Oddity with 12V battery voltage measurements andtranmission
Discussion in 'Gen 2 Prius Main Forum' started by pasadena_commut, Apr 17, 2025.
  1. pasadena_commut
    pasadena_commut Senior Member
    2,620
    776
    Southern California
    Finally managed to get some current measurements with the car in the high and low voltage states. Voltage measurements on the battery, current measurements with a clamp ammeter on the positive cable that runs to the front of the car:
    Transmission in "D":
    13.6V with current varying mostly between 30mA and 70mA (sometimes a little higher) into the battery.
    Transmission in "P":
    14.1V, on the transition from 13.6V the current went briefly over 2 A (too fast to read more than the first digit) then it fell back in seconds to somewhat over 1A, but varying. Again, into the battery. Let's call it 1.2A with huge error bars.
    The current at 13.6V is very similar to what I have measured for a BatteryMinder 1500 on the same car, once it is in float mode. The current at 14.1V is at the high end seen during the absorption phase with that charger. I did not wait long enough to see if it continued to behave like the absorption phase. If it did it would have fallen very slowly (over hours) down to 200-300 mA.
    Turned the car off, opened and closed a few doors and then locked the car, then waited 5 minutes, and the battery was reading 12.65V. Before the drive the car had just come off the charger and it was also at 12.65V. Seems to me that this Prius is somewhat overcharging the 12V battery for no obvious reason. The battery is fully charged as far as a battery charger is concerned, but the car often pushes it to a charging voltage anyway. Admittedly that is only ~1/40C at worst, and probably ~1/150C (300 mA) at best. Still, float is ~1/600C and down.
    One other odd observation (so many...). Drove the car or had it sit in READY for about 35 minutes. That entire time it was stuck at 14.1V. Stopped at a store for 10 minutes where the car was turned off. After turning it back on in a few seconds it was showing 13.6V in "D" again, and it stayed like that for the 20 minutes it took to get home, and 10 minutes more while I made those measurements. Almost like the logic got stuck on the first part of the trip somehow, or power cycling is needed to let it reexamine the state of the 12V.
  2. dolj
    dolj Senior Member
    8,442
    4,289
    Wellington, New Zealand
    All of your assumptions and theories are going to come up short if you're assuming that 12.65 V is fully charged. Depending on whether you have an AGM or a flooded Pb/A battery installed (I don't see anywhere where you talk about what battery is installed), 12.65 V would be anywhere between ~68% (AGM) to ~84% (Reg Fl Pb/A) SoC
    A healthy, brand-new, fully charged AGM battery will hold a voltage of 13.2 V.
    Your assumptions about the vigor of the rate of charge are wrong. If anything, the Prius charges rather conservatively. The Gen 2 Prius charging algorithm is based on charging an AGM battery, which can harm a standard flooded battery, as it also has a lower fully charged voltage of circa 12.9 V.
    Pb:A voltage band (SoC).jpg
  3. pasadena_commut
    2,620
    776
    Southern California
    It is a 4 year old Toyota OEM battery. S46B24R. Not the Yuasa version with the hex shaped cell caps but one that looks like the Walmart S46B24R battery, with the pinwheel "tamper proof" cell caps. It has always seemed weak, even when new, in that the voltage seems to drop too much for the amount of current it is supplying. Despite the HF battery tester claiming it has ~45 Ah capacity. The OEM battery before that was the Yuasa battery (with a Toyota sticker), and it lasted all of two years. A sustained 13.x volts from the battery (not the converter) just from driving around in the car was a pipe dream with both of those batteries. When charged externally on float for a while of course when they were unhooked they remained briefly at the float voltage, which was indeed 13.x V (or thereabouts). But that was in large part surface charge. Turn on the headlights for a few seconds, turn them off, wait at least 5 minutes for the battery to relax, and they would read somewhere around 12.75V. On a good day, more commonly now it is more like 12.65V but sometimes it is over 12.7V. The battery is in the car, so it will also lose ~.03V every day from the normal 20-25 mA parasitic load and self discharge.
