ODO problem
Discussion in 'Prius v Main Forum' started by faizaldal6, Aug 7, 2020.
  1. faizaldal6
    faizaldal6 Junior Member
    England
    2012 Prius Alpha
    ----UK----
    Please can someone help me I've got a Prius alpha japanese import same as V and plus
    The issue I'm having is with the odometer is not counting the milage everything works on the display as it should how can i sort this out what would stop the ODO from counting ? I'm having troubles to understand when the dash works trip meter work etc
  2. Tim Jones
    Tim Jones Senior Member
    1,759
    565
    SE Texas
    2011 Nissan LEAF
    You could try disconnecting the 12 volt battery for 10 minutes.....
    52,395
    sounds like a bad combo meter
  4. David9962000
    David9962000 Member
    141
    68
    2020 Prius
  5. Prodigyplace
    12,681
    11,831
    Central Virginia
  6. Tim Jones
    1,759
    565
    SE Texas
    2011 Nissan LEAF
    Prodigyplace likes this.
