Odd vibration after coming to a stop
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by liyah016, Jun 9, 2016.
  1. liyah016
    liyah016 New Member
    Dallas,Texas
    For three days, my 2013 Prius has suddenly started to vibrate after coming to a complete stop. I feel the vibration in floor boards mostly and a little on the brake pedal. Oddly, I only feel the vibration on my way home from work ( summer heat maybe??).
    This is my second Prius so I am used i noises and the brakes work/feel fine so I'm just wondering where the sudden vibration is coming from.
    My Prius has 43,000 miles and I put new tires on the vehicle in March. I have appointment for service on Saturday. Any ideas what it could be?
  2. spiff72
    spiff72 Member
    184
    37
    West Michigan
    I am about 99% sure it is the AC compressor running. I notice it through the brake pedal on my car too. I don't use AC that often, so it stands out to me.
    52,725
    is it happening before and after the engine shuts off?
  4. gmcneil05
    gmcneil05 Member
    118
    36
    Avon Park, Florida
    It is definitely the AC Compressor. Mine does the same thing. Next time you feel it just turn the AC off and see if it stops.
  5. PRPrius
    PRPrius Active Member
    327
    198
    I will have to agree with the Air Compressor explanation. Living in Fort Worth I feel it every time I get in the car on a hot sunny day. The Prius can bring the A/C compressor to a very high RPM level when it is not on ECO mode and it is trying to cool down the car on a hot summer day. I only feel it while the compressor is giving it all it has. Once the cabin temperature starts to go down it disappears. Next time it happens turn ECO mode on and see if it stops; you could also try and increase the set temperature to force the compressor to slow down. I always use the Auto setting so I am completely used to it. I rather have the vibration than no A/C.
  6. qdllc
    qdllc Senior Member
    1,377
    400
    Likely this. The compressor runs based on load (how hot it is in the cabin and what temperature you set the system at). Every time it's HOT, I hear a grinding noise from under the hood and sometimes feel it through the brake pedal, and I can tell it's the compressor going full bore.
    I'm somewhat disconcerted that it's so noisy when running at full load. Normal A/C compressors run at a set rate and are relatively quiet. My guess is that the electric motor running the compressor
  7. bisco
    52,725
    i wonder why liyah didn't notice it in her first prius, maybe gen 2 a/c was different?
  8. FuelMiser
    FuelMiser Senior Member
    1,349
    929
    Monument, CO
    I definitely notice the A/C compressor in the Gen 3 more than the Gen 2. But, I've not noticed vibration, just a simple spinning sound. Leave your car in Ready with the A/C on, and get out of the car (or maybe just roll down the window in an otherwise quiet setting) and you'll hear the A/C cycling on/off every few seconds. At least this is what mine does. Whirring sound yes, vibration no.
  9. bisco
    52,725
    yes, i can hear mine as well. liyah, can you hear yours?
  10. Montgomery
    Montgomery Senior Member
    2,254
    2,242
    Orange County, CA
    Speaking of that, how about the Verizon guy who used to say "can you hear me now" leaves Verizon for Sprint and now says "can you hear this".
  11. jcohan
    jcohan Junior Member
    I'm glad to have found this thread, as I'm in exactly the same situation. My previous Prius (2005) never did this, and my current one (2011) just started a month ago. I just had the car in for service this morning, and the dealer found no issues with the A/C. It sounds like it isn't anything other than a very minor annoyance.