    I recently picked up an electronically programmable load tester to measure how much the voltage drops for known test loads, and to be able to discharge the battery a known amount at C/20 and see where the resting voltage ends up. Funny thing about battery capacity specifications, to actually measure one seems like it would trash the battery. That is, take a brand new fully charged battery, draw C/20 out of it until it is near 0% SOC, and that is the capacity. Except doing that will permanently damage the battery (at least a lead acid one). Even a deep discharge battery isn't supposed to go below 20% SOC. Makes me wonder if the battery manufacturers really measure capacity like that - and then just toss the damaged test batteries. I'm thinking for a start, take it down by 5Ah and compare the relaxed voltages before and after. Iterate, keeping the voltage after discharge above 70% SOC, and then recharge immediately.
  4. dolj
    dolj Senior Member
    8,442
    4,289
    On this point, we can at least agree. In my opinion, this would be true for any battery. This is why I regularly charge externally. I concede there are those who could not be bothered with this level of maintenance, so each to their own.
    In my case, I really mean that a new healthy battery will hold 13.2 V. I say this from firsthand experience. This is why it is important to charge a new battery to ensure it does this. If it doesn't, then reject and insist on a new one that will meet this criterion.
    In my case, I charged the battery, which only took 30 minutes. I don't remember the exact charge voltage, but it was in the ~13.6 V region. After half an hour, the surface charge bled off, and the battery held 13.2 V right until I installed the battery the next morning.
    So if you see different results from that, then you need to be questioning how good the battery is.
    BTW, that battery I mentioned above was installed in 2016, and with regular external charging, that battery still charges to 12.9 V. A pretty reasonable loss for a nine-year-old battery, in my opinion.
    #24 dolj, Sep 27, 2025
  5. pasadena_commut
    2,620
    776
    Southern California
    Who made that battery? Mine were both Toyota OEM, and neither would do that. Yours could be a Toyota battery too, but since the battery they sell in NZ wouldn't be the same as the one in the USA, it won't help me much. I do wonder though if the batteries Toyota was selling in the 2004-2009 time frame were like that, and later iterations were not.
  6. pasadena_commut
    2,620
    776
    Southern California
    FYI, interesting video here showing a pretty comprehensive set of tests charging and discharging a brand new 9Ah AGM battery:
    The device he used to charge/discharge is only $115 on Amazon (look up EBC-A20) and can log everything to a computer. It doesn't seem to be temperature compensated though. So unless this is done in a temperature controlled room the long test and temperatures varying through the day will make it hard to get the same results twice. Anyway, it takes a long, long, LONG time for the charged battery to settle to its final open circuit voltage, I don't think he ever really got there in either test (see for instance 22:00), hence the "let it sit 24 hours" instructions on a lot of battery tests. Also it was interesting that the absorption phase clearly wasn't over when it hit the 100mA discharge cut off on the device (apparently, and strangely, the device cannot go lower).
  7. pasadena_commut
    2,620
    776
    Southern California
    I was mulling over how to force the car to switch from 14.1V to 13.6V and couldn't come up with anything short of modifying the circuits in the inverter. I'm not doing that. However, in terms of protecting a full charged 12V from overcharging it would be pretty easy to do it with a manual control by placing a typical 30A or 40A car relay in the ground strap and running a wire up to a switch near the driver. If the driver turns off all the current draws (no cabin fan etc.) and a voltmeter shows 13.6V, then the car thinks the battery is fully charged. Throw the switch, current goes to the relay coil, 12V battery detaches from electrical system. At that point the car can do whatever it wants and it cannot overcharge the little battery. A power FET would probably work instead of a relay.
    On the other hand, it would probably throw a code because the little sense wire is now attached to a floating battery. The battery would reattach "automatically" when the car shuts down, but the transition might be too slow and the shutdown abnormal. So there needs to be a bit more of a circuit to toggle the relay off in the process of shutting down. Whatever else happens, the 12V must be reattached when the car is "off" so that it can be unlocked, the cabin lights work for going in and out, and so forth.
