OCC Working Great!
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Noahdoge, Oct 12, 2021.
  1. Noahdoge
    Noahdoge Active Member
    219
    148
    Mississippi
    OCC was well worth the investment. Only 5,000 miles with it installed and went to see how much was in there after doing an oil change. About 4 tablespoons worth of nasty smelling oil so I’m very impressed!
    Raytheeagle, xliderider and mjoo like this.
  2. xliderider
    xliderider Senior Member
    8,140
    3,277
    Honolulu, HI
    I'm curious, where is your OCC mounted?
    I'm thinking about relocating my OCC, which currently sits on top of the front crossmember, under the airbox, to a position next to the engine coolant reservoir.
    However, I'm wondering if the extra length hoses needed to route to this area will affect the vacuum levels in the PCV system appreciably.
    Those that have their OCC mounted behind the driver's side headlight probably have a comparable length of tubing to the OCC relative to the PCV valve on the engine.
  3. Ldo
    Ldo New Member
    Orange County, California
    Wow, all that could have gone into your intake?
  4. xliderider
    8,140
    3,277
    Honolulu, HI
    Not could've, would've. That's why there's usually a pool of oil sitting in the intake manifold under the throttle body waiting to be aspirated into the engine.
  5. Noahdoge
    219
    148
    Mississippi
    I’m going to add a zip tie to get it secured but this was the best place I could put it without having to do the bracket method.
    xliderider likes this.
  6. Mendel Leisk
    42,223
    Some probably still did (still make it to the intake, and combustion chamber too); nothing is 100% effective at waylaying PCV oil vapours. But it sure reduces it, as you can see. I run dual Moroso 85474 in series, and the second one in line often has MORE stuff than the first, especially in spring. This is due to more humid winter weather I think. To be fair, the catch in the second can is mostly water.
  7. xliderider
    8,140
    3,277
    Honolulu, HI
    Wow, snug as a bug in that location. Are you able to lift the can out of there with the hoses attached when it comes time to empty the OCC?
    Also, something to consider, that OCC has fittings that are the same 16x1.5mm thread as the PCV valve. Which means you can swap a fitting into the original PCV valve location and move the PCV valve to the OCC outlet. It would keep the PCV valve cleaner and make changing it so easy.
    The thing I haven't determined yet is whether the open OCC fitting in the original PCV valve location passes more, or the same amount of oil/vapors to the OCC.
  8. Noahdoge
    219
    148
    Mississippi
    There’s enough slack where I don’t have to disconnect anything. It takes about 20 seconds of moving the occ around the get it out of the tight fitting.
    I was going to go with that method of changing the location of the pcv, but ended up not because in my opinion I’d rather only have denso quality equipment going into the engine block. The threads are very fine and there is a lot of room for error with putting equipment that’s not made for it in there.
  9. xliderider
    8,140
    3,277
    Honolulu, HI
    Your OCC location inspired me to move the OCC in our 2014 Corolla. It was previously mounted to a bracket that I affixed under the battery tray. However, it was difficult to reach around the radiator hoses to get at the OCC.
    This location is perfect, higher than the PCV outlet on the engine block, and easy to access the OCC to check and empty. Also, it's away from the rear of the radiator and the heat, so I'm hoping to get more oil condensing out of the vapor phase. It's mounted on a bracket bolted on a stock bracket location on the engine block.
    #9 xliderider, Oct 13, 2021
  10. xliderider
    8,140
    3,277
    Honolulu, HI
    Regarding messing up the threads on the original PCV valve location, you don't have to worry about that since the OCC fitting is aluminum, which is much softer than the steel thread's on the PCV valve mounting plate.
  11. Mendel Leisk
    42,223
    FWIW, the PCV valve screws into a bolted-on plate, covering a rudimentary labyrinth in the block. Still, it's really on there, bolted plus a bead of sealant, which makes for a real job to pry off.
