Odometer and actual ICE mileage.
Discussion in 'Gen 3 Prius Technical Discussion' started by Stratman, Mar 25, 2014.
  1. Stratman
    Stratman Member
    334
    74
    Lilburn Ga
    Since the odometer operates all the time, how do I know the number of actual miles on the ICE? My round trip work commute is less than 15 miles. My wife and I do 3 miles everyday at the park and that's about 4 miles round trip. During the above daily driving I'm in EV mode probably over 50% of the time.
  2. Stratman
    Stratman Member
    334
    74
    Lilburn Ga
  3. JimboPalmer
    12,470
    6,876
    Greenwood MS USA
    While I can't think of any reason to know this, it is just math. If you know the total odometer and the % of Hybrid travel Odometer * HV travel /100 = HV Mileage
  4. gliderman
    gliderman Active Member
    751
    225
    Why do you need to know the ICE mileage?
  5. Stratman
    Stratman Member
    334
    74
    Lilburn Ga
    For the same reason on any other vehicle. The odometer is relatively useless if I don't know what is being indicated. Given the type equipment I work on, I'm guessing there are other meters available in a diagnostic mode.
  6. Stratman
    Stratman Member
    334
    74
    Lilburn Ga
    Wow. I don't understand why anyone would not want to know. To me it would be like buying any other type vehicle used and when asked the salesman says "maybe 50k maybe 100k, why would any one want to know".
    csp1971 likes this.
  7. bisco
    51,154
    does the liftback have a lifetime hv/ev %? i don't think the ice is only on 50% of the time, but i'm guessing as well. going forward, perhaps a scangauge will help, but i don't know if it records something like an hour meter.
  8. gliderman
    751
    225
    Check Techstream for engine hours.
  9. xpcman
    xpcman Senior Member
    1,302
    295
    California - SF Bay area
    Well with any ICE vehicle you never know how many hours the engine has run. Just the number of miles. Lots of delivery trucks never turn off the engine while stopped.
    With the Prius there are times when the ICE is spinning with-out any gas being injected. How do you count this time?
    I agree it would be nice to know the total run hours of the ICE.
  10. gliderman
    751
    225
    Yes the ICE spins without using gas. No gas, no injection and no ignition, all computer controlled and are easily tracked. If the engine is spinning without ignition, then it is not running, just turning. Very low load, but still lubricated metal against metal.
    So why is it OP wants data on engine running? Keep track of gas used and you might be able to convert that to engine hours. But I would check Techstream and see if there was an engine hour timer.
  11. CaliforniaBear
    CaliforniaBear Clearwater Blue Metallic
    1,179
    289
    Northern California
    Odometers measure miles traveled on all cars! You might like an engine hours meter but even that doesn't really tell you much because its how hard the engine works, under what conditions that is important. If a conventional car sits idling in 100 degree heat and coolant at maximum temperature for an hour (no miles) is that the same as 4o mph on a cool day and coolant at 190 degrees for an hour?
    The ICE does't have to work for all those odometer miles. It doesn't have to work when you are stopped (ICE off) and perhaps the ICE is off some modest percent of the time at speeds below 40 mph. Just enjoy the fact the ICE (and brakes) will last a really long time!
    Stratman and gliderman like this.
  12. Stratman
    Stratman Member
    334
    74
    Lilburn Ga
    Thanks but I was right about there being other counters including hours on ICE. I'm guessing its in a higher diagnostic level probably inaccessible to the average Toyota technician. Anything software driven has a debug level.
  13. 70AARCUDA
    70AARCUDA Active Member
    845
    209
    Tucson, AZ
    And, adding a little "...flysh!t...to the pepper..." there is likewise the question of engine speeds (RPMs) the engine was turning when its engine-hours are being recorded, ie: stopped; at idle; at low-speed low-load; at high-speed low-load; or at high-speed high-load? It's definitely NOT a simple linear relationship like other vehicles follow.
  14. car compulsive
    car compulsive Active Member
    741
    274
    Michigan
    It seems that sensor readings and calculations like those used in oil life monitors would make a lot of sense with the Prius. I suspect that Toyota conservatively calculated that the duty cycle of the Prius ICE was safely above 10K, so they just set the oil change interval at 10K.
    jhinsc and CaliforniaBear like this.
  15. adamace1
    adamace1 Senior Member
    1,403
    193
    Charlotte, NC
    Some GM have a hour meter you can check.