    This also makes me think that the "car won't keep the little battery fully charged" behavior is actually protective. Because if the battery is fully charged it is going to be subjected to a permanent 14.1V in any climate where the cabin fan always runs. That may or may not be OK on a healthy battery. Bet it isn't on one that no longer charges to 13.x volts. I think I'll get some current numbers on our fully charged 12V when it is sitting at 14.1V. It could be that it drops down below 100 mA, in which case it probably wouldn't bake the battery dry. However, if it sits at 200mA or more that might explain why this battery is so light.
  8. dolj
    dolj Senior Member
    8,442
    4,289
    I still can't help but think you are overthinking this whole issue, based on false assumptions.
    I don't see any of the behavior you mention, and (due to a combination of many short trips and low mileage) the only thing I do differently than you is that I regularly charge the 12V battery externally.
  9. pasadena_commut
    2,620
    776
    Southern California
    Decided to see how much current was going into the battery at 14.1 V at equilibrium. After having fully charged the car the day before drove it with the fan off (about 9 miles, two stops with car left on in P) until the voltmeter dropped to 13.6V. Indicating perhaps that the car thought the battery was fully charged. Then turned the fan on so that it would stay at 14.1 V. 35 min and two stops (car stayed on in P) later reached home and measured the current into the battery, car still on, just in P.
    It was only 20 mA with the UT210E clamp ammeter. Measured it on both the big copper cable and the ground and that's what it was in both locations.
    I was expecting more than that, because in this reference
    Float Current Monitoring: a complete overview - Multitel
    about halfway down there is a diagram "VRLA Battery float current vs. float voltage". 12.41V is 2.35V/cell and on their graph has a value of 3.2, plug that into the formula provided and 3.2 * 45 = 144 mA (+/- 48 mA). For once the weather cooperated and it was pretty close to 25C. The little HF battery tester most recently showed a capacity of 43 Ah, but that isn't enough to explain the difference between 144 mA and 20 mA.
    But how long did it take to get to that very low current? Just then I was unexpectedly pressed into driving my son somewhere. Since the voltmeter installed in the dash was still dropping to 13.6V with the cabin fan off, it was left off for the whole trip. Consequently almost the entire time it was at 13.6V. It was about 25 minutes total driving with two stops, one where the car remained on and one where it was turned off. On returning home again (in D at 13.6V) the car was parked and put in P (jumping to 14.1V). I quickly ran around and took some current readings going into the battery on this jump up in voltage. The first reading was very close to 1A, at ~1 minute it was 400 mA, and at ~2 minutes it was at 366 mA. The battery was full or very nearly so, but I was running on empty (had not had lunch yet), so stopped measuring current and switched over to measuring voltage (next paragraph). Assuming that the correct formula is Ct=C0*exp(k*t), with C0=1, Ct=366, and t=2 that gives k as -.50. The time of the measurements was not right on the minute, so it is really only something near that. Anyway, using that value for k would mean that it takes a bit less than 8 minutes for a (nearly) fully charged battery to drop to a negligible input current. This sort of absorption mode charging usually takes hours in the graphs from chargers, but those graphs are not for batteries which were already at 100% SOC. I need to redo this experiment and let it run longer.
    Put the carabiner in the hatch slot then turned the car off, pulled the fob out of the slot (not SKS), closed the driver's door (but not hatch, which appeared closed to the car), and started making voltage measurements. These were (min:sec volts)
    0:00 13.10
    1:30 12:52 (the thermos pump ran just before)
    2:00 12:69
    3:00 12:75
    4:00 12:77
    5:00 12:79
    6:00 12:79
    7:00 12:80
    This was not open circuit, the battery was still seeing loads from the car, at least the 20-25 mA parasitic load. So this AGM battery won't hold even briefly at 13 volts or higher with small loads, but 12.80V isn't terrible.
