Occ oil catch can
Discussion in 'Gen 3 Prius Main Forum' started by C-in-DC, Feb 20, 2024.
  1. Moroso
    33.3%
  2. RX performance
    0 vote(s)
    0.0%
  3. Tasan Racing
    0 vote(s)
    0.0%
  4. Mishimoto
    0 vote(s)
    0.0%
  5. Any two port baffled oil catch can regardless of make
    66.7%
  6. No OCC.
    0 vote(s)
    0.0%
  1. C-in-DC
    C-in-DC Member
    487
    68
    Washington D.C.
    I would like to invest in an oil catch can. Need advice on which to get.
  2. Tombukt2
    Tombukt2 Senior Member
    13,391
    2,409
    Durham NC
    Actually most of them are very similar If you look at them online the shape of the can the in and out of the lines and all of that are very similar If you just Google the oil catch can in the Gen 3 section of this list you'll see models and units and use they're pretty much very similar. You're still going to wind up with the 2ZZ Atkinson problems regardless of what you catch in a can for oil The system has something similar to this built-in it's just not very well executed It kind of works but this is not going to save you from a head gasket problem or a messed up engine after 150,000 mi your best bet is to just be out of the car by then and beyond to a new payment or another vehicle Why risk it these cars are not made to go the long distances of Toyota of yore.
  3. Mendel Leisk
    41,889
    I don’t know that I’d recommend it, there are more efficient, but I’m using a pair of Moroso 85474, in series. They’re very solid construction, dependable.
    The Achilles heal for me was the o-ring between the upper and lower portions: you need to be gentle with it, and Moroso rep advised me to always apply anti-seize on it when reassembling. Also suppled me the o-ring spec, and I was able to source locally.
    here’s a good comparison video, Moroso vs RX:
    And if you haven’t found it, the mother of all oil catch can threads:
    Oil Catch Can, Eliminate that knock! | PriusChat
    #3 Mendel Leisk, Feb 20, 2024
    don K otay likes this.
  4. C-in-DC
    C-in-DC Member
    487
    68
    Washington D.C.
    I looked at that thread but I was hoping to get votes so I could decide.
  5. Mendel Leisk
    41,889
    Ok, voted. What is “port baffled” btw?
  6. C-in-DC
    C-in-DC Member
    487
    68
    Washington D.C.
    Two port.
  7. Tombukt2
    13,391
    2,409
    Durham NC
    I think this is referring to the ports themselves those places where you attach hoses have baffles in them kind of like turning veins and air conditioning duct work similar to that to kind of help the particulate smack into something and then fall down in the bottom of the can that kind of activity.
  8. don K otay
    don K otay Junior Member
    35
    16
    Round Rock Texas
    Has anyone done a test on the sludge collected comparing Ethanol vs Non-Ethanol fuel ?
  9. Tombukt2
    13,391
    2,409
    Durham NC
    I don't know but you can send that mess out to all these companies that look at your oil and pretty much anything you want to send them and pay for they'll look at give you a print out of all the nonsense contained within the sample and then the scientist types can go to work
  10. Mendel Leisk
    41,889
    With dual cans in series, I've collected them in separate jars, let them stratefy. my first one collects maybe 50/50 oil/water, and the second more like 80/20 oil/water. Surprisingly, while mostly water, the overall of the second can was maybe 50% more.
  11. C-in-DC
    C-in-DC Member
    487
    68
    Washington D.C.
    Leaning towards the Mishimoto in tandem with a cheaper second can. Only problem is it doesn’t have a drain. Seems annoying to have to disassemble it all the way each time.
  12. Tombukt2
    13,391
    2,409
    Durham NC
    Yeah but the cats can idea is it It separates the nasty crap coming through the intake to the can keeps the nastiness in the can but lets the oil run back to somewhere the pan whatever right?
  13. Mendel Leisk
    41,889
    Most just collect stuff, don’t return it anywhere.
    the Moroso 85474 has a drain with gargantuan elbow below. I removed the elbows, replaced with tapered pipe thread brass plugs.
    Mine are mounted on a bracket atop the main front cross beam (underside of which is front jacking point). I have the bracket installed with finger-tight lock nuts, and a flexible layer twixt bracket and beam, since that beam needs to flex whenever front jack point is used.
    I drain them whenever doing an oil change, just back out the two brass plugs, then open the taps. Nary a drop comes out till I open the taps, so maybe even those brass plugs are unnecessary.
    The bracket I cobbled from a section of slotted angle; I’ve slotted out to its edges where the can mounting bolts are, so if I want to remove the cans for a clean out I just need to slightly loosen the bolts, lift the cans up and off the bracket.
    I’m not using hose clamps on any of the barbed connections (have read they’re not required, barbs sufficient), no problems. using 3/8” ID SAE30R7 fuel line, readily available by the foot locally.
    Oil Catch Can, Eliminate that knock! | Page 113 | PriusChat
    Oil Catch Can, Eliminate that knock! | Page 111 | PriusChat
    #13 Mendel Leisk, Feb 22, 2024
  14. don K otay
    35
    16
    Round Rock Texas
    Where is all the water coming from?
  15. Mendel Leisk
    41,889
  16. C-in-DC
    C-in-DC Member
    487
    68
    Washington D.C.
    does the Moroso have a baffle?
  17. Mendel Leisk
    41,889
    The top half has a dividing wall, with a heavy gauge, stainless mesh biscuit on either side, and a perforated plate enclosing them. There's entrance/exit ports on the sidewalls, symmetrical, can be installed so either is entrance or exit. I've got better pics "somewhere" of the interior, but here's one that shows the exterior:
    Oil Catch Can, Eliminate that knock! | Page 20 | PriusChat
    The air comes in one side, passes through one of the mesh biscuits, then the perforated plate, over and back into the other side. I've since added a small baffle plate (cobbled from aluminum flashing), attached with the two screws holding the perforated plate, to make the air flow a little further down into the lower chamber, before being allowed back up and into the mesh biscuit on the exit side.
  18. Mendel Leisk
    41,889
    Here's a pic of the baffle I added. The bend at the tip points towards the inlet side, my thinking being to make the gas work a little harder swirling around that edge. Note: it's painted, and that turned out to be bad news; the paint started to pucker up after a year or two. I've stripped all the paint off now.
    I've purposely kept it not quite as wide as the ID of the barrel, so that even if the level of collected blow-by liquid got up to the baffle, the gas could get around through the gaps.
  19. C-in-DC
    C-in-DC Member
    487
    68
    Washington D.C.
    Was the angle you used for the bracket aluminum?
  20. Mendel Leisk
    41,889
    Steel slotted angle 2.5"x1.5". I had a "slotted angle phase", have a lot of it.
    Slotted Angle Shelving (In Stock) | Shop Angled Metal Shelves
    Here's an older iteration, from when I had a single can:
    Note the slots I cut in the upstanding leg; they facilitate removal of the can: I just need to loosen the mounting bolts slightly, then I can lift the can off.
