Oil Catch Can, Eliminate that knock!
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by danlatu, May 22, 2017.
  1. Raytheeagle
    Raytheeagle Senior Member
    11,269
    15,528
    Bay Area, California
    2019 Prius Prime
    If you want to make your catch can more efficient (and avoid cans in series), why not increase the residence time;)?
    This can be done by adding a demister style pad (steel wool) inside the can. It will take longer for the vapors to exit, leading to more condensing. Remember, vapors will take the path of least resistance while they have higher energy (once a liquid it takes a lot of energy to vaporize) and if you make it too difficult to leave, they’ll stay:).
    If you mount the can away from the inverter or ice block, the can will stay ambient which is cool enough to condense the vapors is one place:).
    You could always test with and without the steel wool and see if there is a difference in amount collected ;).
    Or wait for the results after I install a catch can around Christmas (y).
    Robert Holt, SFO and mjoo like this.
  2. Mendel Leisk
    42,352
    I was thinking about that. You can see from the video above, the Moroso has a couple of steel wool biscuits, one at the both the intake and outlet (it's reversable, works either direction), and a fair bit of open space below. Put some more stainless steel wool in that extra space might help. OTOH, more hassle to clean, more clog prone?
    mjoo and Raytheeagle like this.
  3. Raytheeagle
    11,269
    15,528
    2019 Prius Prime
    Didn’t watch the video (on vacation with the wife and kids so getting a couple of minutes away is challenging at best):whistle:.
    Could you clean the steel wool? Sure, but Steel wool is cheap enough where you could just remove and replace at a desired frequency ;).
    Could the steel wool clog? Possibly but not likely as:
    • You’ll be pulling and inspecting long before it could even potentially plug;).
    • While you’ll add some mass that will reduce the volume slightly, steel wool is high surface area so it’ll take a lot to plug off the whole mass:)
    • You’re passing vapors and liquids not solids through. The condensate will drip off of the steel wool and collect in the bottom. If it were solids, the chance of plugging would be greater;).
    Hope that helps(y).
  4. Mendel Leisk
    42,352
    You've sold me; think I'll try some extra steel wool after the spring check, see if it increases the catch, by fall. I'll put it in very loosely, try to rinse it clean with brake cleaner, put the run-off in my waste oil. I'm trying to avoid dumping oily junk into the garbage, and I'm not sure Mr. Lube would accept it as a used oil filter.
    Bay Stater, mjoo and Raytheeagle like this.
  5. Mendel Leisk
    42,352
    Or maybe just extend the baffle down: fashion something out tin can material, connect with the existing screws.
    leeb18c and Raytheeagle like this.
  6. CR94
    CR94 Senior Member
    2,831
    1,243
    Northwestern S.C.
    It's gonna be interesting when somebody's engine inhales a loose fragment of that steel wool!
    Keithstef, Mendel Leisk and amos like this.
  7. StarCaller
    StarCaller Senior Member
    1,284
    733
    Cedar Crest, NM, USA
    there are no loose fragments/
    leeb18c, scona and Raytheeagle like this.
  8. RMB
    RMB Senior Member
    406
    642
    Oakland, CA
    Here are some minor updates 3 Saturdays since the Bay Area meet with OCC installation.
    469 miles driven, the catch can collected about 10ml of gasoline, oil, and moisture mixture. Color looks like coffee so for sure water is there. It does smell like gasoline also. Moisture I believe comes from foggy morning cold starts, and about 1.2 miles of local streets in stop and go, red lifts/stop signs traffic before I can get on the freeway.
    danlatu, SFO, Bay Stater and 4 others like this.
  9. Mendel Leisk
    42,352
    What can is that?
    leeb18c likes this.
  10. StarCaller
    1,284
    733
  11. Raytheeagle
    11,269
    15,528
    2019 Prius Prime
    Still rollin’ with the can up top I see;).
    And you were able to install the insert(y).
    SFO, Bay Stater, RMB and 1 other person like this.