    Finally, in terms of overthinking things. I have assumed that the car has some sort of battery management system for the 12V, and the little sensor wire plays a role in that. What if that assumption is wrong? Perhaps the car just has a two level DC to DC converter, with the lower level only able to provide a limited amount of current (slightly more than what the car needs when it is in "D" and none of the accessories are on) and any current demand above that amount causes the converter to switch to the higher level (14.1V) because it needs to in order to be able to provide more current. I know the driving lights pull just below 3A and that is enough current to trigger this transition. What if the headroom is only 2A, or even 1A? Well, if the 12V isn't near 100% SOC it is going to draw that much as it charges. In other words, these transitions that are seen with nearly full/not full batteries may just be a function of the design of the two level converter. Perhaps it was not specifically set up to put the battery in float or bulk/absorption charging, other than the lower is high enough to charge the 12V (slowly) and the higher is low enough not to burn out the battery if it has to sit at that voltage all day. That would make the purpose of the sense wire even more mysterious.
  10. ChapmanF
    18,155
    The sense wire is definitely sensing voltage, and sensing it at the battery itself so as not to be thrown off by voltage drops in the wire harness from whatever currents might be flowing.
    Of course the question arises, how does the control algorithm keep tabs on the battery's state of charge, when the DC/DC converter is active and the voltage being sensed is determined by the converter output?
    You might try to connect your work with some older posts around here—I think the member might have been RGeB—who had graphed some nice datalogs of the voltage over the course of a drive. The graphs seemed to show there were occasional moments where the voltage dropped even below the lower usual converter output voltage, just for a brief blink. It looked as if there might be a strategy of occasionally blinking the converter output off and sampling the battery voltage.
  11. pasadena_commut
    2,620
    776
    Southern California
    There is a very heavy cable from the positive battery post to the jump point in the fusebox. When the car is in READY it has maybe 4A flowing through it. (There is some debate if it ever sends more current than that to the battery. The Yuasa batteries have a sticker that says not to. If the battery is nearly charged it certainly sends much less.) The resistance of that cable would be pretty constant, so the car could conceivably use it as a shunt resistor and control the current going to the battery based on that voltage.
    Using the calculator here:
    Voltage Drop Calculator
    and assuming 3 Gauge 13VDC 4A 8 ft. length the voltage drop across the cable would be .016V. So I guess the sense wire could in theory enable seeing the difference between 13.016V at the jump point (if there is a wire for that) and 13.000 V at the battery's positive post.
    Otherwise though, the voltage at the battery is going to be very close to the voltage in the box. I have no idea what the voltage drop from the converter to the fuse box might be. Perhaps the car doesn't either and it just uses the battery sense wire for both?
  12. ChapmanF
    18,155
    The converter is right next to the fuse box and connected by a very short stout cable.
    As for the cable from there to the battery, there may be greater variation in the current flowing than you expect, especially if there is a strategy in play of occasionally changing or dropping the converter voltage.
    But it is possible that Toyota, between gen 2 and gen 3, thought about it like you have, and decided that cable's voltage drop wasn't something to worry about. Gen 3 still has a converter with a separate sense input, but they just land it right on the bus in the fuse box.
  13. pasadena_commut
    2,620
    776
    Southern California
    After staring at the wiring diagram PDF for a long time I'm still not clear on the heavy cable geometry in this car. Looking from the top in the engine compartment there is one that comes up between the inverter and the box and attaches at the jump point, and it has a low resistance connection to the battery. There is also what looks like another thick cable nearby, but that is actually an outer wrapper around many much thinner wires coming from the white connector just posterior to the jump point. Is there a second, completely separate heavy cable from the converter to the fuse box (coming up underneath somewhere?), or is the thick cable with ends on the battery and jump post Y shaped, with one more terminus on the converter? On conventional ICE vehicles Y shaped cables with one terminus on the battery and the other two on the fuse box and on the starter motor are super common. Changed one on our Accord a few months ago.
