OCC Gasket Replacement
Discussion in 'Gen 3 Prius Technical Discussion' started by Noahdoge, Jul 22, 2022.
Tags:
  1. Noahdoge
    Noahdoge Active Member
    219
    148
    Mississippi
    4EB4A7E4-7B4C-4AAB-A1E0-79FEF73393AD.jpeg Has anyone here replaced the larger o ring that goes on the can itself? What size was it and where did you order from. This is the generic cheap one from Amazon.
  2. Tombukt2
    Tombukt2 Senior Member
    13,822
    2,507
    Durham NC
    Is it broken completely even if it is you should be able to easily Mic or Gage the diameter of the rubber and then the OD should be the same to measure like 36mm od.. 2mm section diameter
    Noahdoge likes this.
  3. Noahdoge
    219
    148
    Mississippi
    Not broken, but was thinking about finding an upgrade for it. Something made of viton or similar.
  4. rjparker
    rjparker Tu Humilde Sirviente
    11,022
    6,912
    Texas Hill Country
    Buy a digital caliper from Amazon or Harbor Freight ($20) and measure. In the meantime if its not broke don't fix it.
  5. Noahdoge
    219
    148
    Mississippi
    8BB67878-44E0-4E17-9613-B7A1B68FB952.jpeg The seller on Amazon sent me this photo. Really nice of them to measure it.
  6. xliderider
    xliderider Senior Member
    8,140
    3,280
    Honolulu, HI
    You also need to know the thickness of the o-ring as well. Either a direct measurement of the inner diameter (ID), or the actual measurement of the o-ring thickness itself.
  7. Noahdoge
    219
    148
    Mississippi
    True, but I’m honestly also looking for something with double the thickness. It’s a $5 bet on Amazon. I’ll update this if it actually works or not. Upgrading the other o rings on the occ helped tremendously with the fuel smell.
