Odometer Issues. Service Record not matching Prius.
Discussion in 'Gen 2 Prius Main Forum' started by Soybomb70, Feb 25, 2013.
  1. Soybomb70
    Soybomb70 New Member
    I recently bought a 2007 Prius with just a little over 98,000 miles on it. Registered it today with Toyota and discovered that their service records have the car at a much higher mileage. Before I start hurling fireballs and pursuing legal action I wanted to ask if you guys think this has an explanation that isn't shady. Attached is my service record I inherited.
  2. 2k1Toaster
    6,035
    3,856
    Rocky Mountains
    One incorrect log would suggest the service tech typed it in incorrectly. But looking at 20K miles per year on average, it looks like the 115K is reasonable.
    Does the odometer say 98K on the instrument cluster? That entire module can be replaced, and the odometer will be whatever the other module is at. Brand new they come with 0 and the dealer is supposed to program them up. Used you can pull one with a car with XYZ miles, and voila the cluster will now say XYZ.
    The real odometer info is stored in 2 other ECUs I believe, and I think the genuine Toyota TechStream can "verify" the mileage to prevent this exact thing. But I am not 100% sure on that.
  3. cwerdna
    cwerdna Senior Member
    12,545
    2,125
    SF Bay Area, CA
    If that's your address in there, I'm not sure you want to post it publicly...
    Anyhow, can you maybe also run a Carfax check (or something along those lines) to see if there's other evidence of an odometer rollback? So far, the signs aren't looking good given the dates and what's unlikely to be a whole series of errors on the report.
    And yep, the combination meter (instrument cluster board) can be replaced and yes, it'll end up displaying whatever mileage it was came with/was set at.
    I'm not sure about his last statement though and whether there are other possibly more correct mileages stored anywhere.
  4. Soybomb70
    Thanks I took that out!
    I made an appt with Toyota to see if it has been tampered with. I'll let you guys know if that's been replaced.
    I have the carfax and used that to buy the car. Nothing sketchy on there. It wasn't until today that I registered the car and discovered this mystery.
  5. sdtundra
    sdtundra Senior Member
    1,314
    194
    Sacramento, CA
    I think carfax has some sort of guarantee for stuff like this.The CARFAX® Buyback Guarantee®
    ewxlt66 likes this.
  6. ETC(SS)
    7,491
    Somebody diddled with the mileage. No doubt. You may want to very carefully examine the paperwork that was generated with the sale. There might be a little check box that you didn't notice that says something like "odometer was replaced - mileage is estimated"
    Every state does it differently, so you'll need to find out what happened between Aridzona and where the car is right now (if you're in a different state) and if you bought the car from a stealership, then I'd involve the mother ship and/or the BBB and/or LEO's or at least I'd threaten to loudly and often until I received a satisfactory answer. If you bought the car from a dealership, especially a Toyota dealership they might think (perhaps even honestly) that they're blameless.
    That's somewhat debatable since they might be "legally" innocent, which is entirely different than being smart or ethical.
    If I were in the biz, and I took a car in on trade I think I would be at least smart enough to do a brief records check to see if the mileage is quasi believable.
    If you bought it from an individual....then it's even easier. They presumably signed off on some kinda odometer declaration when the "change owner" light came on.
    They make it right, or you litigate.....or press charges as the local laws might dictate.
    As far as Carfax is concerned...yes, I pop an angry red flare over them too. I don't have very much experience with them (no offence, but stories like this are why I always buy new ;) ) however (comma!) I'm presuming that their "guarantee" has about as much "honesty" as a political speech. Still....I'd make them defend the flag as well.
    OK...
    So...
    If all else fails, there is a track record for this car, and it appears that some passing attempt was made at routine maintenance. The only things that stands out to me is that the tires were changed out at 31K in 13 months which indicates (to me) that the car was either being driven by a kid or a pretty clueless (or spirited) adult.
