Odd noise trying to figure out...
Discussion in 'Gen 2 Prius Main Forum' started by zooracer, Aug 15, 2017.
  1. zooracer
    zooracer New Member
    22
    asheville NC
    I will try to post a short video I took recording the noise
    It is coming from behind the dash or engine compartment
    It is two noises. Both start and end together. They come and go every 14 seconds like clockwork. They last about 3 seconds
    One part is a buzzy type noise and second is a knocking sound
    Sounds almost like a water pump that is trying to keep pressure in a system/line
    Any idea what that is?
    I'll try to attach video
  2. fotomoto
    fotomoto Senior Member
    5,639
    3,815
    So. Texas
    A repetitive buzzing type sound is usually the brake pump (actuator) going bad on the Gen 2 which is the forum you're posting in. I mention the latter since you don't state what vehicle this is happening to.
    52,786
    what year and how many miles?
    how many miles have you owned it?
    how many miles has it been making the noise?
  4. zooracer
    zooracer New Member
    22
    asheville NC
    Wait
    It goes away when foot goes on the brake
    Must be the complicated hydraulic system keeping pressure
  5. zooracer
    zooracer New Member
    22
    asheville NC
    I've owned it 4 months
    Always did it
    90k miles
  6. Beachbummm
    Beachbummm Senior Member
    1,160
    392
    call your dealer and give them the vin number , ask about an extended warrantee on the brake actuator .... Toyota is replacing a lot of them.. don't disconnect the battery if theres an error code they will have to see it when they scan the car. good luck, the repair cost is about $2700
  7. zooracer
    zooracer New Member
    22
    asheville NC
    Gotcha
    Problem is I see no codes thrown?
    I have a code reader and scangauage II
    Still take it in?
  8. bisco
    52,786
    you need tech stream for some prius codes, but if you didn't get any dash lights, there might not be one.
    do you get the buzzing sound when you open the drivers door?
  9. bisco
    52,786
    is it a 2007?
  10. zooracer
    zooracer New Member
    22
    asheville NC
    And it isn't related to door being open
    I mother-in-law had a 2006 hybrid Camry that the actuator went out on she took it into the dealer that she bought it from and they gave her a really hard time. It took months to get them to agree to do it and she still had to pay labor
    I am calling dealership now and will update on here in a bit
  11. zooracer
    zooracer New Member
    22
    asheville NC
    Ok
    So apparently there is an extended warranty dealer through Toyota for the accumulator until dec 31 2017
    So I set an appointment for tomorrow at 215 to drop it off
    They will see if that is what it is and then supposedly replace for no charge
    I'll update tomorrow
    Beachbummm, coolioe93 and bisco like this.
  12. bisco
    52,786
    all the best!(y)
  13. bisco
    52,786
    all the best!(y)
  14. coolioe93
    coolioe93 Junior Member
    Houston
    Could you post a video of the noise? Does it sound like this?
    iPhone ?
  15. bisco
    52,786
    wow, that's bad! nice audio.(y)
    WilDavis likes this.
  16. Beachbummm
    1,160
    392
    good luck, mine had an error code stored so I was covered.. took a day and a half to do a 4 hour job LOL
  17. zooracer
    zooracer New Member
    22
    asheville NC
    I'm at the dealer now
    They are getting ready to check it for codes
    If no codes found then they will not warranty it
    Keeping fingers crossed
    Technician heard how it tries to build pressure every 13 seconds and said that isn't normal and said it wa the accumulator
    But again...no codes then no help
    I'll post back in a few
    coolioe93 likes this.
  18. zooracer
    zooracer New Member
    22
    asheville NC
    It is the abs actuator accumulator and they will replace under warranty
    Yeah!!
    Part will be in Monday so I'll bring it back then
    Thanks for all the help!
    This forum is the best
    WilDavis and bisco like this.
  19. Beachbummm
    1,160
    392
    look up the regional Toyota customer service managers number and name for your part of the country, they might authorize the repair, if not you can call the nation wide customer service center and tell them what the tech said..
  20. Beachbummm
    1,160
    392
    great, you owe me a pizza... it would have been a $2700 repair ;)
    zooracer likes this.
  21. zooracer
    zooracer New Member
    22
    asheville NC
    Would have been more than that! 2700 for part alone!
    Send me your address and I'll have dominoes deliver...what do you like in it?
    WilDavis and SFO like this.
