Odometer reading w/o fob
Discussion in 'Gen 2 Prius Technical Discussion' started by Jo-Jo Joseph Mims, May 17, 2021.
  1. Jo-Jo Joseph Mims
    Jo-Jo Joseph Mims Junior Member
    17
    South Carolina & more
    Is there a way to read the odometer on a junk yard prius?
  2. dolj
    dolj Senior Member
    8,652
    4,403
    Wellington, New Zealand
    Nope. You need to get the car on to at least IG-ON.
  3. Jo-Jo Joseph Mims
    17
    I'm wondering whether it might be done by switching out a matched fob and reader receptacle. Where is the code stored?
  4. PriusCamper
    PriusCamper Senior Member
    13,468
    5,438
    Pacific Northwest, USA
    #4 PriusCamper, May 17, 2021
    Jo-Jo Joseph Mims and bisco like this.
  5. Jo-Jo Joseph Mims
    17
    Super... Thanks...
    I've been putting off getting set up with register an because I have an older laptop that I believe will not run it...however, maybe it's time so that I can try scanning salvage yard prii.
  6. Mendel Leisk
    42,362
    I’m just wondering: EVERY time our (3rd gen) car is “turned off”, it displays odo, for about 30 seconds. And when I sometimes forget to have my fob on me, get in the car, it WILL wake up, with a push of the ON button. It tells me something about key not detected, but is “on”, or something. When then turned off (nother push of the button), not sure, but MAYBE it still displays odo??
    Or maybe I’m dreaming? Or it’s not the case with second gen? Test it on your car?
  7. TMR-JWAP
    TMR-JWAP Senior Member
    6,404
    6,095
    Columbia, SC
    Do the salvage yards in your area actually leave the batteries installed in the vehicles or do you plan to lug around a small 12v battery?
    The mileage is stored in the combination meter, so I would imagine if you were able to just apply power to the appropriate relay contacts, you could get it to power up the display. Maybe just get power to the power source ecu? Or if the car is partially disassembled, just determine which wires on the combo meter need to have 12v applied in order to power it. I made 2 test adapters for powering up the MFD displays, so I'm sure it can be done for a combo meter. Find a salvage car, chop the wires going to the combo meter so you have a pigtail with the connector on it, figure out which wires need to have power/ground and then cut all the other wires right at the connector so they're out of the way.
  8. Mendel Leisk
    42,362
    Bring along a jump pack?
