Odometer and Speedometer Accuracy
Discussion in 'Prime Main Forum (2017-2022)' started by wyobob, Nov 26, 2021.
  1. wyobob
    wyobob New Member
    Oregon
    2022 Prius Prime
    My brother just straightened me out. Radius doesn't matter. Mr. Leisk is on top of that too. Circumference, as converted to revolutions per mile, is apparently quite stable and predictable, so my new factory tires don't lie. Bias will only creep in as the tire wears or is replaced by a non-standard tire. My conspiratorial folly is revealed.
  2. fuzzy1
    10,706
    I once tried "tire radius" stuff, and couldn't get things to reconcile. Then realized that the contact patch on the ground is not a circle at all, but instead a flat patch. The circle equations just don't work for this as one might initially expect.
    Then learned that tires have RPM (revolutions per mile) specs, which have more to do with the effective rolling circumference of a squishy object. Some arithmetic revealed that this RPM spec corresponds to a radius point somewhere underneath the actual tread. Inside the tire.
    Don't focus solely on this tire radius stuff, it is a rabbit hole. It is more complicated, look for other approaches.
    alanclarkeau, wyobob and Mendel Leisk like this.
  3. rjparker
    rjparker Tu Humilde Sirviente
    11,097
    6,963
    Texas Hill Country
    If I changed my v from stock 205/60R-16 to 215/60R-16s the tire circumference would go up and the revs/mile would go down by 1.9%.
    My actual speed and odo would be 1.9% higher but the displayed values would be the same as with the factory size. However I still would not be speeding if the limit equaled my displayed speed because of the ~ 3% higher mph already built in. The error would be reduced by 1.9%. I would end up with an overstated odo because of the increased tire circumference.
    Interestingly, the v's master cylinder's skid control assembly (brake booster) is a different part number for 16" vs 17" wheels. I am sure other devices on the car are adjusted for stock tire sizes as well.
    If I changed my stock 16s to the factory low profile 215/50R17's, the displayed values would stay the same but I would lose 0.8% on the odo and actual mph. In this case the factory overstated mph would increase by 0.8%.
    Moral of the story, stay with stock size for odo accuracy. But Toyota's decision to overstate displayed mph keeps you legal.
  4. KYBlue
    KYBlue Active Member
    227
    112
    I've run Waze in Android Auto or my phone for a long time now.... I've got the GPS based MPH turned on in it, and run it pretty much all times I'm in the car. My 2013 Prius C, and now my 2021 Prime consistently report roughly 3mph OVER on the display what GPS based speed does. Other cars I've owned in the last few years it's always pretty much dead on. I also recently took a long drive following my brother in his new VW, he had his cruise set at 75MPH, while my Prime with the auto-adjusting cruise would ride behind him reporting we were doing 78 the entire time (and Waze/GPS telling me we were doing 75). My 2cents on the matter, probably owe you change....
    wyobob likes this.
  5. wyobob
    wyobob New Member
    Oregon
    2022 Prius Prime
    I have been enlightened by several of you. Thanks. I just got a bluetooth scanner for the OBD2 plug. It is fun to play with and confirmed that the ECM reports the exact mph without the fudging added to it for dashboard display. And I now have got religion on rpm- and tire circumference-based odometer.
    So that leaves me with a second subject - mpg's displayed with the odometers. I understand that most all makes introduce intentional high-bias for the mpg mileage. Since the miles are very very close to the truth, they are fudging the gas flow numbers down. There is no law- or regulation-based reason for this, is there? In my case (2022 Prius Prime), the mpg bias has accumulated to an average of 6.5% high bias over 7 tank fills totalling 62.77 pumped gallons. Cumulative gallons reported by odometer is calculated to be 58.68 gallons, so actual gallons are 7% higher, which causes 6.5% high bias of mpg. I can see exaggerating mpg by 2-3%, but 6.5% sounds like deception to me, and it sounds common in the industry. I think I have run through enough gallons to have some confidence in that percentage. And I don't think Oregon and California regulators are letting their gas pumps fool me.
  6. Mendel Leisk
    42,343
    My first experience with mpg display was with an 06 Honda Civic Hybrid, and it was spot-on, or slightly pessimistic (under reported mpg). With our 2010, Toyota's basically lying; with over 10 years of records the error's currently at 7.2%.
