occasional rough shutdown from gas to electric???
Discussion in 'Gen 2 Prius Technical Discussion' started by normanj, Jul 10, 2006.
  1. normanj
    normanj New Member
    Anyone have rough shut downs from gas engine to electric engine???
  2. TonyPSchaefer
    14,816
    2,497
    66
    Far-North Chicagoland
    You might want to check your profile: it says you have an '03 though your thread title says "2005". Though, you probably own two and now I'm the schmuck. :)
    Anyway, yes. As some here have noted, ocassionally there is a shutter when the ICE shuts off. Nothing major. Being in SanFran you might never encounter this, but it's worse in cold weather.
    Welcome to Priuschat!
  3. Bill Merchant
    Bill Merchant absit invidia
    4,096
    81
    This is usually a problem in cooler weather, but I see you're in SF, so maybe it is cooler weather. Another contributing factor is the state of charge of the battery; when the SOC is halfway, it seems to happen a bit more.
    It's normal, and will mostly subside with more miles on your car/time on your ICE.
  4. bobkat21
    bobkat21 New Member
    99
    Elwood IL
    <div class='quotetop'>QUOTE(normanj @ Jul 9 2006, 11:21 PM) [snapback]283649[/snapback]</div>
    I also get this . I just lerned to deal with it. Now tell me do you ever get when you put on the break and hit a small bump at the same time . the car seams to jurk forward fast?
  5. normanj
    normanj New Member
    <div class='quotetop'>QUOTE(Bill Merchant @ Jul 9 2006, 11:32 PM) [snapback]283659[/snapback]</div>
    Thank you!!
  6. normanj
    normanj New Member
    <div class='quotetop'>QUOTE(bobkat21 @ Jul 10 2006, 12:16 AM) [snapback]283682[/snapback]</div>
    I assumed that the electrical engine is kicking in causing a surge because the bump triggered it somehow - but yes i have experienced this
