer, which ended up having the same effect.
    But, the intent of my post is to consider and discuss some less obvious consequences of a battery disconnect.
    Not Anticipated, but dicovered within 1 day:
    3. Backup Beep was reset to on - YUK! and I had to look up the obscure procedure for turning it off again, which did not seem to work exactly as described, so I had to try it three times, and I never did think I ever got it right, but then I noticed the Backup Beep was off so OK then, all's well the ends well.
    Not anticipated nor obvious and not discovered for over 1 Week:
    4. Wife and I decided to buy a Pizza, and I thought I would seize the opportunity to show her how easy it would be to look up the phone number on the NAV system and then use BlueTooth connection to dial and call in our order directly from the NAV POI Info screen. Unfortunately, the clossest Pizza resteraunt to Vancouver, WA is in Virginia. I am sure it was a nice place, but the Prius is not that economical to drive. Apparently a battery disconnect also sets a random region in the NAV system.
    Anyone else find any other setting that get dropped when the battery is disconnected, post them here.
  2. Patrick Wong
    18,199
    6,464
    5. Driver's side window auto function must be reset. Lower the window halfway, then close the window and hold the switch for a couple of seconds after the window is closed.
    6. Trip odometers are reset
    (Depending upon model year...)
    7. MFD average MPG and odometer may (or may not) be reset
    8. MFD MPG calculation takes into account accumulated history; may be upset by power loss
    (Classic only)
    9. On my 2001, the hybrid vehicle ECU occasionally got confused where the engine wanted to run but MG1 would not spin, so the engine lugged and felt like it was going to stall. Think of a manual transmission vehicle where the engine is idling and you let the clutch out with your left foot while holding the car stationary by pressing on the brake pedal with your right foot. By disconnecting 12V power then reconnecting, that weirdness seemed to go away.
  3. dogfriend
    7,512
    1,185
    Carmichael, CA
    I have disconnected the 12V battery twice. Each time, it took a couple of tankfuls at lower mpg before the mileage returned to previous average. Similar to the improvement I saw with the first 3 or 4 tanks when I first bought the car. Apparently, the ECU has to relearn some parameters that affect the FE.
  4. Patrick Wong
    18,199
    6,464
    Hi Jason,
    Did you notice a drop in displayed mpg per MFD, actual mpg (based upon odometer readings & # of gallons purchased), or both?
    I understand the displayed mpg algorithm is complex and requires learning. However that doesn't necessarily impact actual mpg.
    Some have said the hybrid vehicle ECU goes through a learning process, but if true this is an undocumented feature...
  5. dogfriend
    7,512
    1,185
    Carmichael, CA
    Hi Patrick,
    Although I didn't go back through my gas receipts to verify, it appeared to be both - the MFD mpg was lower and I drove less miles between fillups for about 3 tankfuls. The MFD mpg increased with each fillup after reconnecting.
  6. Rokeby
    Rokeby Member
    3,033
    708
    75
    Ballamer, Merlin
    I recently had the 12v battery on my 2008 Prius disconnected.
    I did not loose nav info, radio presets, or the driver's window "sticky-key" feature.
    (I don't remember loosing the clock. Its so easy to reset, it's no big deal.)
    This is contrary to much that I've read here. Perhaps this is a 2008 model year feature.
    I did loose a passenger-door-opened-first-opens-all-doors SKS reprogram.
    And I noticed that it took a while to get back up to my typical MPG, but it was only one tank.
  7. Patrick Wong
    18,199
    6,464
    Does this mean that a dealer mechanic did the battery disconnection for you? If so, the mechanic is supposed to note your radio settings etc. and restore them. Or, the mechanic may have had access to a 12VDC power source and kept power applied while the battery was removed.
    If you disconnected the battery yourself and found that all your settings were retained, please let us know. That would be a new feature not found in older 2G or Classic.
  8. Rokeby
    Rokeby Member
    3,033
    708
    75
    Ballamer, Merlin
    I disconnected the 12v battery myself with no alternate source of power.
    As to a Toyota tech resetting the nav and radio info, where would the input-out port be? This is an intriguing idea. It implies the possibility of editing the info with a text editor and bulk loading new nav data.
  9. Patrick Wong
    18,199
    6,464
    Wow, this is very interesting.
    There's no port. The mechanic is supposed to manually make note of the station settings on the radio; then enter them after working on the car.
  10. qbee42
    qbee42 My other car is a boat
    18,058
    3,073
    Northern Michigan
    The ECU goes through a learning process. This is true with most modern automobiles. They adapt to your driving style.
    Tom
  11. frosh
    frosh New Member
    35
    Virginia
    My experience varies. I have had the battery go empty several times. Mileage dropped more than 5 mpg after I had the first service. I noticed that just recently mileage comes back up from a long time average of 46 to 51. The timing is kind of weird, after 3 weeks back on my 50 mile commute the mileage started like shooting back up this week. Seriously it looks that the computer learns the driving style and looses its memory when battery is low. Funny though, the milage from the 1st mile was up 52 until I had my first service and/or battery outage, couldn't tell now which. My Prius had anticipated my driving style?
    Maybe I'm gonna reset the average Monday and it'll go back up to 52 after a new start.
    Note, that at the pump the mileage always is 2 to 2.5 mpg lower than on the computer. I do compare that most times.
    Yes, I've lost radio, beeper and other settings, too.
    Not the garage door opener setting, though
    frosh
