Oddball series of error messages on cold morning
Discussion in 'Prime Main Forum (2017-2022)' started by John roden, Nov 5, 2021.
  1. John roden
    John roden Member
    67
    29
    West Falls, New York
    That's amazing, thanks for the explanations. Dealers must have a hard time keeping mechanics trained to work on these things it sounds like a very complicated system when it goes wrong
  2. schja01
    schja01 Senior Member
    1,835
    1,221
    Chicagoland
    2024 Prius
    Limited AWD-e
    jerrymildred said
    schja01 said:
    The charge door has a solenoid so it could be affected.
    Actually, it's just a spring loaded pin under a rubber boot. Works just like the stereo cabinet doors that you push and they pop open but it activates a switch that monitors its position. So, yes, they can get gummy in cold weather, I suppose. But that would most likely lead to the door not popping open. The switch not knowing the door is closed might take some investigation of the visual variety.
    What you say may be true if you're not in range of a key FOB. If a FOB is within range there is a definite "clunk" when you open/close the charging hatch. If that's not a solenoid it sure is doing a pretty good imitation of one.
    J
  3. vvillovv
    vvillovv Senior Member
    4,321
    1,510
    NY
  4. jerrymildred
    jerrymildred Senior Member
    11,517
    14,152
    Tampa, FL
    Two separate things. The locking pin has the solenoid. The opener has the spring and is behind the "n" in "pin" in the picture below.
  5. Gokhan
    Gokhan Senior Member
    6,242
    2,475
    Paramount CA
    jerrymildred likes this.
  6. jerrymildred
    11,517
    14,152
    Tampa, FL
    I was just addressing what it might be if it was not caused by the obviously low 12V battery. You're right that it really was probably the low 12V that was the culprit. Especially since @John roden hasn't reported any repeat events since charging his battery.
    Glad you brought it back to the main issue.
    Gokhan likes this.