    If the converter drops the voltage occasionally it certainly doesn't stop it completely, as Hobbit demonstrated the car would continue to run just fine with the auxiliary battery detached. Or maybe it is smart enough not to do that test if the sensor cable is waving in the air.
  14. ChapmanF
    18,155
    A separate one to the fuse box, I believe. The battery and converter connect on opposite sides of the 100-amp link in the fusible link assembly.
  15. pasadena_commut
    2,620
    776
    Southern California
    I think I finally found a decent explanation of why 13.6V and 14.1V (and not, for instance, 13.2V and 14.5V). This is for an SLA battery, but the chemistry they are talking about should be the same as in an AGM. (AGM is not supposed to gas because there is catalyst to reform water from H and O. Can it always keep up with the amount of gas generated above the gassing voltage? Who knows. It can certainly keep up if those gasses are never generated in the first place.)
    How to charge all lead acid batteries; how to charge SLA lead acid
    batteries, a tutorial for engineers about lead acid chargers and
    charging.
    Says:
    Anything above 2.15 volts per cell will charge a lead acid battery, this is the voltage of the basic chemistry. This also means than nothing below 2.15 volts per cell will do any charging (12.9V for a "12V" battery) However, most of the time a higher voltage than this is used because the battery will accept higher currents, enabling the charging reaction to proceed at a higher rate. Charging at the minimum voltage will take a long long time--over 200 hours. At 2.25V per cell (13.5) it would take 85-120 hours to fully charge. As you increase the voltage to get faster charging, the voltage to avoid is the gassing voltage, which limits how high the voltage can go before undesirable chemical reactions take place. Charging voltages range between 2.15V per cell (12.9V for a "12V" 6 cell battery) and 2.35V per cell (14.1V for a "12V" 6 cell battery). These voltages can be applied to a fully charged battery without overcharging or damage, since they are below the "gassing" voltage, and cannot break down the electrolyte. If the battery is not yet fully charged you can use much higher voltages without damage because the charging reaction takes precedence over any over-charge chemical reactions until the battery is fully charged. This is why a battery charger can operate at 14.4 to 15 volts during the bulk-charge phase of the charge cycle. Using modern precision chargers allows both a fast charge and safe floating voltages, allowing them to be left on the battery continuously.
    Emphasis added. So, while this doesn't explain why the car switches back and forth between those two voltages, it does say explicitly that 14.1V will not damage a fully charged battery. (Even though it is much higher than a typical float voltage, which is where chargers put 12V batteries which are full.) 14.1V is the highest voltage where that is true. It also suggests why driving short trips with the DC converter putting out 13.6V might not be enough to cover the current lost at startup (and getting in and out of the car and related loads), due to those very long charge times.
    Elsewhere they have a table showing the gassing voltage vs. temperature. At 30C it is 14.19V and at 40C it is 13.98V. I don't believe the 2nd generation Prius has any temperature compensation for the DC converter, or at least there is no temperature sensor at the battery, and this is why the AC must be run on hot days. If the battery is sitting at 14.1V and 100% SOC and 40C gas will be generated, hopefully to be reformed. Unfortunately the AC takes a while to get going, so the 12V battery might take a hit shortly after the car starts up in hot locales.
    However, if 14.1V is safe all the time (ignoring temperature), even on a battery at 100% SOC, it isn't at all clear to me why the car also has the lower 13.5V range. Perhaps, Toyota being Toyota, the lower range eeks out some fraction of a MPG improvement over the higher voltage?
  16. dolj
    dolj Senior Member
    8,442
    4,289
    I don't observe this behavior of bouncing between ~13.6V and 14.1V. Never seen it.
    I recently tried your scenarios where you claim to see it. I had 13.7V on my voltmeter, I switched on the lights. The voltage dropped by 0.1V to 13.6V. I turned the lights off, and the voltage returned to 13.7V.
    I then tried the A/C fan on all speeds from low to high, stepping through each speed one at a time. There was no change in voltage.