  12. Bay Stater
    Bay Stater Senior Member
    534
    771
    Central Mass
    For those that have installed a catch can and live in a CARB state, have you had any issues passing inspection? Thanks.
    SFO and Raytheeagle like this.
  13. Mendel Leisk
    42,352
    It would be advantageous in such locales, to use a compact and nondescript can, black hoses, minimum of clamps (they seem like total overkill with the hose barbs) and mount below the intake manifold.
    CR94 and Bay Stater like this.
  14. Raytheeagle
    11,269
    15,528
    2019 Prius Prime
    Not sure but have a friend who might help as long as there are no engine codes:whistle:.
    amos and Bay Stater like this.
  15. CR94
    CR94 Senior Member
    2,831
    1,243
    Northwestern S.C.
    ... on plumbing that operates only below atmospheric pressure? Indubitably!
  16. RightOnTime
    RightOnTime Senior Member
    791
    1,660
    183
    Kidnapped in OC, CA
    Thanks for the inspiration People! Now its time to put some miles on the car!
  17. JMJCATH
    JMJCATH Member
    91
    52
    Here
    Any shots of where the hoses are going to?
    I know it was mentioned in post #357 but it appears in that picture both connections are made before cutting the hose so I don't understand that once the tube is cut why would it be suggested to reconnect that rubber black elbow?? Makes me think the connection isn't made (hard to tell from the picture) and if not, where does it go?
    Oil Catch Can, Eliminate that knock! | Page 18 | PriusChat
    Following the RX can, is a CSS necessary? CATCH CAN TURBO, CATCH CAN BLOWER, CATCH CAN SUPERCHARGER, RX CAN | REAL ORIGINAL RX CATCH CAN DEVELOPERS AND MANUFACTURERS
    By the time I figure this out (since no mechanic seems to want to do this), my Prius will probably be sold! Maybe an option is to wait & see if someone will do a video/write up with good pictures or sell it at 100K, whichever comes first!
    #397 JMJCATH, Dec 7, 2017
  18. rrg
    rrg Active Member
    458
    120
    East coast - NJ
    I just ordered my catch can. The square one with the lid and bottom that comes apart. I plan to mod it.
    Many people mod the cheap can with the scotch bright stainless steel pads and a tube that brings the inlet air closer to the bottom of the can. This way the air must travel up toward the oulet where it condensates on the steel pad material on the way out.
    my2 cents.
  19. danlatu
    danlatu Senior Member
    533
    1,367
    maryland
    Just dropped off the 2011 prius at a Toyota dealership for side curtain airbags and headlights recall (rewire and new bulbs). I asked to speak with a hybrid tech and was told they did not have one onsite, but had 3 master techs working in the garage. I asked to talk to a mechanic for 30sec in regards to customers experiencing knock start problems. I was offering free/0$ information on how an oil catch can eliminates this problem. Call me a good samaritan/Prius fan boy. The service counter guy returns with a grin on his face politely telling me that the mechanic does not want to talk to me about this and implies about how the mechanic laughed at the idea (my thoughts). I am in no way shape or form angry or irritated at this. It made me :):):)
    I just wanted to share the experience I had today. This is one of the reasons I hate going to the stealership. The mechanic does not realize that many other car manufacture's have been using oil catch cans/oil separators on their vehicles. It goes to show you that you can not take advice from someone wether it be a doctor, lawyer, auto mechanic and expect him/her to have the final word as a professional. I love getting a second opinion's and doing the research myself.
  20. amos
    amos Active Member
    376
    285
    los angeles
    @danlatu yes i knew that will be their attitude. Never admit.
    There is something i wanted to ask you. Just to get the whole thing understood. The OCC purpose is to eliminate oil and all other stuff from accumulating on the IM . i still dont understand where is the solution for Egr pipe cooler and valve from being clogged again. I think you agree that OCC will not prevent egr passages from being clogged again.
    danlatu likes this.