    Still, I'm not sure I see the advantage of shifting the PCV valve. (n)
    #11 Mendel Leisk, Oct 13, 2021
    Paul E. Highway and xliderider like this.
  12. sLick415
    sLick415 Member
    214
    55
    San Francisco, CA
    This is where I have mine mounted. Easy access from below with every oil change.
    PXL_20210405_185721043~2.jpg PXL_20210405_200024276.jpg PXL_20210406_032045278.jpg
  13. xliderider
    8,140
    3,277
    Honolulu, HI
    I try to avoid taking off the undercover at all costs. Nothing easy about jacking up the front end, placing jackstands, removing the cover, etc.
    I want to be able to check the OCC easily, without a jack or ramps.
    I'm thinking of locating my OCC next to the engine coolant reservoir. I have completed the mounting bracket, I just need to remove the OCC from the crossmember and reroute the hoses. The OCC in the picture is a new one that will be mounted on a third vehicle. 20211008_165031.jpeg 20211008_165142.jpeg
    #13 xliderider, Oct 13, 2021
  14. sLick415
    sLick415 Member
    214
    55
    San Francisco, CA
    Ya I can understand that if your can is filling up frequently. For my car, I can get away with emptying it every third oil change. I also live in California so mine needs to be hidden.
  15. xliderider
    8,140
    3,277
    Honolulu, HI
    Update: There seems to be too much oil mist getting past the OCC and condensing in the tubing after the OCC, as there is a fair amount of oil in the hose leading to the intake manifold. I see OCCs with sintered bronze filters for sale, but they seem to be too restrictive for air flow. I got some and sure enough, no light can be seen through the bronze filters, so it is easy to believe that any oil or particles can easily clog this fine filter material.
    I got some very fine mesh stainless steel screen from Amazon and fashioned a filter by cutting a 12 x 3 inch strip and rolling it up into a tube. This is ziptied to the screw on filter canister that holds the steel wool. I then squeezed the bottom end of the tube flat and used a sheet metal seaming tool to double fold the end over.
    I had to additionally bend the corners over as well so that it would clear the inside of the OCC can's walls.
    The filter is at least 3 layers thick and light can still be seen through it.
    Lastly, I believe that the OCC is mislabeled. The port marked IN should be the output side, you want the oil to condense on the filter and drip down into the can before exiting. Screenshot_20211101-110755_Amazon%20Shopping.jpeg 20211101_105246.jpeg 20211101_105312.jpeg 20211101_105223.jpeg 20211101_110555.jpeg
  16. Brad from Ohio
    Brad from Ohio Junior Member
    17
    Cleveland
    Installed OCC on the left side of the motor in the space down by where the washer fluid container is.
    As in this location the OCC bracket, which came with the OCC I ordered, could be bolted to. As well as sufficient space for the hoses in and out of it.
    Strongly recommend not installing down there. As each time I empty it out, which was about once over this past Winter, required unbolting the left side black plastic air filter related component. Can then reach down and untwist the OCC. To facilitate doing this requires disconnecting the MAF sensor. Taking it off requires a bit of force. Vehicle harness clips aren't designed to be taken on and off monthly.
    If/when the clip eventually breaks or wears out it may require a tow, and being at the mercy of to the dealership to repair it.
    Yes you could jack up car, remove the underneath covers, and then reach up to access the OCC.
    But am not trying to go through all that on a monthly basis either.
    Was a person on PriusChat years back who 3D printed and sold a white plastic OCC holder which fit on the top right side over by the fuse box. When clicked on the link to buy it, it was no longer available for purchase.
    Would not have to repeatedly remove air flow related components, and jeopardize the MAF sensor clip, if had been installed in that location.
  17. AzusaPrius
    AzusaPrius Senior Member
    2,249
    940
    @sLick415
    I am glad I saw your post, I was looking all over for a stealth location.
    I remember seeing one a long time ago but could not find it again.
    I also live in California so want it hidden just in case.
    I will be doing my own oil changes so it is a perfect location.
    Thanks for sharing!