    My observation, over a long period of time, is that the voltage I see on my voltmeter is directly tied to the SoC of the battery.
  17. pasadena_commut
    2,620
    776
    Southern California
    I wonder if there is some small difference between the US and NZ versions of the car. The repair manual (or was it the wiring diagrams?) show that there is a logic line that changes the output voltage base from 13.5 and 14.0. So if they are the same there should be some scenario where "12V" is over 14V. If the 12V battery is fairly discharged, like say 70% SOC, even then it doesn't go above 14V? That would be really surprising. Any battery charger one would attach in that situation is going to push the voltage up to 14.5 (ish) by the end of the constant current phase.
  18. dolj
    dolj Senior Member
    8,442
    4,289
    I doubt it.
    On my old 12V battery, i.e. before 2016, my voltage lived at 14.4V. I have never seen it higher than that. When I got the new battery, I would see 14.x regularly, and when I saw that, I charged it externally with my CTEK MSX5.0 charger. The highest voltage that that charger pushes is 14.4V in the absorption phase.
    Since driving less these days, I regularly have the car on the charger and very rarely see 14.x voltages.
  19. pasadena_commut
    2,620
    776
    Southern California
    Hmm. If our battery has been discharged a fair bit (like say from turning on the headlights for 10 minutes) it will start at 14.4 but comes down to 14.1 after 20 minutes or so. I never checked on the 13.6/14.1 switch when it was at that highest voltage. My best guess is that it won't drop to 13.6 until the converter voltage has dropped down to 14.1, or maybe 14.2, so that the current going into the battery is below X amps. Not sure what X is, but suspect around 2.
  20. pasadena_commut
    2,620
    776
    Southern California
    Some information on these cell caps on the AGM battery:
    1. Removing the "tamper proof" caps. In the following video at around 4:10 they unscrew some of these using a flat blade screwdriver and a hammer. The method used is similar to that used on tamper proof screws with a punch and a hammer. Put the screwdriver/punch on the sloped side of a vane, tilted at a shallow angle, and smack it. The metal tool digs in and it rotates the piece out. Only 5 came out in good enough shape to go back in, but they were able to scrounge one from another battery. I question the wisdom of pounding on a car battery like that since they can be quite fragile inside.
    2. Here are some pictures of what this valve looks like, or at least close to it. The source page is here:
    Supply Battery explosion-proof vent plug Wholesale Factory - Zhongshan Oursun New Energy Co.,Ltd
    and the image:
    It appears that there are three ring shaped seals on each valve: the narrowest is just above the cell (keeps gases in the cell trapped there), the middle is above the threaded part of the case (appears to work in conjunction with preceding seal to keep cell gases and atmosphere separated), and the largest is at the top of the battery case (keeps the atmosphere out, allows battery to vent all cells to one exit port). It appears to me that the valve allows passage of gas from the large hole at the bottom of the valve (at the right of the picture) to the small hole in the left of the picture. There is probably a metal ball and a spring inside the core. That small hole empties out into a gallery or space of some sort inside the battery, and on the Prius batteries, that leads eventually to the single vent port where the vent tube attaches. The valves do not vent straight up into the air, as the tamper proof part is solid and there is no sign that the dark plastic which is visible is anything other than solid and immobile.
    The manufacturer claims that the valve is good for 100,000 cycles. So, unlike the valve on the NiMH modules, which are said to jam up after a few venting episodes, these can let a little gas out at a time, many, many times. That in turn allows the battery to lose water whenever the internal pressure is too high.
    The battery in my car is from Korea and this part is Chinese. It may or may not be the ones which are actually used, but in terms of design I suspect it is very close.
    3. search for "vrla vent valve" in google images and the preceding one was found. As were many other designs. Here is one which looks to be almost identical, except either it has seals which are the same color as the core plastic, or it doesn't use rubber seals at all, just plastic to plastic with the case:
    Supply AGM battery Start-stop vent plug Wholesale Factory - Zhongshan Oursun New Energy Co.,Ltd
