Odometer/Gas indicator blinking and Maintenance required light on. Stuck at 0 mph
Discussion in 'Gen 3 Prius Technical Discussion' started by Aluhex, Nov 17, 2017.
  1. Aluhex
    Aluhex New Member
    Orange County
    Just filled up my gas tank 2 days ago and the next morning gas is at one bar and flashing, odometer is also flashing and the "maintenance required" is on the screen. However later in the day it reverted back to normal. This morning it did the same thing. The issue is at 7:40 AM and is resolved around 9:30 AM, meaning it reverts back to how it should be. Speedometer is at 0 throughout drive and after turning the car off the screen shows "miles traveled, gas consumption, etc"
    Video:
    2012 Toyota prius
    *Update, Everything was fine again from 10 AM-5PM but when I started my car at 9 PM the issue occurred again. I made sure my gas cap was on tightly.
  2. JC91006
    16,936
    8,647
    Check your battery and it's connections
  3. Dxta
    Dxta Senior Member
    1,945
    770
    Lagos
    For the blinking fuel level indicator, could be there's some kind of partial connections some from the battery location.
    The system might be recalibrating itself, or so. I thinkbits has to do with the bladder in the tank?!
  4. sparkk
    sparkk New Member
    Pakistan
    I m facing the same problem with my Prius 2011.
    Aluhex, plz guide if ur problem solved.
  5. Mendel Leisk
    42,332
    Troubling, display going bad? Corroding connections??
  6. sparkk
    sparkk New Member
    Pakistan
    Since last couple of days in morning while first start odo reading+fuel bar start falshing with the msg "Oil Maintenance Required" and speedometer stuck on "0' during drive however if I switched off power with/without drive then odo reading flashes nd after waiting some seconds it's goes off nd then by pressing power button again it's comes to normal. I have also performed oil maintenance reset but it's end on message "Oil Maintenance Reset Incomplete".
    So experts kindly advise.
  7. Mendel Leisk
    42,332
    Contact dealership. Also consider contacting Toyota directly; I'd think this is a safety issue.
  8. Dxta
    Dxta Senior Member
    1,945
    770
    Lagos
    Asides that, has there being any signs of water intrusions on the connectors at the engine bay?
  9. Prodigyplace
    12,712
    11,848
    Central Virginia
    Health of 12 volt battery?
  10. sparkk
    sparkk New Member
    Pakistan
    Not only in morning I got same error even when I power on after almost 5 hours parking, and then I got it temporarily fixed after switched off nd waited for the odo reading flashing to went off. I have loaded both videos for the better understanding, so experts kindly advise a permanent solution.
  11. Sirjuan
    Sirjuan Junior Member
    Chicago
    Long shot but did anyone ever figure out the fix or cause of this? I’m having the same Issues. Flashing speedo which is stuck at Km/h, gas gauge flashes the bottom bar only and the trip dial is not showing estimated miles note odometer ready. I’ve checked fuses, put in a new 12v aux battery but absolutely no luck. Me and my wife just had a baby and she’s been driving the car like that and I’m just worried for her safety. Any clues to this fix would be amazing.
    Thank you