    31K miles in 13 months usually indicates highway driving and even the low dollar OEM tires should be good for more than 31K miles - even with one of them having been repaired.
    Of course...there's also the little matter of the year and a half that's elapsed between the last dealership visit (@115K) and now. You're probably looking at a 140,000-150,000 mile car instead of a 100,000 mile car.
    It probably hasn't been wrecked, stolen, or flooded so it's probably an OK car. You just took in in the shorts for about 1-2 years worth of normal wear.
    Start thinking about things that you would replace @ 150K and go from there.
    It's still very probably good for the better part of another 100,000 miles. ;)
    I'm sorry that this happened to you!
    Best of Luck
    ewxlt66 likes this.
  7. fuzzy1
    10,687
  8. Soybomb70
    Just got back from Toyota and they didn't even want to start touching it until I called the little dealership I bought it from to see what is going on. Called the dealership (or stealership as ETC SS put it) and they are more than happy to refund the purchase and were apologetic about it. I thought about keeping it after they gave me a kickback for all of the unknown miles that are on this car but then what about in the future when I want to replace batteries and warranty/recall issues. Seems like that would be a headache and a half I'd have to endure every time I wanted to make repairs. So looks like I'll be back to the drawing board hunting down another Prius this time with a little more knowledge and another flag to look out for.
    Thanks for all your help peeps!
    ewxlt66 likes this.
  9. 2009Prius
    2009Prius A Wimpy DIYer
    2,705
    512
    63
    Agreed better get the refund now than regret later. Good luck hunting!
  10. fuzzy1
    10,687
    Whether or not they were knowing participants of a rollback scheme, at least they did the right thing by offering to undo the transaction. And better still to give you an additional choice. Good for them.
    PriusGuy32 likes this.
  11. ETC(SS)
    7,491
    Sounds like the...ah..."Little Dealership" did the right thing...by you at least.
    I'm still a little sketchy about how somebody that's IN THE CAR BIZ doesn't catch this when they take ownership of a 98,000 mile car....but that's why I stay away from little car dealerships.
    You're in the market for a used Prius?
    Guess what???....so are a BUNCH of other people!
    Stay away from those corner lots! Generally speaking.....when people buy a new car, they trade out their old car. It's dumb as heck, but they still do it a LOT. When the new car dealership gets a car that's been rode hard and put up wet, they generally wholesale it off to an auction house (since they've already made a lot of money off of the sap that traded it in! ;) )
    If they get a car that's decent, then they will often stick it on their used car lot, especially if there's a good history on the car. If it's a REALLY good car? They might put it into a CPO (certified pre-owned) program and slap a warranty on it.
    A lot of times a dealership can make more money on their used car lot than they do hawking the new ones. This is because everybody knows (or should know) just about how much you can get a new car for down to the nearest hundred bucks or so. A used car?
    Not so easy to stare and compare, is it? And remember...they probably shanked the previous owner when they took possession.
    OK...so "shanked" may be a somewhat jaded opinion but I come by it honestly and the car biz is rigged heavily in the house's favor!
    SO...try to buy from a private seller, and get as many records as you can.
    If you want to shop at a dealership...I'd stick with the bigs, and pay a little more (verifying again!)
    Good Luck!
  12. Blu-ray
    Blu-ray Blizzard Brigade #215
    471
    198
    TampaBay, FL
    When I went to buy my Prius I traded in my Camry. The dealership is the same place that services it. The Carfax states and odometer discrepancy. I was livid. No way no how. The dealership had reported the mileage incorrectly on one of my services it turned out. I had all the receipts showing everything I had done to the car which they matched in the system. None of my receipts showed the mileage that they reported. I raised my voice about how it was their mistake and I shouldn't be penalized for it. They gave me way above Kelly for my trade in to shut me up. :)
    I have a feeling that whomever does the mileage reporting got an a$$ chewing on that one! I mean what if I had gone somewhere else?
  13. Soybomb70
    Thanks for the knowledge! Definitely will be buying from private seller.