  7. fuzzy1
    10,706
    Yes, MPG display accuracies remain unregulated, and a high bias appears to be the industry norm. The amount of bias you are finding seems consistent with the Prius family from 2010 on. Some older hybrids were much more accurate, Mendel points out one example. I also seem to remember that some car reviewers testing prototypes found their displays to be fairly accurate, these significant biases didn't appear until forum readers were able to buy actual production models.
  8. Lee Jay
    Lee Jay Senior Member
    5,850
    4,036
    Westminster, Colorado
    Gas pumps only have to be accurate to 3%.
  9. Mendel Leisk
    42,343
    Could have been from me: I read Wayne Gerdes's (cleanmpg founder) 4th gen Prius review, and he found the mpg display accurate. Only hitch: it was a pre-production model, slated to be crushed in about a week.
    fuzzy1 likes this.
  10. fuzzy1
    10,706
    References?
    My state's weights and measures webpages are very opaque on this at the moment, hiding the actual standards, but I'm finding news stories of pumps failing inspection for errors of 1.2% and 0.4%.
  11. fuzzy1
    10,706
    Wayne was the specific reviewer name coming to mind, but I thought this issue happened on more than one vehicle he reviewed, and also on other reviewers.
  12. Lee Jay
    5,850
    4,036
    I don't know - I read it in my state's regulations a long time ago. Maybe it's better now but that's what it was when I read it.
  13. fuzzy1
    10,706
    I just found a couple very old items referring to some states having a limit of 6 cubic inches of error in 5 gallons, which translates to 0.52%:
    Inspection Reveals Variations in Gas-Pump Accuracy : NPR
    https://www.mcall.com/news/all-watchdog-080308-gs-story.html
    A much more recent Australian industry article mentions a 0.3% limit:
    https://acapmag.com.au/2019/03/are-your-pumps-accurate-nmi-inspectors-visiting-sites-in-the-wake-of-startling-increase-in-pump-inaccuracy/
  14. Mendel Leisk
    42,343
    This wiki article on gas pumps says 0.3% too, presumably USA specific:
    https://en.wikipedia.org/wiki/Gasoline_pump
    It's some ways down in the article, you could search for this string:
    The standard accuracy is 0.3%, meaning that a 10-US-gallon
    fuzzy1 likes this.
  15. wyobob
    wyobob New Member
    Oregon
    2022 Prius Prime
    One tidbit of preliminary mpg info - Of my 7 gas fill-ups, four were in Oregon and three were in California. While my overall calculated mpg high bias is 6.5%, the individual fill-up calculations indicate larger high bias in California than in Oregon. That is, Oregon fill-up bias averages 5.6% and California fill-up bias averages 7.7%, so far. Pump regulation error, or maybe something to do with measuring the injector flow of gas with variable ethanol content????
  16. Salamander_King
    Salamander_King Senior Member
    11,024
    8,978
    New England
    Even if the gas pump is accurate to 0.3%, there still are quite variables in the amount of "full tank" from one fill-up to the next, I would think. I try to be consistent, but depending on where I fill up when the auto-shutoff stops the delivery there seems to be a difference from one fill to the next even at the same pump.
  17. Gokhan
    Gokhan Senior Member
    6,714
    2,672
    Paramount CA
    In my 2021 Prius Prime Limited with Dunlop Enasave 01 A/S tires, the speedometer shows exactly 2 mph higher than the actual speed at all speeds.
  18. wyobob
    wyobob New Member
    Oregon
    2022 Prius Prime
    I just got a car scanner for my Prius ODB2 port. It can display fuel usage, but I don't know if it can accumulate and report fuel usage over multiple uses of the car to compare to fill-up data. I already know that it reports mph which is accurate and 2-3mph below the dashboard mph, so it would be a good guess that the fuel usage according to the car's computer is fudged up to fabricate the dashboard mpg just like it does with mph. If such is the case, then filling station pump bias or fill-up bias are not the issue.
  19. wyobob
    wyobob New Member
    Oregon
    2022 Prius Prime
    My 2022 Prius Prime with same tires shows mph on dashboard at 58mph when my scanner of the car's computer shows 54.7-55.3mph, so there is 3mph high bias at 55mph actual. At 32mph on the dashboard, the high bias is 2mph. As resolved earlier, the odometer miles for these new factory tires are very accurate at less than 0.1% error, so the mph bias we see is some kind of simple arithmetic fudge upwards, whether the fudge is a constant 2mph or something proportional to speed, and has nothing to do with measuring distance accurately.
    Gokhan likes this.
  20. bisco
    52,849
    i always drive 32 in a 30mph zone
